Question about Mitsubishi WD-52525 52" Rear Projection HDTV
YELLOW TINT ON SCREEN MITSUBISHI TV MODEL WS 55313
HAVE TRIED RE BOOT NO LUCK ALSO HAVE YELLOW TINT AND BAD COLOUR WHEN WATCHING DVDS
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
The WS is a picture tube type rear projection first produced as a 2003 model year set.
A few questions and then a offer if needed.
Did this happen suddenly or after a power loss?
By reboot do you mean the recessed reset button on the front of the set?
I will presume if you turn color off completely the screen is some other color than black and white?
the offer: have you tried the Option menu this set has hidden, I can explain if needed.
Posted on Dec 11, 2012
  • HammerDoc Sep 02, 2013
    I have had a Mits WS-65-813. It has been a great set. We got through the "blinking green light of death" capacitor problem a couple of years ago, and solved it by replacing with slightly higher rated capacitors. Now, the picture has a decided greenish tint that comes and goes, but is now present far more than it is normal. I have tried adjusting the individual colors and resetting the "perfect color" to factory defaults; unfortunately to no effect. Any help in eliminating this without buying a new set (cannot afford) would be greatly appreciated.
  • 6 Answers
SOURCE: Describe your Mitsubishi WS-65313 65 in.... Problem:
look for the CONVERGENCE settings either behind a small panel on the front or through the menu with the remote control
Posted on Jan 13, 2008
  • 41 Answers
SOURCE: deflect power supply
PCB Power has the Deflection Power Supply onboard and has a list price of $215.50 + S/H
Posted on Dec 17, 2008
SOURCE: Cleaning the bulbs and mirror on my Mitsubishi 55" WS-55313 TV.
You should re-consider having a tech do that for you. The access is by removing the screen assmbly which are somewhat fragile. If you want to give it a try, pull the speaker grill off, it comes off just from pulling it, there should be five screws across the bottom of the screen assy, remove those, there is also an access door on the front of the set with four screws, that has to be removed to unplug the cable that goes to the screen sensors. The screen assy has to be lifted straight up an inch or two and then you can pull it forward away from the set.
As far as cleaning the mirror and lenses, you can't get to the face of the tubes so it's the top of the lenses that you clean, just use a soft lint free cloth (cloth baby diaper) and wipe the dust off the lenses, you can slightly dampen the cloth with water if necessary, same type of cloth on the mirror and you can use a glass cleaner on it just don't press too hard on the mirror.
Posted on Feb 05, 2009
  • 9 Answers
SOURCE: I have a Mitsubishi WS-A48 TV. The plexi-glass
not personally order them no, mitsubishi will not let private parties order servisable parts, so u will need to order it through a service man, then, take of the back part side part etc... can be done, but before u get to it u will feel like u own a hardware store with all the screws they put in. be carefull not to touch the mirror!!!
Posted on Mar 18, 2009
  • 8457 Answers
SOURCE: Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Posted on Mar 16, 2010
My 55313 power light dose not come on
The SMPS section is not oscillating. Your TV need a through checkup. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electric shock. Instead, contact any experienced service technician, or the nearest service center.
Apr 24, 2013 | Mitsubishi WS-55313 55" Rear Projection...
Yellow tv colour tint
PLEASE CLERIFY ARE YOU USING COMPONENT CABLE OR COMPOSITE .DID YOU TRYED TO CONNECT TO DIFFERENT TV WAS IT FINE .
Dec 17, 2011 | Panasonic TX-32LM70 32 in. LCD TV TV/HD...
Mitsubishi ws-55313 vertical hold problem with tv
This set does not have a vertical hold control etc---try to explain what the set is doing or not doing so I or another expert can help you.
SD TECH
May 18, 2011 | Mitsubishi WS-55313 55" Rear Projection...
WS-55313 Where can I find replacement Lenticular screen?
800-553-7278 CALL MITSUBISHI PARTS
A WS-55413 LENTICULAR SCREEN IS $171.10 + DELIVERY BUT THE DIAMOND SHIELD ISNT NEEDED THEY TELL ME AND IT WAS DISCONTINUED ANYWAYS BUT YOUR PART IS PROBABLY AVAILABLE THERE.
Nov 24, 2010 | Mitsubishi WS-55313 55" Rear Projection...
Hi, i need a circuit board for a ws-55313, tv no is js-5531378010478
Encompass Parts Distribution has List of Parts/Prices and Free Service Manual that you can print out online 1-800-638-3328
Model# WS-55313 Your Model# will be printed on the back of the TV.
Nov 09, 2010 | Mitsubishi WS-55315 55" Rear Projection...
I have a cracked screen on my Mitsubishi ws 55313 model. where can I get a new screen? I actually need the screen and the protective screen as well. Thanks, Kris
These parts can be ordered from tritronicsinc.com (use the guest account) using the part numbers and costs below:
Fresnel screen Part number: 491P104030 Cost: $234.08
Lenticular screen Part Num: 491P103030 Cost: $188.21
Hope this helps,
Dan
Feb 08, 2010 | Mitsubishi WS-55807 TV
I have a mitsubishi 55 inch tv model ws-55313 i can hit power it will come on for a 20sec then powers back off what is the cause of this?
Hi my name is Roety,
I can help you with your issue ,
Most likey you need the convergence ICs replaced.
A repairman would charge about $350 to replace them
Voltage checks and a visual would be needed to determine exactly what is bad in your TV
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 20, 2009 | Mitsubishi WS-55313 55" Rear Projection...
Mitsubishi WS-55313 no video
Resolder the vertical output IC that should take care of your problem.
Jun 16, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Cycling by itself
Pressed the ff on the tv remote...Menu 0370...be careful in selecting an option...have to make sure that what you are going to highlight or select is initial..selecting E2 reset would render your tv unusable..don't attemp to make any other changes on the service menu...JUST SELECT INITIAL..no other option should be selected on the service menu screen.
Aug 30, 2007 | Mitsubishi WS-55313 55" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
297 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
