Question about Toshiba Televison & Video
Replace remote sensor on toshiba 32HFX72
Model 32HFX72
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
Aside from getting the part which is soldered in you will have to get the set apart and likely slide the main board out of the set, careful there.
Should only be for this four solder connections, a few have five and some will be for the metal often used to support the part.
So you have an idea what a typical one looks like see attached photo:
replace remote sensor on toshiba 32HFX72 - 12_11_2012_8_31_20_pm.jpgThey have to be right up on front of set somewhere so remote can send signal to them thru a plastic lens either clear or a dark color--signal is infrared.
Posted on Dec 11, 2012
Does my Toshiba 32HFX72 have a digital converter? My Cable is not longer working. I live in the Ottawa, ON - Canada region and it has switched to digital broadcasting. Thanks
Hi Julia.
Unfortunately, your tv does NOT have a digital tuner built into it.This means that you will need to get a digital converter box in order to receive station broadcasts.
Luckily, places like WalMart Target, Kmart and Radio Shack all carry digital converter boxes that aren't expensive.
Most run in the $30-$40 range, so you won't be out alot of money to get one.
I hope this answers your question, and have a good day!
Jun 06, 2011 | Toshiba 32HFX72 32" TV
The remote cannot turn the TV on or off, not a battery problem.The remote from the cable provider cannot turn the TV on or off. I feel like when I was a kid and have to do this manually. Is this a...
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Regards.
Jun 01, 2011 | Toshiba 32HFX72 32" TV
No replacement remote is working. do I need a special remote for this tv?
yes you do. if you want all functions to work you the original remote and it will cost you. I had a pioneer TV that you could not adjust the color unless you had the original remote. if you contact Toshiba they will send you one for $90 to $120
Jan 22, 2011 | Toshiba 32HFX72 32" TV
I have a toshiba universal remote model ct-90121. I need the program codes and programing instructions for an rca tv
According to Toshiba, the CT-90121 isn't a universal remote control. This remote only works with TOSHIBA TVs with the following model numbers:
32AFX62, 32AFX63, 32HFX72, 34HDX82, 36AFX62, 36AFX63, 36FX72, 36HFX72, 42HDX52, 42HDX82, 50HX70, 57HDX82, 57HL83, 57HLX82, 65HDX82, 65HLX83
Unless you posted the wrong remote model number (?) your Toshiba remote isn't going to work with your RCA TV.
Please rate this solution if you find it helpful. Thanks!
Nov 02, 2010 | Toshiba Televison & Video
No power to TV - No Screen - No sound
check the fuse, I found my had blown and that's what it was sort of. Light doesn't flash any more but nothing comes on
Aug 10, 2009 | Toshiba 32HFX72 32" TV
Toshiba CF32H50-no control from remote
Could be the remote does not operate on the correct frequency, but also may be the IR reciever sensor inside the TV, best bet is to bring your remote to a pawn shop and try it on a set there (they sell older model sets look till you find one like yours). once you determine the remote is OK, check the IR sensor for bad solder connection or replace it by soldering a new one in. Also some Toshibas develop micro CPU issue (the computer IC), another thing you can try is cleaning the main board control area with electrical cleaner residue can load down the control circuits but then the buttons would also malfunction.
Aug 01, 2009 | Toshiba CF32H50 TV
TOSHIBA MODEL 32A42 will not work with remote
so does't mean the sensors working do you get anthing on the middle lead ? Thats the one that sends the data to the uP.
Apr 14, 2009 | Toshiba Televison & Video
No picture or sound
Looks like a power supply issue the only solution to fix this up is to get it repaired.
Goodluck..
May 03, 2008 | Toshiba 32HFX72 32" TV
Remote controls will intermittently work
Hey, I would definitely recommend trying all the options mentioned above however sometimes it might never work correctly again (the remote control that is) and it might've been a defective remote control to begin with. Anyways, I had a few friends that have been in similar situations, and usually they won't even bother and went on the internet to find a replacement remote control. What they have done and probably what I would do if I was in that situation is head on over to a replacement remote control website like EveryTVRemote.com and look through their directories for that specific model Toshiba 32HFX72, and they should have what you are looking for in stock!
Dec 06, 2007 | Toshiba 32HFX72 32" TV
Toshiba model Cx36H60
Yes, I have been seeing a lot of those Toshiba IR receivers bad lately. Replacing it with a new one should take care of your remote problems. If you have never replaced small parts on PC boards then have a qualified tech handle it for you.
Aug 09, 2007 | Toshiba CX36H60 TV
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
