Question about Sherwood 7100A Receiver
Stereo indicator lamp for sherwood 7100a
Bulb is burned out, need replacement / substutute
Is there a way to repair my Sherwood S-7100A Stereo Receiver? The On-Off-volume dial switch does not click on or off. Could it be the fuse (which visually appears OK)? Or does the switch itself need...
Your best bet is to find a tech who can repair it; it is possible. Or buy another one on ebay--it might be a cheaper fix. These receivers are among the sweetest-sounding ever made and are well worth fixing.
Oct 22, 2013 | Sherwood S-7100a Am/fm Stereo Receiver...
Does the sherwood rx 4105 receiver have analog or digital inputs
Unfortunately the RX-4105 is a stereo only receiver with only analog L/R inputs. You will have to find a stereo output & go in through one of the stereo inputs.
Feb 12, 2013 | Sherwood RX-4105 Receiver
Turn signal
A slow flash indicates that one of the signal bulbs has burned out. You need to check the turn signal bulbs as well as the marker lamp bulbs. The marker lamps on the the side of the vehicle.
Aug 22, 2012 | 1993 Cadillac DeVille
I have a Sony KDF-55WF655 and the bulb blew out and I smelled something electrical burning.
3 blinks is indicating that the lamp door cover isnt making contact so the lamp door cover is either attached wrong or the switch is defective.
Oct 26, 2011 | Sony Grand WEGA KDF-55WF655 36" Rear...
The loudness knob has suddenly stopped working. The knob just spins, won't turn on the receiver at all. Any ideas?
The knobs are usually connected to a potentiometer; basically a variable resistor circuit with a long shaft that the knob attaches to. The knob could be secured to the shaft with a plastic grommet, which can be stripped. It could be attached by a small screw on the knob, and tightening that would fix it. Or, it's possible that the potentiometer itself broke, and would need to be replaced.
If the "pot" is broken, a repair shop should be able to fix it for less than $50. If you're handy with tools, you can take the 7100A apart; hopefully read the specs from the potentiometer; and buy a new one. Replacing it shouldn't take more than a few screwdrivers, some pliers, and a soldering iron...
Feb 06, 2011 | Sherwood 7100A Receiver
My Hitachi 60v710 HDTV does not come on and when in off position lamp lite is red and when on lamp and led blinks red and power blinks blue what is wrong and can I fix it myself
Did you say the lamp blinks red? I assume you meant the lamp status indicator light. That probably means the lamp is burned out. Take the lamp assembly out and inspect the bulb. If you see a visibly burned capsule or broken wire inside, that's your problem (you don't need to remove the lamp from the assembly to inspect it, and don't touch the lamp itself - see next paragraph). When you replace it, be sure you clean all of the vents in both the front and back of the set. Dust-clogged vents will cause a bulb to burn out prematurely, or even explode. You may need to remove the back cover (unplug first!) to clean out a dust filter for the lamp cooling duct.
You can save money by buying a bare bulb and rewiring it into the lamp housing, but be absolutely careful never to touch the new bulb with bare fingers - the contaminants from your fingertips may cause the bulb to explode when it gets hot. Wear disposable vinyl gloves (the kind restaurant food handlers use) for this job. The gloves may be included with the new bulb.
Set a regular cleaning schedule for the vents. How often depends on how quickly the dust builds up. Just don't let them get completely covered with dust.
Sep 22, 2010 | Hitachi 60V710 60" Rear Projection HDTV
Everytime I change the fuse it burns out
Obviously your Flasher is defective or one of the Lamps is intermittent. Federal Law requires the Flasher to quit Flashing if a Bulb is Burned Out or the Circuit to either front or rear has an intermittent connection. Next time it Stays on check the Front Bulb for the side you are indicating a turn. If Both Front and Rear Bulbs are lit then replace the flasher. Flashers do wear out!
Fastest Robe
Oct 19, 2009 | 1997 Dodge Ram 1500 Club Cab
My left indicator isnt working,the rest are though
need more info ??does it work with hazzards on ??all four lights?'
Jun 14, 2009 | 1999 Volkswagen Passat
Lamp light blinks
The blinking lamp light indicates that there is a problem with the bulb. Mine did this when I had used the bulb past it's life and the bulb was burned out. Use the owner's manual instructions to remove the bulb and visually inspect it. Mine looked burned out - it was black with clouds on the glass. If this is the case with yours, replace the bulb, or replace the whole unit. (Bulbs can be costly.)
Mar 21, 2009 | Sharp XR-30X Projector
Sherwood 7100A Receiver Logo
70 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
