Question about Sharp AR 163 Copier
Half picture when making copy in A4
I can not copy the full picture at A4 format What can be the cause
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
A4 is not a US size if you choose A4 the paper must be that size--
US uses Ltr-- Lgl and 11X14.
Posted on Dec 11, 2012
2 Suggested Answers
rezazadeh
  • 328 Answers
SOURCE: when copying it randomly makes a loud noise and
see scan connector care fully and give me a good vote
Posted on May 29, 2010
MY hp laserjet 200 color m251 pcl 6 do not print full copy of A4 when printing via internet or wireless pls, i need a setting to make it print full copy . thank you.
I would check to ensure that the page size of both the driver and the printer are set to A4 and not letter. Most HP's will auto sub letter for A4 but if driver thinks paper is letter when it is actually A4 then the printout will not match.
Sep 16, 2016 | HP Color LaserJet Pro 200 M251nw
I have a Nikon D3100 camera. Recently there is a black band at the top part of my pictures, about 1/4. This happens every other picture. It almost looks like the shutter does not open properly every other...
You apparently are shooting in both jpg and raw modes. I do that. So what you have is actually two pictures. The jpg picture is full screen and the raw (nef) picture has the black lines you describe.
I don't know why it does this other than to allow you to recognize which pictures is raw and which is jpg. It is not a problem and picture quality is not impacted in any way.
Your manual should explain fairly clearly the benefits of both formats. You can use the menu to change it to take only jpg or nef pictures and possibly other formats.
When I edit photos, unless I'm in a hurry, I usually make a copy of the NEF photo and edit that. You can make many more changes in an NEF photo than you can in a jpg photo.
In either case, I would suggest you always edit from a copy to protect the original. I think my D-90 allows the use of other formats in addition to jpg, but nef is the only raw format that Nikon uses.
Aug 31, 2013 | Nikon D3100 Digital Camera
How do I empty a full card
Loading the pictures onto your computer simply copies them, leaving the originals on the camera's memory card. To clear the card, format it in the camera by using the format command in the recording menu, as described in the "Formatting a CF Card" section of the manual (page 83 in my copy). If you need a manual, you may download a copy here.
May 26, 2012 | Canon PowerShot A10 Digital Camera
Sir i face problem in di 650,i place original
Sir,
Do you have the paper selection in AUTO? Mite you also check your defaults settings
Feb 20, 2010 | Minolta Office Equipment & Supplies
I making copy 50 percent at half a4 paper by stack bypaas but print is cut at upper
More than likely you have just installed that paper into the paper cassette . . . am I correct? Anyways, if so then you may not have selcted the correct setting on the dial which is in the paper tray. You might have set it for A4 instead of A4R (reverse direction) or the other way around. The other thought is that the paper guides in the paper cassette are not snug up against the paper itself thus causing the paper to be positioned incorrectly in the paper tray. Good luck and repost if I was wrong about that.
Dec 17, 2009 | Canon imageRUNNER 2200
Copy enlargement A4 to A3
in reduction and inlargement mode choose custom and set scale 141% and place the a4 picture horizentally on the copy board glass.
Feb 27, 2009 | Panasonic Office Equipment & Supplies
Epson stylus photo rx420
Move envelope/A4 lever near paper output tray until the letter L registers on display. Print in this mode and you should have full page printed.
Jan 21, 2009 | Epson Office Equipment & Supplies
Canon PC940 Ticking noise when copying and regestration is off
The waste toner is in the drum unit it's self. If it full you may as well replace the drum unit all togather. Once it is full the drum is just about shoot. If the regestration is off, you may have a problem withe reg. feed clutch. Dose it show up with the paper tray and the manual feed try?
Nov 15, 2008 | Canon PC-940 Black and White Copier
Lost pics
If you mean on the camera, it would be best to copy all pictures with a card reader (the reason is that the camera may not be able to copy corrupted files) and then look through them on the computer. It is possible that file corruption has happened. If that is the case, then you may have to rename them, if the name has changed. What is important to remember is that the file extension has to be .jpg or .JPG for normal pictures in most cameras, there are other file extensions used for larger and other format cameras. The rest of the file name is not that important, unless it means to have your pictures in order.
Also make a copy of the files affected, and rename them with a b or 2 or some way to tell the difference from the other originals.
If you mean on the computer, then make sure to look in the trash folder. If you do not find any files (note as above in the other notes) which have changed names or they are not there, and not in the trash folder, then something else has happened.
This kind of thing can happen if the camera is turned off before the files are written fully to the camera's memory. It cannot save, and thus the camera may not write anything at all to save the picture.
Another thing which you may want to look for is if the pictures could be in the internal memory and not on the card. Remove the card, and start the camera again, if the camera has internal memory. Some cameras have no internal storage ability.
If the pictures were deleted, there is no way to recover them.
As a precaution to preventing this kind of thing, always format the card you are going to use in the camera. Don't change the card to another kind of camera without reformatting it for use in the other camera. If you use a card formatted in another camera, it can cause not only very slow saving, but it can also cause corruption or deletion of files.
As another caution to remember along this line, copy your pictures often from the card or camera and don't let the card or camera get too full, so that you cannot save any more pictures or movie files. If the camera's memory or the card is too full, the camera has no way too save the files, and may cause corruption or other unknown problems. Usually a message will come on the camera's LCD that the camera's memory or the card is too full and cannot save any.
Jun 22, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
61 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
