Question about Apple iPhone Smartphone
I phone will not go on
  • 4,889 Answers
Are you sure the battery is charged? If yes does it display the itunes logo or something? If yes then this problem is probably due to a failed software update.Post back if you see anything on the screen so that I can see you through this.
Thanks,
Sai.
Posted on Jan 13, 2009
Cell phone freeze
If the Phone says Phone Freeze it's because of wrong code entered.It's Samsung Phone ?Because samsung Phone will say Phone Freezed..You need to Unfreeze it using the Unfreeze Code.You can get the Unfreeze code for Samsung Phone European Phones at Unlocking4u.com/samsung-europe-unlocking-service/rs6wp10/ and Unfreeze it
May 25, 2012 | Cell Phones
Tip
Water problem with cell phones
When ever a phone drops inside the water, first remove the battery cause the battery life might be damaged,and also in that process the phone is still working because the battery is still inside the phone.<br /><br />You will need to service the phone for the phone to be free from water,cause if the water dries inside the phone it will damage an IC or a chip inside the phone and it might cause more damage to the phone.<br /><br />After, disassembling the phone is the next step.<br />Get a phone screw and unscrew the phone from the back by removing the battery and you will see some screws, unscrew possible screws and open the phone.<br /><br />Get a methylated spirit and a small brush, remove the board of the phone and deep the brush inside the methylated spirit,brush gently on the board of the phone. After brushing, get a dryer to dry up the board of the phone and live it for a while to dry.<br /><br />After some minutes,assemble the phone back and fix in the battery. Make sure during the process you are charging the battery of the phone.<br /><br />I guess that's all you need.<br /><br />Note: if the battery has stayed too too long on the phone and am sorry after the water splash, it might not come on after this all process, that means you will have to flash the phone because the battery might have damaged the memory of the board of the phone and will not power up the phone because the phone is too weak to power.<br /><br />Flashing of the phone will restore back the phone memory.<br /><br />You can visit the web to learn more about flashing of phones.<br /><br />
on Jul 05, 2011 | Nokia 6300 Cellular Phone
My sony ericsson k550i dosent startup ,it just show few red flashes and the its dead
Hi, There are different possible things that can cause Your Sony Erickson cell phone to malfunction he way it does. Possible reasons below:
The battery,,
The Phone memory.
The battery of the phone can be the problem.How Sometimes when a phone cell phone battery is weak and It might not be able to power up the phone. You can test the battery by using another battery to test on the phone,or you can test the battery by using the battery on another phone to test if the battery is still working properly.
The phone memory might also be the problem. When an application is being downloaded on a cell phone or being Transfered to another cell phone through Data cable or Blue tooth, it is easy for VIRUS to affect the phone and when a VIRUS affects a cell phone,the cell phone will malfunction.
To fix a malfunctioning phone like a VIRUS infected phone,you will need to flash the phone memory of the phone.
When you flash a cell phones memory,it will restore back the phone to it default state.
You can use the below links to know more on how to flash a phone.
www.hubpages.com/hub/How-to-Flash-your-cell-phone.
Good luck to You.......
Feb 01, 2011 | Sony Ericsson K550i Cellular Phone
No dialtone
It just sounds like the problem with the phone itself. try with the diffr phone and phone cable. If it is a cordless phone, try with the corded phone.
If you have spliter or homewiring, please isolate them and connect the phone directly the phone adapter.
- To check whether it is a phone problem, remove your phone from the phone adapter and make sure phone light on the phone adapter is solid, then make a test call from your cell phone to your phone, you can hear ringback tone on your cellphone which indicates your phone line is actually working fine. After that connect your phone back to phone adapter and check the phone light status whether its blinking or no light at all. make a test call to your phone, call may go to voicemail or may give busy signal. So it could be phone trouble.
- You may also call techsupport and ask them to assign the phone number to phone port2 ( phone adapter has 2 phone ports, by default, line assignd to port1 ).
- If your Online account has a facility to move a number from port1 to port2, you can try it.
- Laxman
Nov 24, 2007 | Linksys SPA-2102 NA Analog VoIP Adapter...
Apple iPhone Smartphone Logo
15 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
