Question about Denon AVR-3806 Receiver
Having troulble getting sound from playstation3
I have sound from the tv to all the speakers just not the playstation 3 I have used HDMI cables and the are wired into the reciver and the T.V. Is also wired with HDMI cables.
Hi my first going at doing this -
have you tried adjusting the sound settings in the ps3? i have found that if you set that right (ie hdmi) they you should solve this issue
Posted on Jun 09, 2009
I am trying to hook up my playstation3 to my my sanyo plasma hdtv I brought the HDMI plugs when i hooked it up I have no video and no audio what do I do to fix it or do i need a plug for each one of my...
If you would like both video and audio to output through the HDMI cord, make sure to go into the PS3's video settings and select HDMI output there, and also go into the audio output settings and select HDMI. This should make the audio come out of the TV's speakers.
If you're using separate speakers, such as a surround sound system, use a different audio output (such as the red and white component cords) and plug those directly into your sound system.
Apr 24, 2011 | Sony Playstation 3 (PS3) Console
All of a sudden, no sound on PS3, great pic though. Using HDMI cable...have checked all connections, reset PS3, etc. Still no sound! Guy from Sony said my HDMI cable(Monster) could be bad?! No sound, but...
I agree with the guy from Sony, the reason for this is the HDMI cable should support the transfer of audio and video over the same cable, if your only getting video over it, the cable could be defective, or its possible that you have another cable in the spot where speakers should go that is over riding the HDMI.
What exactly is the HDMI cable plugged into? Is it direct from TV to PS3?
If you have a stereo set lying around that supports HDMI - try having it run through that.
Is the TV muted? check if you can get sound while watching normal TV channels.
Worst comes to worst, use RCA Plugs remembering that the composite video is (yellow) and stereo audio is (white and red). You don't need to connect the composite video, but connect the stereo audio.
If this did not solve the problem, please leave a comment and I'll get back to you once I can =)
Jul 17, 2009 | Sony Playstation 3 (PS3) Console
Can't get Playstation3 sound through the STR-DG800 using HMDI.
Do you have your ps3 connected to the TV with HDMI and then audo cables from the TV to the receiver? If so, you need to make sure you change the audio settings on your TV to surround sound.
May 12, 2009 | Sony STR-DG800 Receiver
LC32OEM9 says Not Supported Format on HDMI Input. It worked when we first hooked up the TV. Then it started working sporadically now it very very rarely works and when it does it only works for maybe 15...
I'm thinking the Comcast DVR box maybe putting out weird HDMI signals and the TV can't translate it. I would call the Comcast people on this one.
In the meantime, I would try finding another source the uses a HDMI cable to rule out the TV as the problem. Basically, testing the TV to see if the problem still happens when you use something else than the Comcast box. Try a Blueray player, Playstation 3, or Xbox. Just something that uses a HDMI cable.
Apr 30, 2009 | Emerson LC320EM9 32 in. LCD HDTV
I can only get 2.1 sound from my Playstation3
optical cable connection in tv is only input and same in receiver it is both inputs.you need to find the right encoding in your receiver mode/set-up
Apr 21, 2009 | Sony DAV-HDX500 System
Playstation3
when the ps3 is in standby mode with just hte red light on. hold it down til it beeps takes about 5 to 10 seconds and it will bring it back to AV mode so u should be able to get picture and sound.
Oct 31, 2008 | Sony Playstation 3 (PS3) Console
Using a Compaq WF1907 monitor with a Playstation3
No. HDMI transfers picture and sound, but DVI does not. You need a audio line as well.
Oct 25, 2008 | HP Compaq WF1907 Monitor
Ps3 Surround sound
ttttttttttttttttttttttttttttttt
Nov 22, 2007 | Sony Playstation 3 (PS3) Console
Ps3 hdmi-av
i currently have the exact same problem...i always play HDMI but i went home from college for thanksgiving and wanted to play on a regular AV jack TV, hooked up, and have no picture whatsoever...and i think it's because of the settings on the PS3 since it's set to send out an HD signal...Well i found this straight from Playstation3.com, on the support/troubleshooting section
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution."
Hope it helps =)
Nov 17, 2007 | Sony Playstation 3 (PS3) Console
Please help with getting 5.1 sound from my TV!
You must run a Digital Optical cable from your PS3 to your reciever. Then press your function button on your recievers remote until you see SAT/CABLE on your recievers display. Next go to your PS3 settings and go to Sound settings, then Audio Output settings, and select Digital out (OPTICAL) then your done. This is the only way to get true digital sound from your PS3 to your reciever.
Oct 01, 2007 | Sony DAV-HDX500 System
Denon AVR-3806 Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
