Question about Hoover Steam Vac Dual V w/ SpinScrub Vacuum
Spinscrub loud brushes don't spin
I have been through diagnostics on other posts. My turbine seems to be in perfect shape. Is there a tube or something that could be just blowing the air around? The vac still sucks up water, but not nearly as well as before the brushes stopped working. So this is prob related. Grand prize goes to whomever can help me solve this problem. Thanks!
    Genius:
  • Hoover Master
  • 1,239 Answers
Most models have a screen under the machine or behind one of the clear covers on the front. If the screen is clogged it will restrict the airflow.
Make sure the brushes will spin freely by hand.
Posted on Oct 06, 2017
SOURCE: brushes won't spin on hoover steam vac ls
I have the SteamVac Dual and there's a screen on the underside of the unit. It's beneath the brushes and it's red. You have to pull and wiggle it to get it out. With the machine unplugged, lay the unit with the handle on the floor. In the owner's manual ( http://www.hoover.com/pdfs/manuals/F7222900.pdf ) this is shown on page 10 figure 3-2. Clean that screen.
If they still won't spin, then take the brushes out. Again, with the unit on the floor, you simply grab the unit firmly and pull towards you. It's much easier to remove than the screen. I took the brush unit outside and blasted it with the house. You'll have to pull out whatever fur balls are clogging it but eventually you'll see that the brushes spin freely with the water squirting on them. Plug the brush unit back in and - in my case - they started spinning.
Posted on Aug 02, 2008
  • 3 Answers
SOURCE: hoover F7431-900
If the screen is not dirty, and the flapper valve to the turbine inlet is open, then the problem is mostly a stuck turbine impeller. The turbine impeller on my F7431-900 has seized TWICE!! The shaft for the turbine is not made of stainless steel, therefore is subject to corrosion. If you have a handy husband or boyfriend, give it to them, because some disassembly is required to access the turbine unit. After the turbine is removed and opened up, get some P'Blaster and squirt is on the shaft. P'Blaster is a rust removing solvent and is great for freeing up rusty nuts and bolts. Allow the P'Blaster 20-30 minutes to penetrate the corroded shaft. Then, grab the impeller and wiggle it back and forth, until free rotation is achieve. The last time my brushes stopped rotating, and I disassembled the turbine, it was really siezed up. I thought I was going to need to buy a new impeller assembly. But, that P'Blaster is really great stuff for breaking up corroded parts (it's like WD-40 on steroids!). I did need to give the turbine's impeller a good twist to free it up. If you can't get the turbine impeller to rotate, then buy a new one (about $27.00). Then, you can just install it and save a bundle on labor. I think I want to become a Hoover vacuum repairman. Their business must be booming because Hoover is putting out a poorly designed turbine unit. Boo, Hiss...... shame on Hoover for selling us **** like this.
PS You can get P'Blaster at any auto store, like Pep Boys, Autozone, etc.
Posted on Aug 28, 2008
SOURCE: Hoover Steam Vac Dual V brushes won't turn
The brushes are driven with air pressure from vacuum motor. The switch merely opens a small door to allow air flow. usually there is a screen that is plugged that stops air flow which stops the brushes from turning. I too only used the appliance once and it broke. The round disc (turbine) had become jammed with no major obstruction. Cleaned anyway and put back together and it started to work again. I am so done with Hoover--no more of their products for me. To fix. the whole brush motor had to be removed and disassembled and cleaned. Not impressed at all!
Posted on May 11, 2009
ThinkVacuums
  • 144 Answers
SOURCE: Help. The brushes on my Steam Vac Spin Scrub
If you don't have the user's manual for the machine, here it is:
www.thinkvacuums.com/pdf/uprights/Hoover_F5914900.pdf
Check your system for any obstructions that could possibly causing the problem. Also, remove the brushes and see if there's a problem between the brushes and the motor.
Posted on Aug 25, 2009
SOURCE: HOOVER SPINSCRUB WONT SUCK UP WATER...BLOWING AIR OUT
ITS THE DUCT PIECE ON THE FRONT OF THE DIRTY WATER TANK (DWT). ITS NOT LINED UP.
1. TAKE LID OFF OF DWT
2. SLIDE THE LITTLE SQUARE PIECE (5'X5'X1) (THE DUCT) ON THE FRONT OF THE DWT AS FAR UP AS POSSIBLE AND IF IT BENDS FORWARD FROM THE TOP, DO THAT TOO (SOME MODELS OPEN LIKE A DOOR TOP DOWN, OTHERS JUST SLIDE UP AND OUT COMPLETELY)
3. SLIDE THAT DUCT BACK DOWN AS FAR DOWN AND BACK AS IT WILL GO.
4. PUT THE LID BACK ON BY HINGING THE FRONT LATCHES ON AND THEN SNAPPING THE BACK SIDE DOWN.
5. CHECK TO SEE IF THAT DUCT PIECE ON THE FRONT IS LOOSE BY PUSHING ON IT AND SEEING IF IT MOVES UP AND DOWN.
IF IT IS, THE LID ISNT COMPLETELY ON, GO BACK TO STEP 4.
IF THE DUCT IS SNUG, CONGRATS YOU SHOULD HAVE JUST MADE YOUR STEAM VAC **** UP THE WATER AGAIN
Posted on Dec 03, 2009
Spin brushes do not turn
Hi There,
I\'ve written an extensive repair solution on how to diagnosis Hoover SteamVac\'s when the brushes stop spinning. A lot of the times the brushes just need to be cleaned, or it could also be the turbine assembly inside.
Here\'s a link to the diagnosing:
http://www.fixya.com/support/t4286338-hooverspin_scrub_brushes_always_stop
And if you find out that you need to replace the turbine, here\'s a link that shows you step by step how to replace the turbine:
http://www.fixya.com/support/r4530769-diagnosis_fix_hoover_steamvacs_when
Hopefully these were helpful to you. Please be so kind and rate the repair helpful, or leave feedback for me if you found this helpful. This is really appreciated by the Fixya community to do if this was able to fix your problem, and ensures that Fixya experts continue to post free repair solutions rather then just answering the premium questions.
Thanks so much,
Sep 16, 2013 | Hoover SteamVac F5914-900 SpinScrub...
Brushes on my hoover spinscrub model F7411900 wont spin
vanger cheva in post 1 got the correct answer. I just disassembled my f7411900 with some difficulty and took the turbine apart. Sure enough the bearing on the shaft was froze from rust. I was able to free it up in a vice and screw driver big enough to grab and turn the middle of the bearing. I used 3-1 oil and it now is smooth again. Not sure for how long. It was then I found the instructions by vanger above. There is no belt in this unit. The turbine is driven by water that turns the brushes.
Sep 13, 2012 | Hoover Vacuums
How to change the belt?
There is no belt on a Hoover SteamVac. The brushes are rotated by an air driven turbine. If the brushes aren't spinning, you most likely need to replace the turbine assembly.
Jul 05, 2011 | Hoover SteamVac F5914-900 SpinScrub...
The brushes won't spin. I put new brushes on and it still doesn't spin.
Usually when the brushes won't turn it is due to a bad turbine. Insert a screwdriver into the square hole that the pin on the brush fits into, and see if it turns. If it is seized up, the turbine assembly will need to be replaced.
Jun 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Were can i find the belt on a hoover steamvac spinscrub the wheels quit spinning on it
There is no belt on the Hoover SpinScrub. The brushes are turned by an air driven turbine. To test the turbine, insert a flat screwdriver into the square hole that the pin on the brush assembly normally fits into, and see if the fitting turns. If it doesn't turn, the turbine has seized up and will need to be replaced.
Jun 20, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Brushes don;t spin
First remember that the speed switch must be set to carpet. The handle must also be tipped back. If this is not the problem, you probably have a bad turbine assembly. Remove the brush assembly and insert a flat screwdriver into the square hole that the pin on the brush fits into, and see if it turns. There will be some resistance. If it is seized up, the turbine unit must be replaced. To prevent rust damage to the turbine, always remove the upper tank during storage, and squeeze the trigger to drain fluid from the machine.
Feb 05, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Scrub brushes not rotating
Hi There,
You'll need to first diagnosis why these brushes are not spinning. When the SpinScrub brushes on a Hoover SteamVac don't spin, this can be 1 of 3 different things.
In order to diagnosis which one of the problems is causing your problem, here's what you'll need to do.
Step 1. The first and easiest thing you should check is to make sure that that the brush speeed selector knob on the top of the machine is turned on, and is not in the off position. This may sound obvious, but I've had several cutsomers that have come in with this exact problem, only for the brushes to be turned off. Also make sure that the SteamVac's handle is reclined, and not in the upright position. There's a switch inside that shuts the brushes off when the SteamVac is moved into the upright position. If the brushes still are not spinning, move on to step 2.
Step 2. You'll need to remove the SpinScrub brushes from the SteamVac. Turn the machine upside down so that the brushes are facing upwards. There are four clips that hold these brushes in place. You'll need to remove the brushes from the machine by squeezing the four tabs while pulling upwards at the same time. The picture actually only shows the two tabs on the right hand side being squeezed (my left hand was holding the camera, lol), but the tabs on the left hand side are in the exact same location:
Step 3. Once the brushes have been removed, plug the machine in, make sure that the handle is reclined. Look in the SteamVac where the brushes used to be. You should see a hole that is square shaped where the brushes go into.
Turn the machine on, and look to see if this square shaped hole is spinning. If the hole is spinning, this indicates that either the brush block itself is bad, or there maybe something clogged (such as pet hair) in the brushes that's preventing them from spinning. If the square hole is not spinning, this indicates that your internal turbine brush gear has gone bad. Here's a link to a repair that I've written on how to replace the internal brush turbine gear if the square shaped, female receptacle hole is not spinning.
If the square shaped hole is spinning, here's what you may do to see if the brush block is just jammed up with debris, or if the brush block itself is bad and needs to be replaced:
Step 1. I'd say that 60% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem.
you should look at the brush stem that goes into the turbine inside the machine. This is the green pole pictured in middle of the brush block. Examine this pole to determine if the top of it has broken off. It should exactly how the picture shows it. Make sure that the plastic has not broken. If the pole has broken, you will simply need to replace the brush block.
It can really only be one of these three things that are causing your brushes not turn. Here are links to all of the products that possibly need to purchased (if the brushes weren't just clogged) on our website for the model that you listed this repair under, the Hoover F7425-900.
- Hoover Brush Turbine Gear Assembly Part 43191009
- Hoover Brush Block SpinScrub 6 Brushes For F7425-900, Part #
48437030
I hope that this helped you figure out the problem. If you have any follow up questions, please use the Clarification Request form here on Fixya and I'll be more then happy to follow up with you and help you out. If you found this helpful, may you kindly please rate my repair helpful by clicking the thumbs up icons in the top right hand corner of the repair? This is really what keeps Fixya repair experts coming back to give free repair advice, and helps Fixya users continue to get the free replies without having to pay for answers. It's greatly appreciated.
Thanks,
Chris J.
GoVacuum.com
Apr 13, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
New Hoover Steam Vac's brushes do not spin
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine will have to be replaced. You can find a genuine hoover replacement part by following the link below.
Turbine Brush Gear Part # 43191008
F5914 Parts Link
http://www.usavacuum.com/Hoover-F5903-F5904-F5905-F5910-F5912-F5914-F5915-s/138.htm
Feb 28, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Brushes won't spin on a Hoover Steamvac SpinScrub Model F5918-900
well the hand tool works off the suction of the machine and has nothing to do with the turbine that controls the brushes. if you can get the part i can walk you through taking it apart. when you write back, let me know what the model num of your machine, so i can give you the right directions. hope this helps
Aug 02, 2009 | Vacuums
Spin Scrub Brushes won't turn
If the brushes quit spinning, either the brush block shaft that goes into the turbine broke off, or the turbine is bad. This unit is tricky to take apart and then put back together again. But pull the brush asm off, then start taking out screws. But if after you pull off the brush block, look up where you will see a small square hole, turn unit on and if not turning, usually the turbine is the cause and will have to be replaced.
Jan 13, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Hoover Steam Vac Dual V w/ SpinScrub Vacuum Logo
41 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
