Mitsubishi TV keeps shutting off!
2 1/2 years old 6400 hours shuts off with red blinking light codes are 034-lamp and 048 main assy. Where can I get a main assy? part # 934C328001 MIT no longer has these go figure
  • Joe Burdek
    Joe Burdek Dec 13, 2012
    I fixed my Mitsubishi TV myself. Easy fix. Bought a board & lamp on eBay item# 230896497758
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
I have only a suggestion if lamp has been ruled out but it depends on if set does come up and play for a short while or NOT>
Mitsubishi is well known for the parts issues like yours.
Posted on Dec 11, 2012
Slinteriors
  • 8617 Answers
SOURCE: TV shuts down with Red Light blinking
Thats an easy set to trouble shoot, but you would need the manual called toshiba power supply and shutdown circuit troubleshooter. It takes you step by step on the items to check so you can easilly pinpoint the problem. You can get that manual at the following link, they email it right after purchase and they also provide free one on one tech support so you can get help with it if you need. Heres the link
http://servicemanuals.vstore.ca/
Posted on May 10, 2008
SOURCE: mitsubishi WS-55859
Easy to fix this problem, I did 1 mounth ago. 30 min and $20 dollar
Posted on Dec 30, 2008
SOURCE: My Mitsubishi DLP TV has a 7 month old bulb, but
take the bulb out and clean the dust on and around the fan. Doing this every 3 to 4 months will extend the bulb life. The little red lamp light that is coming on is an indicator that the bulb needs replaced. Make sure you DO NOT touch the bulb with your fingers. There is a button for reseting the bulb when you replace it. I have a 65 inch Mitsubishi DLP that the bulb just went out on. This worked for me...hope it works for you.
Posted on Jan 05, 2010
SOURCE: WD-62327 Lamp
OSRAM VS. PHILLIPS
This is about buying replacement bulbs for the WD62327 TVs.I dont know about the other models but I purchased a PHILLIPS replacement bulb and it worked for about a week and then those dumb flashing lights and no TV. I did some research and others were saying that you had to replace some condensers. Shop would do it for 600 dollars..Well i sent the bulb back and bought an OSRAM replaement bulb. The TV is now working perfect.
Posted on Jul 14, 2010
SOURCE: mitsubishi WD-65737 DLP TV. TV powers on, green
I had exactly the same thing happen..I contacted Mitsubishi and they said the software needs to be updated..they are going to send me the link to download the software.
Posted on Dec 29, 2010
Tv comes on with picture and then shuts down to red blinking light
It will be the LAMP the only last between 5,000 to 8,000 playing hours so if your not watching TV turn it off.
Jun 03, 2015 | Mitsubishi WD-60735 Projection Television
Display powers of with power up of AVC
how many blinks does the red light give in a row? This would be an error code?
The problem for 7 blinks would be an Interface board. Apparently there is a glitch in the interface board that sends signals to the television. Basically the glitch shorts out the board and the t.v wont turn on and you will see the power light blink 7 times pause then 7 more. You can replace the board with a new one and update the software on the new interface board.
If is isn't 7, let me know and I will help you out with this
thanks
Apr 26, 2008 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
TV shutting down, lamp and power light blinking
I would try a new lamp. Lamps have varying qualities & usage conditions may cause varying life spans.So, even though the lamp may be 1 year old I would try a new one first.
Jan 07, 2015 | Samsung HL61A650C Television
What is the solution to the blinking green light and welcome screen then tv shuts itself off
I recently had this problem on my model as well, though it was lessthan a year old. The method that worked for me is to update thefirmware of the TV itself; you can download the new software, with complete instructions on how to update your TV at http://support.mitsubishi-tv.com/documents/WD-60C9
After doing this, my set started working again.
Do not replace your lamp. the light will blink red for a bad lamp, not green.
Jun 18, 2011 | Mitsubishi WD-60C9 60" DLP HDTV
I have a mitsubishi the model number is wd-82837 it keep shut down after blue screen show
Ur tv"LAMP"LED light indication flashes or stay on?Ur tv projection lamp been inside this tv like a 1 1/2 or 2 years and tv been on an in used like 4 or 5 hours every day.Yes to all of this,than the tv projection lamp is the causes and it life are ending.The tv projection lamp require replacing.
Dec 09, 2010 | Mitsubishi WD-82837 82 in. HDTV DLP TV
Mitsubishi WD-65737 DLP TV. TV powers on, green light starts blinking and blue screen shows up. TV then shuts down. I retrieved the error code and it shows "1-2". Any ideas? TV is less than a year old...
Oct 24, 2010 | Mitsubishi WD65737 65" DLP TV
Mitsubishi 53 projection TV- won't turn on- Red lamp light is on. Tried to turn the tv on and the lamp light turned amber and we heard the sound of the tv and then it shut off and the red light "lamp"...
unplug the set for over an hour, if the same thing happenes you will need service. Look at the power light, it should be blikning. If you count the # of blinks between pauses it will tell you the problem
Jan 10, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi wd52525 shows error code 37
error code 37 is either the dmd fan or the lamp fan. you can see the dmd fan with the cover off. you cannot set the lamp fan as it is under the light engine. I guess the easiest thing to do is get a lamp fan 299P282010 and a dmd fan 299P283010 and change them both.
Nov 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Shuts down automatically with red light
Push device and Menu in on the front panel together and hold for 8 seconds and see if the led blinks a two digit code. As it may be the lamp or quite possibly the Power PWB capacitors if it blink a 3 4 code.
Jul 16, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Turn on and Power and Lamp Lights blink.
Just because it doesn't look broken doesn't mean it hasn't failed.
Is the TV over 2 years old?
If so, buy just the bulb (not the whole lamp assy) from us at sedonix.com, install it yourself and save about 75% of what Mitsubishi charges.
Dec 13, 2007 | Panasonic PT-43LC14 43" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
