Question about Acer AL1917 LCD Monitor
AL1917 doesn't show a picture on Lenovo 3000 n100. The latter says someting like "no external monitor is connected"
I used 2 work with external Acer AL1917 on my PC. After running some program, which checks drivers, I can't use my external monitor ("no signal" appears on its screen). Also the combination Fn+F7 no more works on PC. When I tune the Presentation Director 2 work with AL1917 as an external monitor, PD behaves as if the external monitor can't be found. The Driver Detector reports that AL1917 driver is OK.
  • 198 Answers
SOURCE: Acer AL1916W 19" problem
Hello mat78, Unfortunatelly the problem is hardware based. You will need to have the monitor repaired in a service center. Here's why: LCD/TFT monitors don't produce light themselves. They are composed by a matrix of transistors (TFT - thin film transistor) that have the property to reflect or allow some light (certain wavelenghts)to pass through them. They don't produce light by themselves. Instead there is a fluorescent tube (neon like) light inside the monitor and that's the light source used in order for you to see what's on the screen. A flourescent light is suposed to last pretty much, i don't think yours has a problem, you say it works for some seconds or so. Instead your problem is most probable with the inverter circuitry that powers on that light. It's a common problem among these types of monitors but in your situation i don't think it will be an expensive repair. In the case that the screen is dark (in a dark place you can't read or view anything on it) but if you apply light to it ( a flashlight or something) and you see something, then the problem is most likely to have occured with the invertor. Try to ask at a local service center for a repair, this shouldn't be an expensive procedure. Hope this helps.
Posted on May 24, 2007
  • 108 Answers
SOURCE: ACER LCD monitor no image, appears white color only
Quickly go to the Acer website and check FAQ's and while there also find out how to get an RMA to return it. My guess is you have a bad monitor. At $200 roughly for a replacement I would hustle. I am assuming you got nothing but a white screen but did get video on your TV.
Posted on Jan 24, 2008
  • 198 Answers
SOURCE: unable to install AL1916w lcd driver in xp
i buyed the new al1916w lcd monitor ,i tried to install the driver for it.
i also downloaded the driver from acer site ,when i looked in device manager ,i found two plug and play monitor
plz check this link
<a href=""><img src="" border="0" alt="Image Hosted by"/></a><br/>
then i selected update driver from the right click and selected the folder wherethe driver was stored ,after searching windows cannot find the drivers.
i am sure that the folder has the driver downloaded from the site.
check this link
now how can i install the lcd monitor driver?
any other method?
Posted on Feb 20, 2008
SOURCE: Acer al1916W Driver updates
Problems like this are usually the fault of the video card and not the monitor. Does your video card support 1440 X 900? Try updating your video card drivers.
Posted on Mar 10, 2008
  • 1073 Answers
SOURCE: Computer won't recognize monitor driver
Its the usb, if u connect the monitor via the standard port, the vga port, it will work. If your monitor only have an dvi cable you can fix that by an adapter. That adapter should be an DVI to VGA.
Good luck to you
Posted on Dec 11, 2008
No display but OS is booting & running as evident from sound.No display in external monitor also
Does the power on light show on either the OS monitor or the external monitor? If so, and no picture, it is likely to be the graphics card has failed. If in warranty return.
Mar 28, 2014 | Lenovo 3000 N100 0768 - Pentium Dual Core...
External Acer AL1917 stopped to work with Lenovo 3000 n100 as an external monitor.
No signal means you have a different input enabled TV/HDMI/VGA are set on some input other than the one you need for your cable. Check the menu settings, if you have a remote, try the input button and try a different setting
Jul 09, 2017 | Acer AL1917 19 inch LCD Monitor
Lenovo 3000 n100 webcam revert image
what do you mean revert? you mean inverted? you probably don't have the correct webcam drivers installed. go here:
Feb 05, 2012 | Lenovo 3000 N100 Notebook
How do i enable my wireless connection on my lenovo 3000 N100
The wireless switch is at the front side of your Lenovo 3000 N100. (see pic.1). Press Fn+F5 to confirm if your wireless switch is on. If required, switch on the physical switch for your wireless connection.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
(for Windows only)
Mar 29, 2011 | Lenovo 3000 N100 Notebook PC
Lenovo 3000 n100 lcd display works but only less than a minute before display goes black. Connect an external monitor and it works fine.
possible problem is your led light on your LCD or its Flex. you might need to have it replaced. Try to check your LCD when it turns black under the light if you can see a dark image of your desktop. If you can see your desktop then the backlight has a problem. If there is no display, your LCD needs to be replaced.
Aug 13, 2010 | Lenovo 3000 N100 0768 - Pentium Dual Core...
I got black screen a few seconds after reboot my LENOVO 3000 N100, type 0689 - 2BS, Laptop run normally without screen light, I need to flash screen in order to read it. I tried unplugging the battery and...
Hi. I think the LCD screen of your laptop needs a replacement because I think the backlight on that LCD is already busted thats why you need to point a flashlight or some sort of light just to see the display. Powerdraining your computer wont work because this already a hardware issue with the LCD, that's why when you switch display with your monitor it works fine. I would suggest replacing the LCD of that laptop or try calling Lenovo tech support if your laptop still under warranty so that they would replace it for free. This is no. to contact for your Lenovo laptop US/Canada 1-800-426-7378, Australia 1-300-880-917. Hope this Helps
Feb 28, 2010 | Lenovo 3000 N100 Notebook
Will not run on battery
probably a bad battery. see if you can try it with a different one.
Aug 02, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Screen goes dark after a few seconds
try fn+f7 that Toggle external monitor,and disconect external monitor before starting
Jun 13, 2009 | Lenovo 3000 N100 0689 Notebook
Lenovo 3000 n100 notebook monitor turns green
my lenovo 300 N100 when turnned on the laptop from charger and Monitor
Apr 26, 2009 | Lenovo 3000 N100 0689 Notebook
Lenovo 3ooo c100 notebook
That is either :
Faulty LCD ribbon cable or connector slipping off.
Faulty LCD screen.
Faulty video adapter on laptop motherboard.
To find out you connect laptop to an external monitor.
If the problem persists on external monitor, then you have a faulty video chipset on motherboard.
If the picture is good on external monitor, then problem concerns LCD panel , or LCD cable on laptop.
Apr 06, 2009 | Lenovo 3000 C100 Notebook
Acer AL1917 LCD Monitor Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
