No power to tv after I moved it - Televison & Video
  • 8,617 Answers
Very common problem what happens is weak capacitors on the power supply completely discharge when the set is unplugged then when its plugged back in they weak caps cant recharge properly and the set wont power up. Replacing the bad caps should solve the issue in most cases.
Posted on Dec 11, 2012
No power,moved tv and no power
You probably have some capacitors on the power supply board that have gone bad. When they do... the TV will not re start.
Jan 28, 2014 | Panasonic Viera 50" Class 1080p Full HD...
Moving abroad
you would need a power converter Europes power runs on 50hz power were the u.s. uses 60hz if you plug your tv in in Europe you will damage it without a converter
Apr 27, 2009 | Televison & Video
No power in surround sound system(DVD/subwoofer)
The key could be the word "move".
Electrical items can get knocked moving and something might have become loose or damaged inside the sub. So check it out. Inside too!
Feb 28, 2018 | JVC TH-C3 System
Power cord
you would need a qualified tv personal to re- insert the power chord
Jan 20, 2009 | RCA 27V530T 27" TV
Samsung hl-r4667w needs power cord reset to turn on
How much was it moved? It could have jiggled something loose or made an intermittent connection, try removing the bulb/lamp and put it back in to reseat it, it might be detecting a lamp issue due to a bad connection, or a lamp thats starting to fail, if you have a spare lamp you can try replacing it. If thats not it then it may just be something is failing due to age/heat in the tv and moving it caused enough shock to the part to go intermittent. Most commonly when a projection tv does this its a problem with the lamp, or the power supply board.
Jan 02, 2018 | Samsung HL-R4667W Rear Projection...
Power
the tv probably has a loose solder joint or broken or cracked circuit board due to moving
Aug 13, 2008 | Mitsubishi VS-55707 TV
TV with not power up
If it worked prior to moving and not when delilvered, I would take the back off and look for either physical damage or a loose plug.
Jun 29, 2008 | Emerson EWL20D6 Television
Sony Trinitron color TV model no. kv-27v22
dear, you can check that transformers out put before connecting to a tv. also when its connected to a tv.
get a avo meter and connect in series with a tv.
observe the current on the intial switch on and when the picture goes. if you notice that current on intial switching is high and then it starts going lower and lower, then change the transformer.
but if the current starts going up from the intial current then check the power supply components of the tv.
thanks for asking fixya.
Mar 02, 2008 | Sony KV-27V22 TV
No power
since the only thing you did was move the tv i would say you have a loose solder connection inside the set. you can unplug everything from the tv and unplug it from the wall for a couple of hours. see if that helps
Dec 13, 2007 | Sylvania 6632LG 32 in. LCD HDTV
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
