Question about HP Photosmart D5160 InkJet Printer
HP Photosmart D5160 Error Code 07874DD6 031F4DD6 HELP !!!
Joed911
  • 4338 Answers
SOURCE: Flashing red light won't correct on HP Photosmart D5160 printer
Here is a HP document that explains what the blinking lights mean and how to fix it:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01041365&dlc=en&product=1155996
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 30, 2008
  • 5 Answers
SOURCE: problem of my printer photosmart d5160
I have the exact same printer. Struggled for hours with it, until I learned it's ways. If you have good cartridges in and purge your print buffer from your computer, then 'gently but firmly' slam the top cover.
I don't see sensors, etc that detect it being up, but I just closed mine, had ! blinking, etc. Then gently 'slammed' the top cover and it reset and worked great.
Posted on Jun 05, 2009
nalin_elliot
  • 224 Answers
SOURCE: Won't power on
The product uses a power cord, if the power supply is a power cord with electrical connections at each end. Figure 1: Power cord c00057913.jpgThe product uses a power module, if the power supply is a power cord connected to a power module. Figure 2: Power module c00745315.gif
  • If the product uses a power module (adapter), go to Step two: Check if power is supplied from the power module.
  • If the product uses only a power cord, go to Step three: Check if power is supplied from the power cord.If the product uses a power module (adapter), follow these steps to make sure that power is properly supplied to the product. Figure 3: Power module c00745315.gif
    1. Check the power module part number against the part number listed in the User’s Guide to make sure that the proper power module is being used.
    2. If the power module has a permanently attached power cord, do the following.
      1. Disconnect the power cord from the wall outlet.
      2. Disconnect the power cord from the product.
      3. Wait 30 seconds.
      4. Reconnect the power cord to the product and the wall outlet.
    3. If the power module has a detachable power cord, disconnect the power cord from the power module and reconnect the power cord to the power module.
    4. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
    5. If the product does not turn on, or the power light built into the power cord does not glow, plug the product into a wall outlet in another room.
      • If the product or power light turns on when connected to a wall outlet in another room, there is an issue with the power supply in the previous room.
      • If there is still no power to the product, then the power module, power cord, or product might be defective. Proceed to the next instruction.
    6. Connect the power module or power cord to another HP Deskjet or Photosmart product to see if the power module is functioning.
      • If the power light does not glow, the power module might be defective. Replace the power module and the power cord.
      • If the power module or power cord works on the other product, the product facing the issue might be defective. Proceed to Step four: Service the product.
If the product uses only a power cord, follow these steps to make sure that power is properly supplied to the product. Figure 4: Power cord c00057913.jpg
  1. Inspect the power cord for visible damage.
    • If the power cord is damaged, replace the power cord.
    • If the power cord is not damaged, continue with the next instruction.
  2. Disconnect the power cord from the wall outlet.
  3. Disconnect the power cord from the product.
  4. Wait 30 seconds.
  5. Reconnect the power cord to the product.
  6. Reconnect the power cord to the wall outlet.
  7. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  8. If the product still does not turn on, plug the product into a wall outlet in another room.
    • If the product turns on when connected to a wall outlet in another room, there is an issue with the power supply in the previous room.
    • If there is no power to the product, then the power cord or the product might be defective. Proceed to the next instruction.
  9. Connect the power cord on another HP Deskjet or Photosmart product to see if the power cord is functioning.
    • If the power cord does not work on the other product, the power cord is defective. Replace the power cord.
    • If the power cord works on the other product, the product facing the issue might be defective. Proceed to Step four: Service the product.
Step four: Service the Product If you have completed all the steps listed above and are still experiencing a problem, service the product by calling hp at 1800-474-6836
Posted on Jun 17, 2009
SOURCE: hp photosmart error code 0xc05d2381. does this
french oeioe
Posted on Aug 16, 2009
luciana44
  • 292 Answers
SOURCE: HP photosmart D7160, ink sys failuar error code:
Hi otissr
If you are lucky, the solution given by HP in the following link will help.
Hope you wouldn't require a service call.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01936219&cc=us&lc=en&dlc=en&product=1156652
Good luck
If my answer is helpful, please give a rating.
luciana44
Posted on Dec 28, 2009
Won't print - d5160 photosmart. system subspooler app error
Printer Spool offline:
Disconnect the USB cable, go to RUN and type in services.msc and then find print spool and right click, then choose restart.
or:
Start-->printers and faxes-->right click on the printer-->properties-->make sure it
May 17, 2011 | HP Photosmart D5160 InkJet Printer
HP Photosmart D5160 gives error message -0 03 31 IF F$ 4d dd d6
Issue
The product displays an 0x ... error code when printing (for example Error: 0xf0af8004). These error codes indicate that the product has an internal condition.
Solution
Use the instructions below to resolve the issue by restarting the product.
Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
Open the cover of the product and remove the print cartridges.
Close the cover and wait for the Insert Ink Cartridges message to display.
Disconnect the power cord from the back of the product and wait for one minute.
Reconnect the power cord. If the product does not automatically turn on, press the Power button.
Open the cover and reinsert the print cartridges.
Close the cover.
If prompted, print a calibration page.
Reconnect the USB cable, and try to print a print job from the computer.
If these steps did not resolve the issue, contact HP technical support for assistance.
Mar 05, 2011 | HP Photosmart D5160 InkJet Printer
I received an error code on my HP Photosmart D5160 Inkjet Printer of 003311FF44dddd6. Any help would be greatly appreciated.
I've got the same error code. I disassembled plastic body to reveal mechanism. At the end of initialisation procedure I noticed that the cleaning caret was stuck and a ckracking sound appears. I took off a small triangular cogweel panel at the right hand end of the mechanism that actually gears the cleaning caret. I disassembled the panel and discovered a brocken cogweel. Also I noticed that the cleaning caret itself was hard to move. I applied some grease, but now I need the brocken cogweel to be replaced or fixed. The resume: if you are not into fixing your equipment and got such an error - probably a service center is waiting for you.
Feb 19, 2011 | HP Photosmart D5160 InkJet Printer
HP Photosmart D5160. Software won't install on computer with Windows Vista
u must uninstall software unplug your HP!
Shutdown your PC!
Reinstall drivers!
Connect your HP D5160 printer
Sep 21, 2010 | HP Photosmart D5160 InkJet Printer
Help, I have lost my installation disk for my HP Photosmart D5160 Printer. They would like to charge me $38.00 for a new disk. Any suggestions?? Thanks, Mary
You can download the Softwares/Drivers for your printer from these links (similar with the contents on the Hp CD) :
Hp Photosmart D5160 Printer for windows xp 32 bit
or
ftp://ftp.hp.com/pub/softlib/software10/COL15834/dj-41864-2/TF_regna_psp_NB.exe
Hp Photosmart D5160 Printer for windows xp 64 bit
or
Hp Photosmart D5160 Printer for windows vista 32 bit
or
ftp://ftp.hp.com/pub/softlib/software10/COL18384/dj-47558-2/SF_CDA_Full_Non-Network_enu_NB.exe
Hp Photosmart D5160 Printer for windows vista 64
or
Hp Photosmart D5160 Printer for Windows 7 32 bit
or
ftp://ftp.hp.com/pub/softlib/software11/COL30907/dj-76773-1/SF_CDA_NonNet_Full_Win_WW_130_140.exe
Hp Photosmart D5160 Printer for Windows 7 64 bit
or
Hp Photosmart D5160 Printer for Linux
For Mac Drivers, please visit here and follow the instructions given there.
It would be much easier for you and for me if you had mentioned the Operating System installed on your computer where you are going to install the printer. Anyway, select the suitable link for your operating system.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Aug 23, 2010 | HP Photosmart D5160 InkJet Printer
Problem of my printer photosmart d5160
Apr 24, 2009 | HP Photosmart D5160 InkJet Printer
How download driver for D5160
Follow the instructions on page below to install drivers and download manuals for your printer:
Mar 05, 2009 | HP Photosmart D5160 InkJet Printer
HP Photosmart D5160 trouble
i have a stall carrige.. how to fix up that....
Aug 05, 2008 | HP Photosmart D5160 InkJet Printer
Hp 97 use to D5160
see whether your printer is capable of using other hp cartridge.it may be the same on physical appearance but check it on the manual of your printer if you could use 97 as a replacement cartridge
May 27, 2008 | HP Photosmart D5160 InkJet Printer
HP Photosmart D5160 InkJet Printer Logo
613 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
