Question about Toshiba e-Studio 232 Black and White Copier
Leaves black marks on copies
Machine leaves black smudges - not lines on copies, and not on all of them- inconsistant in smudges- have gotten a few copies that are ok and then it smudges again. I cleaned the scale, rollers, changed toner, blew out toner areas, and it still makes black smudges here and there.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Toshiba Master
  • 1,362 Answers
It could be leaking toner from the recovery area that sis on top of the dum, it removes any toner that was not transfered to the paper. You would have to remove it and empty out the toner.
Posted on Dec 11, 2012
  • 34 Answers
SOURCE: THE COPIES COME OUT ALL SMUDGED WITH INK WHAT'S WRONG.
Hello
in your printer fuser has went bad, just replace toner if its almost empy and fuser and that will take care of it.
Thankyou
Posted on May 15, 2008
  • 990 Answers
SOURCE: radf problems on e-studio 232
Hello sir; As you said everything is ok, then the only thing you need to do is solenoid problem, replace it. but make sure exit roller clean enough.
Posted on Jan 12, 2009
Cogz
  • 1326 Answers
SOURCE: toshiba 2060 marks on papaer
There is no such paper for copiers that I know of in 18 years. What you can do is try to run some blank pages throw the copier. This can tell 2 things if the line gets lighter in may be in the fixing ***'y and the upper fusing roller is shoot, needs to be replaced and or if it dose not clear up you may need a cleaning blade for the drum(OPC) and or the drum and blade as a set. It depends on how old the parts are? You may need to replace all 3 items and a general cleaning. Here is a idea for you are you running LTR or LTR-R you may be able to switch the paper arould to avoid the line all togather. Good Luck.... You may need a service call on the copier. With the age of the copier I might just go with the cheap fix first.
Posted on Mar 12, 2008
  • 990 Answers
SOURCE: Toshiba e-studio 162d makes smudgy black margin
Hello sir; you do need a drum blade to replace at least.
Posted on May 12, 2009
  • 628 Answers
SOURCE: Toshiba 2860-changed Toner cartridge-black line on edge of copy
If drum no problem, then probably need to align the drawer alignment.
Posted on May 28, 2009
BLACK MARK ON THE COPIES OR SCANNED IMAGE
Clean the slit glass under the document feeder. Lift the feeder and find the thin piece of glass on either the left or right side and give it a good cleaning - you marks will likely go away.
Here is a how-to for removing lines from Sharp copiers.
How To Remove Lines from copies prints on Sharp copier
Jan 17, 2014 | Sharp Mx-C402sc mx-C402sc
Black lines on copies and on drum
There are a few things you can do to troubleshoot this problem.
  1. Be sure you are using new, clean paper
  2. Clean the copier's paper rollers, the marks may result from a dirty roller mechanism.
  3. Clean the copier bed's glass plate, smudges manifest themselves in the final copies.
  4. Clear any excess toner that has spilled in the toner cartridge chamber. Remove the cartridge, set it aside, then clean the compartment.
  5. Check for low toner levels. Low toner levels can actually contribute to unsightly lines and blotches on a photocopy
If all else fails, try turning down the darkness of the copies in the settings, this can occasionally lead to lines and marks.
Feb 28, 2011 | Brother MFC-8460N All-In-One Printer
Our Toshiba e-studio250 copy machine is leaving a
i think you machine lost scuner home positin try to adjust the scuner
Mar 25, 2010 | Toshiba e-Studio 350 Copier
When printing dark line down copy
A line down the copy can come from a dirty document scanner lens.
Usually white out or wet ink will smudge on the document scanner. Opening the document cover check the scanner for a dirty glass. Some document feeders have the white roller on top of the small glass window. They have delicate plastice retainers that hold the roller on both ends. Extra care needs to be taken if this roller is removed.
Clean the roller and the glass with wet towel. Shine a flashlight on the glass to see if there are anymore black marks on it.
Use the finger-nail to run across the glass and make sure no debris is on it. Even a spot can make a line on the copy.
Also, a bad fuser roll can cause a black line on the copy. A defective drum unit can cause a line on the copy as well.
If all else fails place a Xerox service call for this problem.
Oct 22, 2009 | Samsung Office Equipment & Supplies
I'm getting black smudge marks on copies. After
I also had this issue, waste tone was comming from the transfer belt, had a good clean out been good for months now.
Aug 11, 2009 | Samsung CLP 300 Laser Printer
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
Waste ink tank over flowing??
Hi, like every ink jet printer, there should be an ink pad(spunch) at the bottom of the printer to collect the waste. That spunch might be full of ink. You could locate it, remove and try to clean it under the water. See if it works
Apr 03, 2009 | Canon i860 InkJet Photo Printer
Black smudge marks along left side edge of paper.
Its probably a defective toner. If the film on the toner drum is scratched it can cause toner to stick to the drum everytime it spins causing the constant marks.
Jul 08, 2008 | HP LaserJet 1320 Printer
Black marks
sounds like a bad rear bearing.causing grease to get into laundry.
May 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Toshiba e-Studio 232 Black and White Copier Logo
492 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
