Vizio LCD Screen Scratch
I was moving and thought I protected the screen enough but I still ended up with a 1/4'' scratch in the lower right hand corner of my 42'' LCD Vizio. Its just deep enough to catch my finger nail. Is there any commercial product i can use to get rid of it? Is there anything I can do or will I have to live with it for the life of the set?
  • jmyers1182 Jan 13, 2009
    Thanks for your quick answers! I read somewhere else about the Vaseline idea and I am just afraid that it will just smear and smudge my screen. The pencil sounds like it might be worth a try. I'm going to take a look in the manual and see if it says anything but im sure it wont. Thanks to both of you for your help, I will keep this updated if I find anything.
    Sniper:
  • 62 Answers
There is A product for repairing scratches on CD's and DVD's. It is a wax type pencil that fills the scratch then "polishes" it away. It will not take it away completely, but should make it bearable. I Did the samething with my first widescreen. You an pickup this at circuit city for around ten bucks! Let me know how helpful this was! Good Luck!
Posted on Jan 13, 2009
  • 362 Answers
Hi jmyers1182, With out replacing the polarization film on the screen there is no guaranteed way of repairing the scratch. A method of disguising the scratch is to use Vaseline, very lightly rub the Vaseline into the scratch and carefully wipe away excess. I have used this method and it works on some and not on others. Let me know how it goes and please rate this solution. lone99star
Is it possilble to repair a scratched lcd tv screen
Hi
Typically, all lcd screens have a protective film coating that is scratched is not the matrix. If the scratches are not deep you can try them polished tool for polishing cd drive. If you scratch deeper and you will not be able to remove them yourself, contact a service center to replace the protective cover the screen it will cost a low price
Sep 18, 2010 | LG 30FZ4D TV
Scratched computor screen
How deep of a scratch is it on the screen? Just on the plastic/glass protective coating over the monitor?
If it is not in the LCD then you could just remove the plastic/glass and replace it if you want.
If the scratch is deep then your LCD is probably scratched. Sadly the cost of replacing the LCD screen within an LCD monitor is more expensive than buying an entirely new screen. Your best bet is either dealing with the scratch or getting an entirely new monitor. I would recommend visiting www.newegg.com where there are many cheap monitors there.
please rate my solution
Jul 20, 2010 | Acer AL2016W 20" LCD Monitor
MY 3 YEAR OLD DAUGHTER HAS JUST SCRATCHED MY SONY BRAVIA TV WITH A MAGNA DOODLE PEN. HOW CAN I GET RID OF THE SCRATCHES?
Clean the surface of the LCD screen with a barely damp cloth.
  • Step 2 Dry the screen with a soft, clean cloth.
  • Step 3 Rub a generous amount of petroleum jelly into the scratch using a cotton swab. The petroleum jelly should fill in the scratch and remain there.
  • Step 4 Immediately wipe the excess petroleum jelly off of the screen with a soft cloth being careful to leave some petroleum jelly inside the scratch to act as a patch or filler.
  • This scratch repair method is effective because of optical density. The optical density of petroleum jelly matches the plastic, LCD screen coating more closely than that of air.
  • To avoid future scratches or gouges, you might consider purchasing a LCD screen protector. These screen protectors are generally made of a thin, plastic film and affix to the screen without adhesives. Not only can they protect against scratches, but they also keep the screen free of dirt, oil and dust while simultaneously reducing glare.
  • When wiping the screen as described Step 4, avoid pressing too hard or you will inadvertently remove the petroleum jelly from inside the scratch.
  • Using petroleum jelly to fill a scratch on your LCD screen could void your screen's warranty. If you are concerned about warranty issues, consult your user's manual for more information.
  • Sep 16, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
    Scratch on plasma screen
    You should be able to make the scratch become invisible using a white eraser. A pink one will work, but the white one works better. Just simply erase the scratch, it may take awhile, but your basically buffing the surface down even again making the scratch un-noticeable.
    Jun 21, 2009 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
    Scratch in sreen
    By the looks of that picture, it's hard for me to believe that the scratch is not on the outside of the protective plexiglass screen. However, you can remove the protective screen w/o negative effect of the picture. In fact, it will probably reduce the glare from light on the screen. If, in fact, the scratch is still seen w/o the protective screen installed, then it is the lenticular screen that is scratched.
    The lenticular screen is the one with the vertical grooves from top to bottom in it. The fresnal is the back screen that appears to have been lathed in a circular pattern.
    Jan 07, 2009 | Toshiba 61HX70 61" Rear Projection...
    Repaire scratches on a lcd flat screen
    The eraser method is even better than I first thought.
    I acquired my first scratch some weeks back, tried the eraser method, and was quite pleased with the results, as my scratch was approx. 80% less visible, a faint grey line visible only on very light or dark coloured backgrounds, instead of the glaring black line it was at first.
    Today my monitor toppled again (I really must tether the damn thing to something next time) creating - gulp - a new and even larger scratch. Oh, no... But whodathunk I'd end up happy I got the 2nd scratch? Oddly, I am happy, 'cause I took the opportunity to lay the monitor flat, take my white eraser again , and really go to town rubbing both new & old scratches. Lo & behold, both scratches appear to be now virtually 100% invisible or gone. My 2-scratch monitor is better now than it was as a one scratch one! I'm now convinced it's partly, largely, or completely due to the heat from friction of rubbing the eraser across the scratch, plus pressure applied, that does the trick. The heat must soften the plastic surface making it malleable, and the pressure of rubbing smooths out the jagged scratch edges, making the scratches disappear.
    -So, if at first your eraser doesn't completely eliminate your scratch, try, try again! Keep working on it - harder!faster! And with luck, you'll get results like mine: complete elimination of two ugly scratches!
    Apr 25, 2008 | Computers & Internet
    Polaroid FLM-2601 flat screen
    It has a protective outer screen and depending on the depth of the scratch you might be able to restore it. You'll need to look on-line at a few aircraft site for a kit that is meant to polish scratches from the plexi in an aircraft windshield. There is a company in Oregon http://www.chiefaircraft.com/airsec/Aircraft/Windshields/ScratchRemoval.html
    that sells the kit for 34.95....
    It is time consuming but I have restored many this way!
    Bill
    Mar 27, 2008 | Polaroid FLM-2601 Television
    Scratches on Plasma TV Screen
    My daughter scratched my TV Plasma with a Pen - It now has scratches. What can I use to get rid of these scratches.
    Mar 26, 2006 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
    Televison & Video Logo
    754 people viewed this question
    Top Televison & Video Experts
