Question about Brother MFC-8860DN Printer
How to Reset the page drum count on Brother MFC-8860DN
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
Open door
remove drum and toner unit
remove toner from drum push on blue tab on side to release
reinsert new toner in drum
reinsert unit in machine
leave door open
hit clear/back on panel --- says new drum-- hit yes
says accepted
close door
Posted on Dec 11, 2012
3 Suggested Answers
SOURCE: reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Posted on Mar 16, 2008
  • 59 Answers
SOURCE: Problem for Brother MFC-8860DN Printer How do i
press menu 7 3 2. this will bring you into the parts reset, and reset the fuser
Posted on Mar 31, 2010
MFC BROTHER 8860 DRUM RESET
REMOVE THE DRUM AND AND INSERT A NEW DRUM, THAT IS THE RESET
May 02, 2014 | Brother MFC-8860DN All-In-One Laser...
MY BROTHER MFC-8860DN IS LEAVING "GLOBS" OF TONER ON THE SHEET WHEN IT PRINTS. CAN THAT BE FIXED?
Hello. this error is caused by the "drum". the drum can be replaced either through Brother or your local office supplies store.
There is no quick fix for this issue.
Regards GM
May 30, 2011 | Brother MFC-8860DN Printer
Brother mfc 8860dn, what is the difference between drum and toner.
On this machine the toner cartridge is installed into the drum unit so they are separate units. After opening the front door you can lift and then pull out the toner cartridge/drum unit assembly. There is a blue release lever thet is used to release the toner cartridge from the drum unit. As far as the difference? Well the toner cartridge contains the toner, and the drum unit contains the drum as well as other parts that make up the print "process". The toner is good for about 5,000 pages while the drum unit is good for about 18,000 pages. The drum unit life indicator can be reset to get additional life from the drum unit. To do this, open the front door and leave it open. The press the clear/stop key, then press 1
Good Luck and Thank You for using Fixya.
Sep 11, 2010 | Brother MFC-8860DN All-In-One Laser...
BROTHER MFC-8860DN EVERY TIME I PRINT TWO DARK LINES PRINT ON EACH SIDE OF THE PAPER?
I had a similar problem but it was only one dark line on the right side of each page. I just changed the drum while keeping the same toner and the problem is gone.
Dec 11, 2009 | Brother MFC-8860DN All-In-One Laser...
Problem for Brother MFC-8860DN Printer How do i reset fuser count after replacement
Nov 21, 2009 | Brother MFC-8860DN Printer
Poor print quality from Brother MFC-8860DN
Replace the drum. The drum is failing.
When you replace the drum open the front door of the machine where thr drum and toner is.
Hit the clear/back button. Press 1
That resets the drum count after you replaced the unit.
Nov 12, 2008 | Brother MFC-8860DN Printer
Print problems with brother MFC-8860DN
Brother mfc8860dn copier
Open front cover with power ON
press set
read display....
choose change drum and yes/ok
close cover
will reset bias voltage aka light copies, to suit new drum
Jan 11, 2008 | Brother MFC-8860DN All-In-One Laser...
Reset drum - brother mfc-8860dn
Open front cover
Press Clear/Back
Jan 06, 2008 | Brother MFC-8860DN Printer
Brother MFC-8860DN Printer Logo
487 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
