Where do I find parts for a honeywell rediline generator serial number 32020
Input 12 VDC Output 120 VAC 60 HZ 1600 Watt
SOURCE: Refrigerator totally inop. 120 VAC & 12 VDC present. Unit is model # RM3662.
Yes, I did the same thing. I had a qualified RV repairman change out the board. He also told me there is a recall on this specific issue and that DOMETIC should pay for not only the board, but quite possibly the cost of the labor to repair.
Dometic phone # is 888-803-0013
Posted on May 29, 2009
c17hydro
  • 2984 Answers
SOURCE: I need a 1988 Chevy 454 Engine Firing Order Diagram
Here's the firing order part of your question
Posted on Aug 28, 2009
  • 4736 Answers
SOURCE: I have a honeywell HZ-2000C
Either the heating element (which is like a toasters) has burned out or the On/Off Heat sensor switch has failed or needs to be reset. Try this to reset the heater. Turn The Master ON/OFF switch to Off. Unplug the heater and wait 10 minutes before plugging it back in. Turn the Master ON/OFF to ON and turn the heater switch to low setting. If the Elements heat up, you've solved the problem. If they don't heat up the heater is toast. The reason I say this, is that they are inexpensive (under $20.00), so it's less of a hassle to just replace it rather than try to repair it. Parts alone would be a bear to find.
Now, if it's still under warranty, then you can either have it repaired or replaced at Honeywells' option. You will need your Proof of Purchase to accomplish this.
Hope this helped in some way, to solve your problem.
Posted on Mar 15, 2011
  • 456 Answers
SOURCE: I got a Schumacher fully
hi.
basically, with any charger, the positive (red +ve) wire goes to the positive post.
the negative (black -ve) goes to the negative post.
Posted on Apr 04, 2011
  • 15941 Answers
SOURCE: Lenco Tuntable built for 50 Hz. I need 60 Hz! Please?
There is no cheap way to convert from 60 hertz to 50. http://www.lencoheaven.net/forum/index.php?topic=68.0
Posted on Nov 25, 2013
Coleman Powermate 5000W has HIGH RPMs until a 3KW load
This generator is less than ideal to use as a home unit. see www.advanced-power-technologies.com and look at residential videos. Basically the voltage is governed by a capacitor on your unit, and ouput is directly propertional to speed. Also the engine is mechanically governered versus an electronic system. This is a common mistake using portables to power home equipment. You will damage your home digital equipment, do not use recommended
Jan 25, 2013 | Coleman Powermate Powermate 5000W...
The power adapter is bad. What are the power requirements for this unit i.e visioneer 9220 USB scanner
Hello! You can actually get this directly from Visioneer for $19.99.
http://www.visioneer.com/products/parts.asp?PN=9220
Otherwise the power specs in the manual are here.
Power supply Input voltage/frequency 100 Vac, 50/60 Hz (Japan) 120 Vac, 60 Hz (North America) 230 Vac, 50 Hz (Europe) Output voltage/watt 12 V DC, 15 watt maximum
http://support.visioneer.com/downloads/Manuals/9220/9220_Install.OT3.EN.pdf
If this helps, please give a positive rating. Good luck to you!
Jul 01, 2011 | Visioneer OneTouch 9220 USB Color Scanner
Please tell me the input voltage and amperageof my speakers emachine model sp-30a
Output Values:
Output 9 VAC 200 Ma
Input values:
Input 120 VAC 60 Hz
I believe this is what you are looking for. Output voltage and amperage for the SP-30A speakers, as read on the tag. The output will be the sound out and capabilities. The input is going to be the standard US wall socket.
Apr 26, 2011 | Audio Players & Recorders
90/180 volt output is ruining/overheating tools and several electronic devices and fluorescent fixtures will not start.
I am not familiar with this make of generator, however I am thinking that voltage regulation and rpm are tied together with this unit. The generator MUST have an output of 60 hertz. This could be 63 hz (when the load comes on it drops to around 60). If the frequency is NOT at the above specs you will burn out anything with a transformer or motor. Now this translates to around, minimum of 3600 rpm on the engine. If you have access to a frequency meter (a kill-a-watt) you can set the speed. I found it best when using the kill-a-watt to use it with a minimum of a 10 foot extension cord. Set the throttle speed so that your frequency reading is 63 hz. If this is the non electronic voltage regulated type of generator, the voltage should come up to around 120 volts and the frequency should be at 63 hz.
joe
Mar 09, 2011 | Northstar Generator 13 Hp, 8000 Watt,...
7 hp brigs engine on my generator runs two fast producing 127 volts. how do I slow it down?
Hi and welcome to FixYa. I am Kelly. Since you did not mention the make or model number of your generator I will respond in generic terms. If your generator is at 127 volts with NO load it is adjust at the very top end of the manufacturers limits. There is a 10% tolerance so 120 VAC + 12 is 127 VAC. Under an electrical load above 500 watts the generator should drop the output voltage slightly so your generator would still be within factory limits. Personally on any generator as a repair person; I set the output voltage at 126 VAC no load so that when the user puts the generator to work the output voltage is good. If your generator is running at 127 VAC under load then you can adjust the governor screw on the governor plate CCW about 1/2 turn to drop the voltage. Without a generator model number or engine number I can not tell you exactly where the governor plate is on your engine / generator. The screw will have a lock nut that you must loosen 1/4 turn then turn the adjustment screw CCW to drop the voltage. Just make sure to re-tighten the lock nut when the adjustments are complete. Mind you by decreasing the output voltage you also drop the output freqency at the same time you decrease the output voltage. It is better to have 125 -127 VAC under a no load condition as the more electrical load you add the more voltage drop you will notice. It is best to adjust the generator to 122.5 -123 VAC under a medium load. (50% of output capacity) A bread toaster is 1400 - 1600 watts and is a good load for a 3000 watt generator. Also a good hand held hair dryer will use around 1600 watts. If you use this type of load and the voltage output is 122.5 to 123 VAC I would not adjust anything. I have been working on generators since 1970 so this is nothing new for me. I hope that you understand everything I posted. If not, feel free to ask as many questions as you wish in any future response.
Thanks for choosing FixYa,
Kelly
Jan 08, 2011 | Craftsman Electrical Supplies
What is the proper DC power supply voltage for an
Power supply details are as follows:
Mar 12, 2010 | Visioneer OneTouch 8100 Flatbed Scanner
I misplaced the power supply for my visioneer 4400usb scanner. Can anyone tell me the voltage output to the scanner?
Power supply
May 24, 2009 | Visioneer 4400 Flatbed Scanner
Lost the power plug what kind is it
1. You can buy a new power plug here.
2. You look at the power connector on your scanner and try to find a replacement with the following specifications:
Input voltage/frequency:
  • 100 Vac, 50/60 Hz (Japan)
  • 120 Vac, 60 Hz (North America)
  • 230 Vac, 50 Hz (Europe)
Output voltage/watt:
  • 12 V DC, 15 watt maximum
If you try to find an AC/DC converter yourself, make sure that the DC plug has the right +/- polarity and right size.
Jan 11, 2009 | Visioneer 4400 Flatbed Scanner
Heating & Cooling Logo
66 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
