Question about Zojirushi Nphbc18 10 Cup Induction Rice Cooker Warmer
Thermal resistor location - Zojirushi Nphbc18 10 Cup Induction Rice Cooker Warmer
Replace blower motor resistor 1995 Mercury Mystique
Probably connected to the blower switch. Actually it is a group of resistors in a block. BTW, there also is a thermal fuse in the resistor group that might be the cause of failure
Sep 23, 2012 | 1995 Mercury Mystique
Need to locate the motor blower resistor for my 1999 mercury mountaineer, it has dual air, the resistor for the back is fine but the one in the front is bad and i cannot locate it. Please help.
If you have a manual system, you have a resistor. If electronic, you have a blower motor speed controller. Please rate if this helps.
here is info:
Control System Outputs-Manual A/C
Blower Motor Switch Resistor
The heater blower motor switch resistor has the following features:
  • The assembly is located on the evaporator housing in the engine compartment.
  • Three resistance elements are mounted on the resistor board to provide four blower motor speeds.
  • Depending on the heater blower motor switch position, series resistance is added or bypassed in the blower motor circuit to decrease or increase blower motor speed.
  • An overheating protective device (thermal limiter) will open the resistor coil circuit when the temperature reaches 121°C (250°F) interrupting the blower motor operation in all speeds except HI.
  • The thermal limiter cannot be reset and is not serviceable.
Control System Outputs-EATC
Blower Motor Speed Control
The blower speed control is located on the evaporator housing in the engine compartment.
  • The function of the blower motor speed control is to convert low power signals from the electronic automatic temperature control module to a high current, variable ground feed for the blower motor (18527).
  • The blower motor speed is infinitely variable and is controlled by the electronic automatic temperature control module software.
  • A delay function provides a gradual increase or decrease in blower motor speed under all conditions.
Jan 10, 2011 | 1999 Mercury Mountaineer
Blower motor doesnt work
replace the blower motor speed control resistor, the thermal limiter is most likely blown in the resistor, the resistor is located next to the blower motor, see picture below, the aprt is very cheap to buy and takes only minutes to replace
Sep 11, 2010 | 1996 Ford Ranger SuperCab
Ac will not blow threw vent
The ac resistor is located on the blower motor under the right side of the dash. Looks like a black box bolted to the housing of the motor. You can check the resistor by first looking to see if the thermal limiter is still good. The thermal limiter keeps other parts of the resistor from being damaged from to much heat. If there is stuff melting from between the contacts then you need to replace your resistor due to the thermal limiter damage. If no damage then check your continuity between the terminals of the resistor withan ohm meter. These are the ohm reswistance that they shopuld be within if they are not then you need to replace resistor:between terminals 2&3 8ohms or less, 2&4 1.8 and 2 ohm, 1&4 2.3 and 2.5 ohms. If all tests passed check brown and Orange wire(positive) terminal and check for voltage. There should be at least 10 volts being supplied to this terminal (when the motor is not in off position). If there is not at least 10 volts there then the problem lies somewhere between fuse panel and ac control panel. If there is 10 volts of power and it still is not working check the ground wire(orange and black) to see if the ground wire is insufficient. I don't know if you need all that but If you do end up trouble shooting you have the info you need. I hope i helped.
Jul 26, 2010 | 1998 Ford Explorer
Where is the blower resister on a 2004 crown victoria
very unusual location. usually inside the car in the plenum case by passenger floor, but here it is:
  • The assembly is located in the engine compartment on the evaporator housing toward the center of the vehicle.
  • Three resistor elements are mounted on the resistor board to provide four blower motor speeds.
  • Depending on the heater blower motor switch position, series resistance is added or bypassed in the A/C blower motor circuit to decrease or increase A/C blower motor speed.
  • A device to prevent overheating (thermal limiter) will open the resistor coil when the temperature reaches 121°C (250°F) interrupting the blower motor operation in all speeds except HI.
Feb 19, 2010 | 2004 Ford Crown Victoria
Where is the resistor located
No resistor. You have a thermal fuse located at the front attached to the duct assembly. white plastic with 2 wires.
Jan 28, 2010 | Whirlpool LER5636P Electric Dryer
1999 grand marquis were the blower motor resistor is located
this is for manual heater system. If you have electronic (digital display) you don't have one. Instead you have a blower motor speed controller.
here is info
Control System Outputs—Manual A/C
  • An overheating protective device (thermal limiter) will open the resistor coil when the temperature reaches 121°C (250°F) interrupting the blower motor operation in all speeds except HI.
Dec 12, 2009 | 1999 Mercury Villager
Liberty HVAC blower motor only works on hi speed. No low or middle speed. Is there a relay or thermal resistor for this and where is it located?
The HVAC Blower Motor Resistor needs to be replaced. It is located in behind the glove box. You have to remove the glove box which is easily done by releasing two clips located on each side of the compartment door. Then slide the cover to the right and the cover will come right off. I just had my replaced today and it only took the garage 10 minutes to install the new one.
Sep 03, 2009 | Jeep Liberty Cars & Trucks
F150 2004 blower working only on high position.
this is because your blower motor resisters are burned out for speeds 1,2 & 3. High speed does not have a resister.
Replace the resister. If it goes a 2nd time, it is because your blower motor is failing & drawing too much current.
it is behind the glove box I think. It is in the plenum case where air blowing on it keeps it cool.
Easy repair. May need to access throught glove box which should open all the way down when you squeeze the sides in.
Go to tascafordparts.com for a discounted resister.
Please rate as solved problem if this is what you needed.
Manual Climate Control System Outputs
Blower Motor Resistor Coils 9ba1105.gif Blower Motor Thermal Limiter 47afe58.gif The heater blower motor switch resistor has the following features:
  • The assembly is located on the passenger side of the plenum assembly behind the glove compartment (06010).
  • Three resistance elements are mounted on the resistor board to provide four A/C blower motor speeds.
  • An overheating protective device (thermal limiter) will open the resistor coil circuit when the temperature reaches 121°C (250°F), interrupting the blower motor operation in all speeds except HI.
Mar 23, 2009 | 2004 Ford F150
Ps3 stuff
One of them is located next to the relay. The other is located right behind the big transformer in the middle screwed to the copper heatsink next to the three transistors.
Feb 29, 2008 | Sony Playstation 3 (PS3) Console
Zojirushi Nphbc18 10 Cup Induction Rice Cooker Warmer Logo
111 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
30yrmech
Level 1 Expert
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
