Question about Homelite Garden
What is the gap between magneto and flywheel,homelite,super ez chainsaw
  • Homelite Master
  • 2,239 Answers
0.3mm is a pretty standar air gap for most machines
Posted on Dec 11, 2012
3 Suggested Answers
  • 2239 Answers
SOURCE: have a 16" Homelite super
Air gap 0.3mm and plug gap 0.5mm
Posted on Apr 21, 2011
dontbother10
  • 2220 Answers
SOURCE: magneto to flywheel gap for Husqvarna 455 Chain Saw
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 22, 2010
How do I get spark
Make sure the magneto is not grounded and make sure the air gap between the flywheel magnet and magneto is set to specs. If air gap is too wide, it will be difficult for the magneto to produce an efficient spark.
May 07, 2014 | Poulan PP5020AV 20 in. 50cc Gas Chainsaw
Brushes sparking too much
Homelite Chainsaws have no brushes that I know of. Maybe it is not that. It could be a short in the magneto coil wire that goes to the switch.
Check to see if anything is shorting out under the flywheel cover.All the way back to the switch.
Feb 27, 2014 | Homelite Consumer Products 9.0 Amp, 14 In....
Not getting spark to plug on eagerbeaver 2014
Jeffuxum:
The magneto is probably where the problem is. You'll need to pull the cover off of the motor and check the gap between the magneto and the flywheel. If the bolts holding the magneto have vibrated loose, the gap between the magneto and the flywheel will be incorrect. While you have the motor cover off, check the wiring to make sure you don't have a short in your ignition wiring and clean the air filter. I don't remember what the gap is between the flywheel and magneto, but .010 In. sounds familiar. Both legs of the magneto should be the same distance from the flywheel and they must not touch the flywheel at any point. I have used a matchbook cover between the flywheel and magneto while I tightened the magneto retention screws and it worked.
Jan 18, 2013 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Need to set magneto gap on homelite super xl chainsaw model UT10045c
Hi, 8 thou is the correct gap. Hope this helps, regards Phil.
Jun 15, 2011 | Garden
Have a 16" Homelite super
Apr 21, 2011 | Garden
My Stihl ms361c won't start. Want to check air gap on the magneto.Re-set the timing.How? do I do this?
Pull off the side cover where the cord is.Make sure the keyway in the flywheel is not broke and flywheel has not turned.If flywheel did not turn the timing is fine.Too set the air gap you have to loosen the screws on the magneto .Slip a piece of paper or metal that is .010 thick between magneto and flywheel and turn flywheel until magnet pulls magneto down.tighten screws and reinstall cover.
Nov 29, 2010 | Husqvarna Garden
What is the air gap for my magneto on my 25cc homelite weeater?
Should be around .013 to .014. turn flywheel until magnets face magneto insert your feeler gauge and loosen magneto screws...let the magneto stick to the feeler gauge and the magnets... re-tighten the screws, remove feeler gauge, and you should be set...hope this helps. ;-D
Jul 06, 2010 | Homelite Mighty Lite Lawn Trimmer
Magneto to flywheel gap for Husqvarna 455 Chain Saw
Ignition module gap
Lou
Mar 22, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I NEED TO KNOW THE SPARK PLUG GAP AND MAGNITO GAP FOR A POLAN CHAINSAW MODEL # 2375
Spark plug gap is .025
As for the air gap in-between the flywheel, and magneto, I generally start with a piece of notebook paper in-between them.
After the bolts are snugged down, turn the flywheel by hand to spin the paper out.
Oct 29, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
205 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
