Question about Electrolux EW30GF65GS Gas Range
Electronic ignitor will not turn off - Electrolux EW30GF65GS Gas Range
  • Official Brand Answer
  • 4,342 Answers
Hello garroneb - From what you have described, the range may possibly have a faulty switch assembly. Contact a professional to move forward accurately.
Posted on Dec 14, 2012
Why is my Jandy Lite 2 Pool Heater Tripping the Circuit Breaker
shorted ignitor remove the ignitor leads and see if it still trips if it doesnt trip replace the ignitor
May 17, 2012 | Jandy Laars Lite2 - 125,000 BTU Propane...
WHERE IS MY PILOT ON MY FRIGIDAIRE FGF368GM
Hello, There is no pilot..It uses ignitors to light. number 19 in this picture is the oven ignitor http://lookup.bellparts.com/diagramenlarge/frigidaire/47877/00000358
If when you turn on the oven it doesnt glow bright orange chances are it failed and needs to be replaced. The top is electronic ignition. If this helps please rate me..Thanks
Jun 08, 2011 | Frigidaire FGF368GM Kitchen Range
STOVE WORKS BUT OVEN WILL NOT HEAT UP - GAS OVEN
There are 2 high likelihoods as to what your problem may be. When you turn your oven on, does the ignitor begin to glow within 15 to 30 seconds? If it doesn't, there is no power going to the ignitor and the control mechanism is going to need to be replaced. If you have a manual dial thermostat control, you can order this on-line at parstdirect.com. If you control is electronic, you will be required to have an appliance technician come out in order to send the old controller in to be rebuilt.
If your ignitor is glowing when you turn on your oven, but it has a very dull orange glow, you have a bad ignitor and it needs to be replaced. This is the most common problem with older gas ovens. The ignitors just burn out after time and do not draw the amperage needed to open the safety valve.
Replacing the ignitor is a fairly easy procedure. Replacing a dial thermostat control can be a little rough due to rerouting the thermocoupler back through the oven body. Unfortunately, the electronic style oven controls can only be sent in for rebuilding and the company that you use will need to be able to handle "Retforrepr Rebuilds".
May 01, 2011 | Magic Chef 9122 Gas Single Oven
Electronic ignitors won't stop clicking
Pull the burner caps, etc off the stove and completely dry the area ..Be sure to inspect each ignitor contact for cleanliness as well. If the ignitors have soapy buildup or water, around them, they can act like this.
You should be able to pull the burner caps and flame diffusers off and clean with a paper towel, and if needed, a light scouring sponge. Be careful not to scratch the surfaces, but scour the top of the ignitors carefully if you need to clean them.
Jul 31, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Not heating up Gas Dryer
Modern gas dryers do not have a pilot light. They have an electronic ignitor (glow or spark). A glow ignitor turns on several seconds before the gas turns on and should get orange hot. A spark ignitor should make a clicking or buzzing noise.
Most likely the ignitor is bad but you can check it fairly easily to make certain. The best instructions I have found are at
http://www.acmehowto.com/howto/appliance/dryer/gdryer/check/ignitor.php
If it is the ignitor it can be replaced with a few hand tools. Remove the bad ignitor. Write down the make, model, and serial # of your dryer. Call your local appliance parts store to see if they have one it stock before driving over there.
Dec 22, 2009 | Whirlpool Dryers
Oven not receiving any gas but pilot is working
Sounds like you have a weak ignitor (pilot lite) . The ignitor has to turn white hot , not red , orange , but white , to open the gas valve . Replace the electronic ignitor and that should get the oven working .
Aug 16, 2009 | Danby D9604 Refrigerator With Ice Box
G.E Profile gas cook top #JGP640 ignitor.
It is sparking because the module does not sense the heat which would normally cause the sparking to stop.
It can be caused by a poor ground, make sure the ignitor at that burner is clean and free from any obstructions. If it is then it could either be a defective ignitor or spark module.
Mar 12, 2009 | GE Cooktops
Maytag Range MGR6875ADB will not light and no clicking sound
Sounds like your electronic ignitor is not getting the supplied voltage,it could be the contol box or a bad ignitor.The gas valve will not open when this is the case.I assume you know how to use a meter.Check that the breaker is not tripped,check line voltage to the ignitor.If supplied voltage is there when the unit is turned on, the ignitor is bad.That's why no clicking!!
Nov 21, 2007 | Ovens
Oven will not heat up.
eerb, most likley your ignitor failed. When you turn the oven on to bake you should hear a relay click on the electronic control (clock). You can do a couple of things here. If you have a ohmmeter the ignitor should ohm out at between 50 and 150 ohms. You can physically swap out the bake and broil ignitors to see if the ignitor comes on in bake. Or you can swap the bake and broil wires on the board. They should be marked BA and BR. This way when you turn on bake, the broil ignitor should glow and verify you have power going to it. Carefull when testing, be sure to kill power to the range before any changes. Catriver...post back
Dec 12, 2006 | GE JGBP26 Gas Kitchen Range
Electrolux EW30GF65GS Gas Range Logo
104 people viewed this question
Top Electrolux Kitchen Ranges Experts
Rommel Balcita
Mike Henne
Level 1 Expert
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
