Question about HP Photosmart D5160 InkJet Printer
D5160 error code 07874dd6 - HP Photosmart D5160 InkJet Printer
Won't print - d5160 photosmart. system subspooler app error
Printer Spool offline:
Disconnect the USB cable, go to RUN and type in services.msc and then find print spool and right click, then choose restart.
or:
Start-->printers and faxes-->right click on the printer-->properties-->make sure it
May 17, 2011 | HP Photosmart D5160 InkJet Printer
HP Photosmart D5160 gives error message -0 03 31 IF F$ 4d dd d6
Issue
The product displays an 0x ... error code when printing (for example Error: 0xf0af8004). These error codes indicate that the product has an internal condition.
Solution
Use the instructions below to resolve the issue by restarting the product.
Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
Open the cover of the product and remove the print cartridges.
Close the cover and wait for the Insert Ink Cartridges message to display.
Disconnect the power cord from the back of the product and wait for one minute.
Reconnect the power cord. If the product does not automatically turn on, press the Power button.
Open the cover and reinsert the print cartridges.
Close the cover.
If prompted, print a calibration page.
Reconnect the USB cable, and try to print a print job from the computer.
If these steps did not resolve the issue, contact HP technical support for assistance.
Mar 05, 2011 | HP Photosmart D5160 InkJet Printer
I received an error code on my HP Photosmart D5160 Inkjet Printer of 003311FF44dddd6. Any help would be greatly appreciated.
I've got the same error code. I disassembled plastic body to reveal mechanism. At the end of initialisation procedure I noticed that the cleaning caret was stuck and a ckracking sound appears. I took off a small triangular cogweel panel at the right hand end of the mechanism that actually gears the cleaning caret. I disassembled the panel and discovered a brocken cogweel. Also I noticed that the cleaning caret itself was hard to move. I applied some grease, but now I need the brocken cogweel to be replaced or fixed. The resume: if you are not into fixing your equipment and got such an error - probably a service center is waiting for you.
Feb 19, 2011 | HP Photosmart D5160 InkJet Printer
HP Photosmart D5160. Software won't install on computer with Windows Vista
u must uninstall software unplug your HP!
Shutdown your PC!
Reinstall drivers!
Connect your HP D5160 printer
Sep 21, 2010 | HP Photosmart D5160 InkJet Printer
Help, I have lost my installation disk for my HP Photosmart D5160 Printer. They would like to charge me $38.00 for a new disk. Any suggestions?? Thanks, Mary
You can download the Softwares/Drivers for your printer from these links (similar with the contents on the Hp CD) :
Hp Photosmart D5160 Printer for windows xp 32 bit
or
ftp://ftp.hp.com/pub/softlib/software10/COL15834/dj-41864-2/TF_regna_psp_NB.exe
Hp Photosmart D5160 Printer for windows xp 64 bit
or
Hp Photosmart D5160 Printer for windows vista 32 bit
or
ftp://ftp.hp.com/pub/softlib/software10/COL18384/dj-47558-2/SF_CDA_Full_Non-Network_enu_NB.exe
Hp Photosmart D5160 Printer for windows vista 64
or
Hp Photosmart D5160 Printer for Windows 7 32 bit
or
ftp://ftp.hp.com/pub/softlib/software11/COL30907/dj-76773-1/SF_CDA_NonNet_Full_Win_WW_130_140.exe
Hp Photosmart D5160 Printer for Windows 7 64 bit
or
Hp Photosmart D5160 Printer for Linux
For Mac Drivers, please visit here and follow the instructions given there.
It would be much easier for you and for me if you had mentioned the Operating System installed on your computer where you are going to install the printer. Anyway, select the suitable link for your operating system.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Aug 23, 2010 | HP Photosmart D5160 InkJet Printer
I changed the color ink in my d5160 printer and now the red light is flashing. i can't get the printer to reset it self.
Sorry to hear you are having problems with your printer. Here are some things to check.
1) Is cartridge inserted correctly and all tape remove from cartridge?
2) Are both cartridges in correct chamber?
3) Have you tried unplugging and letting stand for a minute or two and then replugging? (Hard Reset)
4) Do you get any error message on your screen?
5) Is paper fed into paper tray and pushed all of the way back?
6) What if any error message do you get on the computer itself in printers inside coontrol panel?
Let me know if these don't provide an answer and I will gladly assist further.
Scott
Feb 20, 2010 | HP Photosmart D5160 InkJet Printer
Need printer driver for hp D5160
try downloading from a torrent site.! like isohunt
Nov 16, 2009 | HP Photosmart D5160 InkJet Printer
Cuales son tus fuentes?
Primero que nada, muchas gracias por tu pregunta y por darme la oportunidad de despejar (o ampliar) una duda tuya.
Cuando en un modelo de hardware dice que es la Serie 5100, significa que hay mas "subseries" de modelos en esa misma base de hardware, digamos que la 5100 es la básica y la 5160 la tienes tu y tiene un puerto de USB cuando la 5120 no la tiene. Es un ejemplo.
Otro, en cuanto a laptops HP. La serie Pavilion dv8000 tiene varios modelos, la dv8360 tiene 512 MB de RAM mientras que la dv8600 tiene 2GB y cuenta con bluetooth.
Las placas de hardware son una base para crear mas modelos, le quitan o le aumentan algo, pero fisicamente son similares.
Esto contesta tu pregunta?
Recibe un cordial saludo desde Mexico.
- CoolDragon.
Sep 10, 2008 | HP Photosmart D5160 InkJet Printer
HP Photosmart D5160 trouble
i have a stall carrige.. how to fix up that....
Aug 05, 2008 | HP Photosmart D5160 InkJet Printer
HP Photosmart D5160 InkJet Printer Logo
46 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
