Question about Haier HNSB02BB 1.7 cu ft Compact Refrigerator
Troubleshooting problems with haier mini fridge hnsb02bb it clicks on and off every 20 seconds and it doesnt get cold
  • Haier Master
  • 4,655 Answers
Feel the compressor top Kim. I need to know if it is too hot to keep your hand there. If yes it is too hot then unplug untill someone can perform the test listed below. If there frigerator compresasor pass that test it will be safe to replace the start relay=> RF-4800-48 Start Relay or here=> RF-4800-48 There are no photos of the overload start relay and the part installs under the cover on the side of the compressor.
Unplug the refrigerator and remove the back panel that covers the compressor. There should be 3 wires going inside the cover of the compressor. Mark all 3 and mark their location so if compressor is OK you can put them back in same order. The plastic cover may snap on and you may need to squeeze the sides to unlock the cover and sometimes there is a metal clip holding the cover in place. Remove the cover. May look hard but it's simple. There will be three connections under the cover and 2 will go through the start relay. Unplug them leaving the three prongs exposed. They may be marked R =Run, S=Start and C=Common. Set your meter on continuity and then begin by testing 2 at a time until you have checked S to R and R to C an C to S and S to R again. You should get a reading all the way around. If no reading between any of the pairs as you go around you should get no reading between any two the compressor has an open winding and is defective. Then if it passes that test then touch one probe to R and the other to the copper pipes or clean metal on outside of compressor, then S to metal outside and C to metal outside. If you get a reading this way even just a little. The compressor is a burnout. Then let me know what you find. Thanks, Sea Breeze
Posted on Dec 12, 2012
Haier troubleshooting
Does it have cooling coils in the back... or underneath... that might need to be cleaned and vacuumed out???. That is a common problem.. Another thing, check to see if the door is sealing properly.. The next suspect might be the temperature adjustment mechanism that you've been adjusting..
Aug 07, 2014 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
Igloo mini fridge not getting cold
The compressor may be frozen. Turn off the fridge for 6-8 hours, then turn it back on. Don't turn the temp to the coldest setting. If it will still not get cold, the compressor is probably bad.
Jan 22, 2014 | Igloo Cooler Igloo 4.6 cu. ft....
To cold
Try 2 switch off (plug out) leave it few hour then switch on (plug in) again sometime it just error.
Dec 04, 2012 | Haier Refrigerator Fridge Personal Mini...
Freezer sounds like it's running, but doesnt get cold
Hi,check that the thermostat is set correctly,if so the it could be the compressor has gone down.
Nov 13, 2012 | Haier Freezers
Sides of Haier Compact Fridge are very hot to the touch
On some small units such as this, the condenser coil is actually in the walls of the cooler. It is not that unusual for this type of construction. I have seen this in chest freezers and other such units. If the unit makes the desired temperature, I would watch it for a day or 2 before putting any product into it to ensure it is okay and so you don't loose any product.
Sep 06, 2017 | Haier HNSE045 4.5 Cu. Ft. Capacity Compact...
We get clicking noises when water is dispensed. also the fridge compartment is not cold at all - the freezer is working (at the moment). model SB540W/SAL2027GBB. Service code 85951051500 / 110738001758....
the clicking sound is normal it sounds like valve operating or you may have the water pressure up to hgh for the unit. for your second problem is the fan operating inthe fridge this stops the cold air to transfer from the freezer, also check the operation of the damper this is the flap the controls the amount of air into the fridge this is uasualy controled by a by metalic thermostat or motor. thirdly which mostly common is the defrost heater is not working signs are frozer evaperator in freezer and air duct the checks are defrost timer, heater element terminatinion thermostat and someunits have thermofuses goodluck
Aug 23, 2010 | Whirlpool Freezers
DEFY C361 Double door fridge that does'nt get cold
We solved this by replacing the thermostat with a new one.
Sep 11, 2009 | Freezers
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
Hello, my daewoo fridge freezer has stopped working. The light comes on & it sounds normal, any suggestions?
SOMETHINGS LIKE THAT YOU CAN UNPLUG FOR A WHILE THEN PLUG BACK IN AND THEY WILL MAGICALLY WORK AGAIN, I GOT A NON WORKING MINI FRIDGE FROM CRAIGSLIST AND THE GUY SAID IT DIDN'T GET COLD, SO I ASKED HIM SOME QUESTIONS ABOUT IT AND HE ANSWERED THEN AND I ENDED UP TAKING THE FREE MINI FRIDGE HOME , ALL I DID TO MAKE IT WORK AS UNPLUGGED IT FROM THE WALL AND CHECKED ALL THE CONECTORS ON THE BACK NEAR THE COMPRESSOR, I DID THAT THEN PLUGED THEM BACK IN AND I HEARD THE COMPRESSOR START TO KICK ON AND WAS LIKE YES AND NO I HAVE A GREAT LIL MINI FRIDGE TO KEEP SODA FRESH AND CHILLED , SOMETIMES I GET A POP TO EXPLODE IN THE FRIDGE BECAUSE IT IS SO COLD INSIDE
Jun 25, 2009 | Freezers
Haier HNSB02BB 1.7 cu ft Compact Refrigerator Logo
196 people viewed this question
Top Haier Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Charles T Nevin
Charles T Nevin
christian nielsen
Are you a Haier Freezer Expert? Answer questions, earn points and help others
