Need replacement usb cable for buffalo ministation HD-PF500U2/BK
  • michael42655
    michael42655 Dec 13, 2012
    No more info on what I need. However, the responses below have nothing to do with purchasing a replacement USB cable.
3 Suggested Answers
  • 4 Answers
SOURCE: apparently i need to reboot my BUFFALO &
Apparently -- if you don't know how to reboot -- you should perhaps ask some computer wizard among your friends for advice.
You don't reboot a hard drive (or any other device), you reboot THE COMPUTER. Which means you shut it down and restart it. During the startup process (which is synonymous to "booting") the computer checks all its internal interfaces and external sockets, takes an inventory of all devices and checks if they work properly.
Posted on Sep 24, 2009
  • 10406 Answers
SOURCE: When i connect Buffalo Mini
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files.
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Posted on Nov 11, 2010
Formatting buffalo ministation stealth for mac
Probably the software could not recognize or support the disk type/model
Dec 18, 2013 | Buffalo Technology 1tb Ministation Stealth...
HD-PE500U3/BK-EU does not work
Compatible
Windows 7 (32/64 bit), Vista (32/64 bit), XP (32 bit), Mac OS X 10.4 or later (*2)
You could download and use TrueCrypt. It's free and has very strong encryption. http://www.truecrypt.org/
Jan 01, 2013 | Buffalo Technology Buffalo MiniStation...
Buffalo ministation not auto-playing or showing in my computer
i have exactly the same problem with HD-PCU2 500gb ministation (Buffalo). i have also gone through the solution given by John Adams. i cannot find the device in disk management, therefore i cannot format the device...is it going to work again..please help
Sep 03, 2012 | Buffalo Technology Buffalo MiniStation...
I can't Open my External Hard Disk Buffalo HD-PXT320U2/W-AP .. How can i solve this problem .. ?? The Interface view I/O Error Device .. Thamls for yOur hElp ..
I/O Error Device means that the pc cannot communicate with your external HDD - either the USB cable is broken (replace it) or its control board has failed. If it's the latter then the Buffalo is dead, get a new one.
May 24, 2011 | Buffalo Technology 320GB MINISTATION TURBO...
Will Buffalo Model HD-PE250U2 work with Windows 7 OS? Regards sandra
Yes, it is a "plug-and-play" device, and Windows XP/Vista/7 support "plug-and-play" devices.
Dec 31, 2010 | Buffalo Technology (HD-PE250U2/BK) 250 GB...
When i connect Buffalo Mini Station HD-PF500U2/BK-AP to my laptop, the green signal blinks with beep sound and thereafter, the device is not detected. How can i solve this problem. I have important...
* the USB cable
* the power-adapter
Nov 11, 2010 | Buffalo Technology 320GB MINISTATION TURBO...
External Buffalo Hard Disk 500 Gb model no HD-PF500U2/BK-AP not detecting when connnected to a laptop or a desktop PC
Check the usb port function in the computer bios settings and be sure that it is set to yes. Connect properly your external drive. If it has two wire usb connections, use both to obtain the maximum power that will be need by your drive.
Dec 18, 2009 | Buffalo Technology 500GB DRIVESTATION...
Setup Process
no need for installation whatsoever for this kind of drive. just plug it in, and its ready for use... but i suggest not to move or even touch the standard folders inside it. rather, make a separate location for the files you are going to save in it. i hope it helps..
Sep 01, 2008 | Buffalo Technology 250GB MINISTATION TURBO...
Computers & Internet Logo
147 people viewed this question
David Payne
David Payne
