Question about Fujimi 124 Toyota Lexus Is200300 4 Door
I have a 2000 is200 lexus that has lost power and is heavy on fuel
Where is the starter motor location on a lexus is200 2000 model
most rear wheel drive cars have the starter on the gear box some where check google images there is bound to be a pic on there some where
Mar 29, 2015 | Lexus IS Cars & Trucks
Trouble code p1755
linear solenoid lockup control malfunction,98 GS300
May 29, 2014 | 2000 Lexus Gs 300
My car 2001 lexus is200 has no power in the ignition, dashboard and interior
Fusible link directly off battery? Usually on the positive cable. Feel the wire if not visibly burnt or broken, Use fingernail tips and "feel" for the break. Also relays in the relay box, some are same as ignition, power sources ect. Can take off wipers or some other relay that is not essential and test.
Mar 23, 2014 | Lexus 1999 2000 2001 2002 2003 Is200 Is300...
How to get more low end power from lexus is200 auto
have a talk with the service centre for lexus vehicles and see if you can have the cpu reprogrammed to give more fuel at a lower rpms. failing that you may have to have a new chip fitted at a speed shop and have it reset to what you want.
Mar 31, 2013 | Lexus 1999 2000 2001 2002 2003 Is200 Is300...
Tighten power steering belt is200
My standard answer for this type of question is that you should purchase a haynes or chiltons manuel for your vehicle, you will find a lot of very good info about many things as well as tips for repairs that will save you time.
These can be purchased from most auto supply stores or for a little less money on ebay.
Mar 21, 2013 | Lexus 1999 2000 2001 2002 2003 Is200 Is300...
Handle mechanism for lexus is200
The rod should have a plastic clip on the end to attach it to the door parts inside the door it should attach by the rod coming from the inside handle
Feb 09, 2013 | Lexus 1999 2000 2001 2002 2003 Is200 Is300...
Fujimi 124 Toyota Lexus Is200300 4 Door Logo
23 people viewed this question
Top Fujimi Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Fujimi Toy Expert? Answer questions, earn points and help others
