Question about Acer AL1917 19 inch LCD Monitor
External Acer AL1917 stopped to work with Lenovo 3000 n100 as an external monitor.
I used 2 work with external Acer AL1917 on my PC. After running some program, which checks drivers, I can't use my external monitor ("no signal" appears on its screen). Also the combination Fn+F7 no more works on PC. When I tune the Presentation Director 2 work with AL1917 as an external monitor, PD behaves as if the external monitor can't be found. The Driver Detector reports that AL1917 driver is OK.
    Sergeant:
  • 249 Answers
No signal means you have a different input enabled somewhere...like TV/HDMI/VGA ...you are set on some input other than the one you need for your cable. Check the menu settings, if you have a remote, try the input button and try a different setting
Posted on Jul 10, 2017
Bogdan
  • 198 Answers
SOURCE: Acer AL1916W 19" problem
Hello mat78, Unfortunatelly the problem is hardware based. You will need to have the monitor repaired in a service center. Here's why: LCD/TFT monitors don't produce light themselves. They are composed by a matrix of transistors (TFT - thin film transistor) that have the property to reflect or allow some light (certain wavelenghts)to pass through them. They don't produce light by themselves. Instead there is a fluorescent tube (neon like) light inside the monitor and that's the light source used in order for you to see what's on the screen. A flourescent light is suposed to last pretty much, i don't think yours has a problem, you say it works for some seconds or so. Instead your problem is most probable with the inverter circuitry that powers on that light. It's a common problem among these types of monitors but in your situation i don't think it will be an expensive repair. In the case that the screen is dark (in a dark place you can't read or view anything on it) but if you apply light to it ( a flashlight or something) and you see something, then the problem is most likely to have occured with the invertor. Try to ask at a local service center for a repair, this shouldn't be an expensive procedure. Hope this helps.
Posted on May 24, 2007
  • 198 Answers
SOURCE: unable to install AL1916w lcd driver in xp
i buyed the new al1916w lcd monitor ,i tried to install the driver for it.
i also downloaded the driver from acer site ,when i looked in device manager ,i found two plug and play monitor
plz check this link
<a href="http://imageshack.us"><img src="http://img151.imageshack.us/img151/2717/48550554nr5.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/>
then i selected update driver from the right click and selected the folder wherethe driver was stored ,after searching windows cannot find the drivers.
i am sure that the folder has the driver downloaded from the site.
check this link
<a href="http://imageshack.us"><img src="http://img100.imageshack.us/img100/71/28697132zh8.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/>
now how can i install the lcd monitor driver?
any other method?
Posted on Feb 20, 2008
SOURCE: Acer al1916W Driver updates
Problems like this are usually the fault of the video card and not the monitor. Does your video card support 1440 X 900? Try updating your video card drivers.
Posted on Mar 10, 2008
Nic61
  • 1073 Answers
SOURCE: Computer won't recognize monitor driver
Its the usb, if u connect the monitor via the standard port, the vga port, it will work. If your monitor only have an dvi cable you can fix that by an adapter. That adapter should be an DVI to VGA.
Good luck to you
Posted on Dec 11, 2008
leecom72
  • 4806 Answers
SOURCE: Acer Aspire 3680 Cracked Screen *help*
Hi there
yes you can plug an external monitor to the laptop, the screen switch keyboard toggle is hold down Fn and is should one other the F keys with a monitor icon on it, just press that to activate the external monitor
Good luck and thanks for using Fixya!!!
Posted on Feb 11, 2009
No display on booting but from sound it is evident that win xp is booting & running. No display in external monitor also
If only problem is the lcd screen, if you are sure, just buy a new inverter for lcd and install it, forums like these and some sites on net explain how it is to be done
Mar 28, 2014 | Lenovo 3000 N100 0768 - Pentium Dual Core...
No display but OS is booting & running as evident from sound.No display in external monitor also
Does the power on light show on either the OS monitor or the external monitor? If so, and no picture, it is likely to be the graphics card has failed. If in warranty return.
Lenovo 3000 n200 0769AMU press power on switch green light on after about 1 sec screen still black no HD light fan running
Welcome to Fixya
Try to drain the electrostatic charge of the motherboard that usually cause this issue. I wrote a tip on how to do the power drain. Try to plug in external monitor on the VGA port and see if you are getting display using external monitor. If you are getting display using external monitor then the problem would be the laptop LCD. If you are getting the same black screen using external monitor then the problem is already the motherboard.
Thank you for using Fixya!
Mar 19, 2011 | Lenovo 3000 N200 0769 Intel Celeron 530...
Lenovo 3000 n100 lcd display works but only less than a minute before display goes black. Connect an external monitor and it works fine.
possible problem is your led light on your LCD or its Flex. you might need to have it replaced. Try to check your LCD when it turns black under the light if you can see a dark image of your desktop. If you can see your desktop then the backlight has a problem. If there is no display, your LCD needs to be replaced.
Aug 13, 2010 | Lenovo 3000 N100 0768 - Pentium Dual Core...
How much does a new optical drive for lenovo laptop Y410 cost?
NEW DL USB External DVD±RW Drive for IBM-Lenovo 3000 C100 C200 N100 N200 V100 V200 Y400 Y410 Price: $40.35
Jul 14, 2010 | Lenovo 3000 Y410 (59012354) PC Notebook
Can I send an s-video signal from my Lenovo laptop to the tv..???
yes, if you have an S-video out port you can.
once you have the cable connected to both pieces of equipment, you will need to push the signa. to the external screen. not sure what buttons are used on the Lenovo, but you can look that up. You may need to adjust your display settings to allow for the external video screen
May 31, 2010 | Lenovo 3000 N100 Notebook
I got black screen a few seconds after reboot my LENOVO 3000 N100, type 0689 - 2BS, Laptop run normally without screen light, I need to flash screen in order to read it. I tried unplugging the battery and...
Hi. I think the LCD screen of your laptop needs a replacement because I think the backlight on that LCD is already busted thats why you need to point a flashlight or some sort of light just to see the display. Powerdraining your computer wont work because this already a hardware issue with the LCD, that's why when you switch display with your monitor it works fine. I would suggest replacing the LCD of that laptop or try calling Lenovo tech support if your laptop still under warranty so that they would replace it for free. This is no. to contact for your Lenovo laptop US/Canada 1-800-426-7378, Australia 1-300-880-917. Hope this Helps
Feb 28, 2010 | Lenovo 3000 N100 Notebook
Screen goes dark after a few seconds
try fn+f7 that Toggle external monitor,and disconect external monitor before starting
Jun 13, 2009 | Lenovo 3000 N100 0689 Notebook
I have a lenovo laptop 3000 n100 i reseted everything to factory defaults updated to windows sp3 and installed all software required for my computer to work. but the only thing is my usb ports do not read...
Does it recognize the devices in the first place? If it does then it could be the operating system is not compatible with the devices. If it doesn't, then you will have load the drivers for the onboard USB. You could check this through the Device Manager. Good luck.
Jun 10, 2009 | Lenovo 3000 N100 Notebook PC
Lenovo 3000 n100 notebook monitor turns green
my lenovo 300 N100 when turnned on the laptop from charger and Monitor
Apr 26, 2009 | Lenovo 3000 N100 0689 Notebook
Acer AL1917 19 inch LCD Monitor Logo
37 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
