Question about Lifan LF188FBQ 13 HP OHV Recoil Start Engine
Lifan 13 hp engine electrical fault
As the engine was running on full revs the flap in the carb was shut and the engine backfired and it made a loud band; all seems ok mechanically turns over with compression and inside ohv cover valves seem to operate normally; i have no spark been told maybe magneto armature, coil or spark plug how do i check in reverse trace thanks
  • Rick Legault Sep 15, 2013
    electronic ignition system !
  • Rick Legault Sep 16, 2013
    Wont start ,took spark plug out few spark s one or two then nothing
2 Suggested Answers
  • 5370 Answers
SOURCE: Lifan 50cc scooter not starting.
It requires three main things to start the scooter:--- 1)Gas. 2) Spark. 3) Cylinder compression.---------- Any of the one is not functioning right so scooter is not starting.------------ Its possible that gas is not flowing till the carb and that is causing the problem.Either gas valve is clogged or faulty.Or gas line is clogged or carb itself is dirty and gunked up inside and needs to be cleaned.--------- Click this link below and follow the troubleshooting :--- http://whatisbyme.blogspot.com/2011/08/lifan-50cc-scooter-not-starting.html ----------- This will help.Thanks.Helpmech.
Posted on Aug 18, 2011
Is this unit has the same wiring diagram and electronic parts?i have a zongshen 250 vtwin 2003 model
are you fitting the correct pluge some twins run differant plugs in cylinders, have the carbs stripped and cleaned and balanced, clean out the petrol tank and fill with fresh fuel.
Jan 24, 2014 | 2008 Lifan Delta 250 V Twin
Hi , i bought a lifan lf 125cc 14f. the man i got it off said it cut out on his mate and has been sitting for 8 months since and never got round to looking at it . i got it home and started working at it...
backfiring through the carb sound like a timing issue, odd though, should me an automatic adjustment, may have slipped a tooth on the cam witch may indicate a bad timing chain or chain tensioner/guide, May also be a serious carb adjustment is required.
Oct 23, 2013 | Lifan Motorcycles
My Yardman 13.5 hp Briggs rider revs up and sputters, revs up and sputters.
Does this engine have overhead valves. If yes they need to be checked for proper valve clearance. The engine must be cold to check this.
Sep 24, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
Hard to start then backfires through carb
Backfire through carb often means timing too advanced.
Mar 13, 2012 | 1993 Harley Davidson XLH Sportster 883...
Craftsman lawn tractor 917.271060w/kohler 15.5 hp engine cranks but backfires thru carb and wont start.
my 15 hp kohler engine backfired while i was using it, now it wont crank and backfires thru carb
Oct 10, 2010 | Craftsman Garden
I have a briggs and stratton 14 hp ohv engine on my murray lawn mower it starts and runs good until i go to full throttle or engage the blades then it seems to flood out and start backfiring i can lower...
It sounds like you are putting it into choke mode. The choke is usually all the way up on tractors. And it will make it backfire and flood out. Just rev it high enough to work and don't go into the choke mode. hope this helps.
Apr 21, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
My engine revs on high by itself and runs rough
we had the same problem with our snowblower. we tried everything. ponits, adjustments. even converted points to electronics. we ened up putting on a brand new carborater and it runs great now. save youself the headaches and buy a new carborator. we spent $87. so much better
Dec 30, 2009 | Sport & Outdoor - Others
Choke needs to stay on and engine backfires when
COULD BE A CARBARATOR PROBLEM
YOUR PROBLEM IS CALLED ENGINE RUN ON OR DIESELING THIS HAPPENS WHEN YOU TURN OFF THE KEY AND FUEL IS STILL BEING PUMPED INTO THE CARB. COULD BE DIRT UNDER THE NEEDLE VALVE FOR THE FLOAT
Aug 10, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Engine runs like POP-POP-POP.Fuel solinoid?
Hi..my name is Keith...this is kind of a hard one to answer...when im not there...but i would suspect weak fuel..i would drain the tank and put fresh in and a new fuel filter..and if that dont help..then you might need a carb cleaning or overhaul..i hope this has helped..if not..write me back
Jun 28, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Lifan LF188FBQ 13 HP OHV Recoil Start Engine Logo
78 people viewed this question
Top Lifan Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Lifan Electrical Supply Expert? Answer questions, earn points and help others
