Question about Kyocera Mita FS 680 Laser Printer
Connect kyocera fs680 to laptop
Is it possible to connect my kyocera fs680 to my laptop?
if so then what cable do i need for the different connection?
thanks,rory.
  • 622 Answers
It comes standard with a parallel interface so you need parallel to usb interface cable.. to connect to laptop... if it has an optional ethernet card installed then you need a cat5e crossover cable... if the crossover cable doesn't work then you need a network switch and two cat5 ethernet cables...
Posted on Dec 24, 2009
  • 27 Answers
It depends on what laptop you have. the fs680 only has a parallel connection so your laptop needs to have a parallel port or you need a usb to parallel converter.
Posted on Mar 13, 2009
Just bought a Kyocera FS-1030D laser printer. what do i need to do or need to connect it to my laptop. have power cable but no disks
I looked up the specs this has a usb 2.0 interface so you need a usb printer cable. it has a parallel interface but this is an older technology and your computer most likely does not have a parallel port.
you need to download the driver see http://www.kyoceradocumentsolutions.eu/index/service/dlc.false.driver.FS1030D._.EN.html
windows os may have a driver already.
Jun 16, 2015 | Kyocera FS-1030D Laser Printer
Compag laptop connected to LG HD TV. TV screen just show blues and greens, no reds. What do I need to do
To troubleshoot this, you must first start with the obvious. Check your cable connections/try replacing the cable. If this does not work you should then check the color settings in the tv. If that still does not work you can try connecting your laptop to a different monitor/tv. If the color shows up with the same problem, you know the issue is contained within the computer itself. Possibly bad VGA/HDMI Port or color management settings.
Nov 18, 2010 | Compaq Computers & Internet
I have a kyocera fs-c5016n brought it home from office. It was on a network there. I have it connected with a network cable at home to a router. Can't get it to change from parallel interface to...
The display just indicates the default interface. If you have everything connected properly and send a print job to the printer it will automatically switch and print out. The default interface can be changed but there is no need to for your application.
Nov 12, 2010 | Kyocera Mita FS-C5016N Printer
How to replace a VGN-FS680 keyboard I'm trying
the battrey isnt under the keyboard from memory i believe you will have to pull the back off which is extremely difficult
Feb 19, 2010 | Sony VAIO VGN-FS680W PC Notebook
My packard bell lcd monitor shows orange then sometimes green light but has totally black screen. If power supply giving insufficient voltage would this cause above problem?
> insufficient voltage cause ?
Well, anything is possible, but other things are more likely:
1. loose connections of the "data" cable between the monitor and the computer's video-card;
2. an electrical "short" in the data-cable;
3. a "dying" video-card.
So, try the "free" stuff first:
Check the connections.
Try a different cable.
Try connecting the monitor to a different computer (laptop?).
Try connecting a different monitor to your computer's video-card.
Then, consider buying & installing a new video-card.
Nov 18, 2009 | HP Computers & Internet
Kyocera 4530 is reading offline
I would check the usb connection cable - maybe try a different one. 'off line' normally means that the computer can't communicate with the printer. Silly thing - check that the printer has power. I'm not trying to insult your intelligence, but sometimes it's the simple things that get missed.
Feb 12, 2009 | Kyocera Mita KM-5035 Printer
How to watch laptop in my Sony Bravia?
you need to clone the acer screen using ati utility
Jan 26, 2009 | Televison & Video
Network or usb cable
Look on the back of the printer. If it's possible, you'll see a USB connector that looks kind of like an arch or doorway. If so, use a USB A to B cable to connect it to your PC. Make sure you use the drivers for a USB connection when reinstalling it.
Jan 14, 2009 | Kyocera Office Equipment & Supplies
I cannot take prinout from kyocera FS1030D from my laptop
make sure you have the correct driver for your laptop operating system and you have a usb2 cable
Dec 03, 2008 | Kyocera FS-1030D Laser Printer
How to clean the printer inside
You can use an aspirator to clean the printer inside, and if you have a little experience you can clean the blade inside the cartridge with isopropylic alcohol, and the drum too. How many times was the cartridge refilled?
Oct 14, 2008 | Kyocera KM-1505 Copier
Kyocera Mita FS 680 Laser Printer Logo
143 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
