Question about Dryers
Beko DCU 8230 Condensor Dryer water tank full warning light comes on
Just installed my Beko condensor dryer, started the machine and it only goes for a minute then the water tank warning light comes on and the machine stops. There is no water in the tank, as it has just started, when we reset the machine it starts again and the same thing happens. I have checked the condensor filter, door is shut, cant see a problem.
3 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: Beko DCL 1560 condensor dryer. After starting the
Hi
I believe the that everything else is fine rather it is the thermostat that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if bad replace it as it cannot be reset. Hope this helps...please post back for further assistance.
Dan
Posted on Feb 25, 2011
Daniel S
  • 4323 Answers
Hi
Daniel
How do I replace the small belt in a beko dcu 8230 condenser dryer
I'm not familiar with this one specifically but typically you just need to loosen the tensioner, pry from the under side of it with a large screw driver.
Feb 02, 2015 | Dryers
Beko condensor dryer not emmiting any heat but still 'working'
Stat or heater check power if it is a 220 volt machine may have one side down on power
Dec 03, 2013 | Zanussi TC7102W Electric Dryer
Hi i have a two day old beko dcu 7230 tumble dryer the water tank and clean filter light keeps coming on even though they are clean and empty is my product faulty.
not too many dryers w water tank, but the air filter light maybe due to a lack of air movement. If you have replaced an old machine, then your problem may be with the existing exhaust and duct work, you'll need to clean them out thoroughly to know. You may have to go outside or up on the roof as sometimes these also have trap doors that become stuck.
Nov 09, 2013 | Dryers
My beko condensor dryer not heating up
beko condenser dryer not heating up any solutions
Feb 07, 2011 | Dryers
Zanussi TCE 7276W Condensor Dryer - no red lights but won't go!
Hello, have you cleaned the condensor stack just recently if so check that the stack etc is fitted correctly and the door is closed fully.
Hope this helps.
May 14, 2010 | Dryers
Water tank full (!) in bosch tumble dryer WTE86301gr
As a matter of fact I have solved the problem. The dryer is now fully functioning again. :-)
I'll try to explain how to fix the problem:
The water that condenses in the condensor (doh!) drips down into a container situated below the condensor. The moist air that passes through the condensor is the same air that circulates via the clothes, thus it also contains some lint that the filter doesn't catch. Over time there will be some build-up of lint and mucus (?), clogging the tank AND a sensor that sends a signal to the electronics to start the pump that evacuates the condensed water to the removable tank in the upper part of the machine. This messes up the function of the water evacuation system.
Alright, pull out the condensor and find a hatch in the 'floor' in the farther part of the compartment. Below the hatch you'll find the container that collects the condensed water. Start by cleaning it as thoroughly as you can. There are a few 'nooks and crannies', take your time, also flush with some fresh water and maybe some gentle cleanser to get rid of the mucus. The pump and the sensor for the pump are located in the left part (viewing from front of the machine) of the container. Try to flush there as well.
If this procedure doesn't solve the problem you'll have to disassemble the machine to also be able to remove the pump and sensor housing. I had to do this on mine. Quite a few screws to remove and keep track of, but pretty straight forward if aren't too uncomfortable with 'fixing things'.
I have some pictures of the 'project' somewhere, let me know if you would like to see them or if I may help you some other way.
BR /Hans
Mar 10, 2010 | Bosch Dryers
Asko t702c stops working after about 5 minutes
If you continue to try to run the dryer after the automatic shut off kicks-in it will shut the cycle down with no flashing lights after the dryer reaches a critical and dangerous temperature. If the dryer is skipping immediately to this step without any flashing lights then call an Asko certified repairman as something may be wrong with the machine. If you have not tried cleaning the condensor, please do this as well. Remove the bottom housing of the dyer, move the two red handle to the right, and pull out the condensor unit. Wash it under warm/hot water using a bathtub or shower and you will see lint and dust come out by the heapful. Replace the condensor unit, wait about 30-45 minutes, and then try restarting your dry cycle.
Kevin C., Asko USA.
Jun 07, 2009 | Asko Dryers
Seimans dryer txl733...incessant buzzing warning light to empty water resevoir even after emptying?
hiya
i take it this is a condensor dryer, the most likely cause of this will be the float in the recirculation pump (takes he water from the condensor unit to the bottle) sometimes these just stick and once freed they work ok, other times they will need replaced.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 03, 2008 | Siemens Dryers
Tank full light stays lit.
Under the water bottle is a drain hole,when the bottle overflows water runs down this hole through a pipe to a reservoir behind the condensor unit, there is a float in this reservoir that rises and clicks a switch that activates the full tank light and stops the machine working,
removing the stopper at the rear and emptying the reservior should do the trick,If the float does not go back down due to dirt in the machine the left hand side panel can be removed by taking off the top then the retaining screws,one inside at the top the rest in the back panel,remove the one screw holding the float switch unit and clean the black float.(Make sure it's not plugged in)
Sep 22, 2006 | Tricity Bendix TM310W Electric Dryer
Dryers Logo
531 people viewed this question
Top Dryers Experts
