Question about Toshiba CZ36T31 36" TV
Toshiba cz 36t31 suddenly has no sound and shows no pic only the red on light comes on..how do i fix this and is it worth fixin???
It worked fine yesterday is there a part i can order cheap ??
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
If the red light on little chance of a fuse, set is large and old enough unless you have some experience or know someone who does you may not be able to fix it.
Issues range from broken connections at for example the high voltage transformer to elsewhere in set or almost any part in power supply for this issue.
Typical high voltage transformer--look do not touch.
toshiba cz 36t31 suddenly has no sound and shows n - 12_11_2012_8_36_10_pm.jpg
Posted on Dec 11, 2012
4 Suggested Answers
  • 71 Answers
SOURCE: no pic..or sound
a lot of times when a set is dropped the printed circuit board gets cracked, the only way to tell is to remove the back and printed circuit board and check; if not too badly damaged can be 'hard wired' across breaks and fixed
Posted on May 08, 2008
welcomejee
  • 10594 Answers
SOURCE: My toshiba tv doesn't work
Toshiba 52HM95, Green and Red blink continuously at 1-second intervals, it is an error code that shows problem with Lamp in tv.
The lamp is not working properly, turn Off the tv, unplug it from wall socket for minute, replug back in and turn it On. If the problem persists, replace the lamp in tv.
Let me know when did you replaced lamp last time in tv?
Thanks.
Posted on Sep 26, 2010
gopakumarg43
  • 74459 Answers
SOURCE: I have a Toshiba 36AF43 was working fine then all of a sudden it turned off and now the red power light blinks it doesnt turn on or make and sounds I have anew 50
Check its horizontal output transformer, and associated circuts.
Posted on Apr 28, 2012
I have toshiba estudio211 copier machine copy coming ....but painal show tols icon red err i give you one pic plz solve my problme.godbless u sir....
I have toshiba estudio211 copier machine copy coming ....but painal show tols icon red err i give you one pic plz solve my problme.godbless u sir.... Sir Please Help Mi
Oct 13, 2015 | Toshiba Office Equipment & Supplies
40wh08b convergence problem
Convergence IC's need replacement = STK392-110 original #...
Use name brand Toshiba, NAP, or upgrade to STK394-160E
Hitachi part # CZ 01341...no cheap generics..they won't hold up..
Chassis pull and some precision soldering will be needed....let me know if you need further info...........................T.
Dec 27, 2007 | Toshiba 40H80 40" Rear Projection...
I turned on my tv and everything was fine it started to make a little wisttling sound and all of the sudden the pic dissapeard no audio and no pic the on light stays on but nothing shows please help .
There are two possible problems. We will concentrate on one first. You say the red light stays on, and the TV will not power up. Actually this is a good sign. This TV has one bad capacitor and a one weak capacitor. The bad capacitor location is C421, which is a 200 volt 10 MF at 85 degrees. Replace with a 200 volt 10Mf at 105 degrees. The second capacitor that is weak is the C482,which is a 50 volt 4.7Mf at 85 degrees. Replace with a 50 volt 4.7 Mf at 105 degrees. This should enable your TV to come back on. If the TV will not come on we will have to replace the eeprom. At this time I believe the eeprom is fine. In either case, the capacitors will need to be replaced. Try that and let me know how you do. Thanks for asking me and show all hands of support!
May 16, 2011 | Philips Magnavox 27MS343S 27" TV
Blue light remains lit but lose picture. no other indicator lights flash. if i unplug the tv it will restart but lose picture again after half hour
I have a toshiba 50hm67 tv and with mine the blue light would come on and I would hear sound first and then the picture would finally come on... this happend for about a month.... next the yellow and blue light would come on but the pic still wouldn't come on until it clicked off and on by itself for about 10 min this went on for about a week. All of a sudden last night the red lights by the power light started blinking. No tv now and when the tv shut off it said lamp not working.
Sep 17, 2010 | Toshiba 56HM66 56" Projection HDTV
42 inch flat screen shows black screen with sound only no picture
That sounds like the backlight system or its powersupply has failed. If you can see an ghost like image when close and at an angle near the dge (depends on the light) then this confirms the backlight being the problem.
Repair cost should be about $100. You should be able to get this fixed under warrenty if you have any. If not get repair estimates before doing anything. It should be worth fixing but it never hurts to know if it is getting close to what a new replacment tv is worth.
Apr 23, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
No pic...humming noice on 62'' toshiba dlp
was the lamp blown if it was blown you could be hearing the ballast
if the lamp was not blown and the new one did not fix it the red light indicates the door there is a little switch when you put the door back on if you look at it it may need to be adjusted so it will connect with the door if that is not it you could have a fan that is not turn if it is making a real loud constant humming noise while it trying to fire the lamp you probably have a bad color wheel
Nov 19, 2008 | Toshiba 62HM95 62" HDTV
No pic
alright guys...blew a bulb....fixed that. still didint work...found out it was ballast...replaced that. tv worked for a month..all the sudden hdmi input didint work id plug in my playstation and screen would turn green and say "hdmi color has been corrupted" im thinking wtf? so a week later it works fine then just turns off in middle of watching espn... comes back on an hour later...only to turn off again...it just turns black for ten seconds then just turns off and the red and green lights blink at intervals of one second....replaced a bulb..not that, same problems.......when the tv comes on for the ten minutes before it quits working the pic and sound are great i just dnt get it...is it shorting out? color wheel bad? a fan?
May 24, 2008 | Toshiba 52HM95 52" HDTV Projection...
No pic..or sound
May 08, 2008 | Toshiba 36A61 36" TV
Quit working
Based on the limited info.I have, it sounds like the heating element is not getting power. suggest visually inspecting the switch and thermostat for burnt wires. Also check the heating element for broken electrode.
Nov 08, 2007 | Comfort Zone CZ-530 Compact Heater
Toshiba CZ36T31 36" TV Logo
102 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
