Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater rh125t will not pump enough fuel to stay on
The glow igniter will glow and then the fan will come on but the not enough spray for the heater to turn on. then shuts off
  • d_lanclos Jan 15, 2009
    I have by-passed the filter and put the hose straight to a bottle and it will do the same problem
Checked your air pressure? If you look at the back of the heater, the pump cover will have 2 small yellow plugs. The left is a plug where you install the air guage to check the pressure. The right one adjusts the pressure at which the pump blows the fuel in.
Posted on Jan 21, 2009
HAVE YOU CHECKED YOUR FILTER AT THE FUEL TANK?
Posted on Jan 15, 2009
  • ZMS2 Jan 16, 2009
    The photocell may be bad. It must see the proper color of flame before it will allow the heater to work. They are approximately $16.00. I purchased mine at Rural King.
  • ZMS2 Jan 16, 2009
    TRY THIS WEB SITE IT HELPED ME OUT. http://www.reddyparts.com/
I replaced all filters and the nozzel pump presure is at 6psi i'm running desiel the ignighter glows for 5-6sec I'mgetting fual but ignighter goes out before flame
I want you to inspect the fuel tank, you are looking for water that may have entered while in storage. Condensation builds from storing them and it can duplicate what you are saying here. What I did was to empty the fuel in a clean five gallon bucket and observe, fuel is lighter than water so it floats to the top water sinks to the bottom. If water is present please try to dry out the tank the best you can by soaking it up with a rag. You can siphon off the fuel just be careful not to get the water. If no water is present check to see how the igniter is positioned in conjunction to the angled spray of atomized fuel.You may have to bend it in a little closer to the fuel.
Dec 28, 2010 | Reddy HEATER RH125T 125,000-BTU...
Ignition starter fail
Read these troubleshooting tips. You must determine whether the failure is a fuel delivery problem or an electronics problem.
Reddy Heater troubleshooting tips
Oct 19, 2010 | Reddy HEATER RH125T 125,000-BTU...
Reddy heater has problem staying on
Check the foam filters located in the back, their is also a primary air adjustment slot in the back try adjusting that each time you fire it to see if you can get it to stay on.
Can you see the fuel oil coming out of the nossle? If
not clean it. If it has a cad cell that could be bad or dirty, you might have to bypass it to see if that is the
problem.
Jan 15, 2010 | Reddy HEATER RH125T 125,000-BTU...
Reddy Heater not firing
Take air preassure from an air hose to turn the fan blades to loosen everything up. Time for afull service, like change the vanes in the pump, 3- filters fuel--2 air.
Dec 15, 2009 | Reddy HEATER RH125T 125,000-BTU...
Reddy r200b keroseen heater will not ignite
CAD flame sensor is bad, also check your air inlet line for the fuel mix, could be cracked.
Jan 20, 2009 | Desa International Reddy Heater R200BT...
100,000 btu therm controled heater
What did you set the air pump pressure at? This is critical on heaters with Hot Surface Technology. Setting the pump pressure is always the FIRST place to start troubleshooting on these heaters.
Here are some things that can prevent ignition even though there is fuel & glow:
  1. wrong air pump pressure
  2. the nozzle is restricted & distorted not allowing fuel to contact the glowing ignitor
  3. the nozzle is worn. It should produce a cone of fog, not a spray.
  4. there is water in the tank below the fuel.
Oct 23, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
186 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
