Question about RCA Televison & Video
I need three step instructions - RCA Televison & Video
  • RCA Master
  • 8,617 Answers
Which instructions are you needing? also whats the model number of your RCA?
Posted on Dec 11, 2012
Trying to find a remote code. The tv is a 19"PLEDV1945A-B and the remote is a Time Warner UR5U-8780L-TWC
TV Instructions:
TV Codes: try 333
or 116, 143, 258, 363
STEP 1 Turn on the TV.
STEP 2 Press the [TV] button and the [OK/SEL] button simultaneously for three seconds. The TV Device LED will turn on indicating that the remote is in the programming mode. The LED will remain on for 30 seconds and the next step must be entered while the LED is on.
STEP 3 Point the remote control toward the TV and enter the three-digit code number assigned to your brand device (codes can be found in the code tables in the user guide or online). If there are more than one three-digit number listed for your brand, try one code number at a time until your TV turns off.
Note: When the TV turns off you can verify that you have selected the correct code by pressing the [POWER] button. The TV should turn back on. Then try all of the functions on the remote control (i.e. volume, mute, etc.) to ensure you have the correct code. If any of the functions do not operate as they should, repeat the instructions from STEP 3 above using the next three digit code number from the brand list.
STEP 4 Store the three-digit code by pressing the [TV] button once again. The TV Device LED will blink twice to confirm that the TV code has been stored.
Program My Remote Time Warner Cable
Nov 13, 2014 | Proscan 19 In. 720p LED HDTV/DVD Combo...
Tip
How to connect the iphone with wifi ( need routeur wifi)
just follow the instructions step one:
Click settings
step two:
click wifi
step three:
activate wifi and wait
step four:
to press on your network
wifi enabled
on Oct 05, 2010 | Cell Phones
Hello, I need the instructions for Amazing Amy Doll...
The doll has a sticker sewn into her back that has the reset instructions in three steps. It also tells you what to do if a playpiece is lost and there is an Amazing Amy Helpline phone number: (888) 675-2368
Nov 14, 2010 | Toys
The computer shut down and the LED blinks three times, it sounds like the Convergence IC's is this correct? But I can not find it and I open the back cover. Is this something easy to fix or do I need a...
3 is short protection, 95% Chance the chips are bad.
I can tell you how to prove this and I have start to finish, step by step instructions for the repair.
SD TECH
Sep 30, 2010 | Panasonic PT-53X54 53" Rear Projection...
Why doesn't paper feed after "print" instruction? Printer merely makes a mechanical noise and states "paper out" condition.
Hello.
There are lots of reasons why this would happen:
Foreign object (could be very tiny)
Any power lights flashing ?
Paper feed rollers may need cleaning - try (from Canon Support):
1. Ensure that the printer is turned on. If any paper is loaded in the printer, remove it.
2. Select which roller to clean, the auto sheet feeder's or cassette's, by pressing the <Paper Feed> switch on the printer.
3. Hold down the <Resume/Cancel> button; when the Power lamp flashes green three times, release the button. The paper feed roller will rotate as it cleans itself.
4.. Repeat step 3 twice.
5. Load three or more of A4 or letter sized plain paper in the auto sheet feeder or cassette, as selected in step 2.
6. Repeat step 3. The paper that is loaded in the printer will be fed through the printer and ejected.
7. If printing problems persist, repeat step 6 up to three times.
Could be a hardware error and the printer would need servicing - still under warranty ?? If so, return to Canon for repair or replacement.
Hope this helps.
Jul 05, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
I need a diagram of how to set up the analog converter box or instructions.
I am posting the instructions of how to set up the analog converter box :-
Hope it will you.
· Things you’ll need:
Analog TV, antenna, two coaxial cable, and converter box
· Instructions:
Step 1
Unplug coaxial cable on the back of TV "antenna in" (RF) port
Step 2
Insert coaxial wire into the "antenna in" on the converter box
Step 3
Use second coaxial wire and plug in the converter box, "out to TV" port. Plug the other end into
“antenna in" on the TV
Step 4
Power on the converter box and TV. Change TV channel to 3 or 4. Follow on screen instruction to
Complete setup.
Step 5
After setup you will begin to see more channels than before with better clarity. Some stations will broadcast two or three channels. Enjoy
Please let us know if that was helpful enough.
Good Luck & Thanks,
Shiv.
Aug 18, 2009 | Televison & Video
Tv wont turn on
Thats the classic sign that your flyback need sreplacing, very easy repair . You need flyback number 259296 you can get a replacement with free step by step instructions on how to replace it yourself at the following link.
http://servicemanuals.vstore.ca/
Aug 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv won't come on
you need to replace the flyback. You need flyback number 259296 you can get a replacement at the following link with free step by step installation instructions.
Aug 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Will not turn on
I have a 1999 chevy lumina LTZ and i change the battery after that my cd player locked asking me a code so can u please help me how to unlock the code. Thank you
Search the net for "Delco unlock codes" OR "Delco security codes" you should easily find a set of instructions telling you to get a code from your radio and then call an 800 number. Follow these instructions. This will give you the factory unlock code for your stereo. Worked for me and for heaven sakes don't pay anybody for this information - it's free.
Aug 04, 2008 | 1997 Chevrolet Lumina
Televison & Video Logo
16 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
