Question about Panasonic TX-36PF10 TV
Hi I have a Panasonic 36" TXPF10 TV. THERES different colors on the screen like a SPECTRUM, is there anyway of fixing this
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
Its what we call a purity problem on this 36 inch set and only two things cause it, the set (not getting too technical) uses a single part connected inside that when set is turned on powers a large coil around the picture tube--it just demagnetizes the tube---what happens is there is a single black square part there not much bigger than a cube of sugar---easy to spot as it will have three leads in a triangle shape---
What you will likely find if you can get the set apart---Its a real heavy set is follow the power cord to the board---real high chance you will find one of the three leads on that part has broken loose from the board, happens from all the heat at turn on that part gets real hot for a very short time.
You would be smart if one lead has come loose to solder all three---the part is often referred to as a thermistor--as it gets hot it cuts voltage off to the coil.
The other possible cause is only possible if set fell forward or was dropped, in that case the damage is fatal and cannot be repaired.
Let me know if questions.
Posted on Dec 11, 2012
3 Suggested Answers
  • 88 Answers
SOURCE: i have a old tv 36 inch panasonic ct-36d30 my tv
sound like yoke short problem. replace same yoke as possible . good luck!
Posted on Apr 29, 2010
SOURCE: Panasonic TV CT-32631U 36
Dry joints on frame output ic
Posted on Dec 11, 2011
Limited color on screen primarily blue, white and green. I use to be able to fix by giving the screen a gentle wiggle but color spectrum is gone.
Sounds like you have a bad joint on the tv circuit board somewhere.There is another thing it could be if you have a scart lead connected. Pull it out and check to make sure none of the pins are dissapearing inside the plug. Sometimes they slip inside. Check both ends of the lead.
Feb 16, 2012 | Panasonic TCP42C2 42 in TV
I have a old tv 36 inch panasonic ct-36d30 my tv
Feb 15, 2010 | Panasonic CT-36D32 36" TV
Panasonic Viera missing the red color spectrum?
Ours is doing the exact same thing! I came here hoping to find an answer. Did you figure your tv out?
Nov 26, 2009 | Panasonic TC-32LX60 32 in. LCD Television
Screen comes on all red 50 inch panasonic viera
the rest of your color spectrum in you r tv has burt out
Aug 21, 2009 | Panasonic TH-50PX75U Plasma HDTV
Purple area on the top of the screen
need to degause device to fix that color
Jan 11, 2009 | Panasonic CT-36D32 36" TV
PANASONIC 36" TAU --- NEED HELP
Sounds terminal. Companies build things with "planned obsolescence" in mind. In other words. You buy a TV today, and the warranty says it's good for 4 years. 4 years and 3 months later, it dies.
I hope someone else can help you.
Good Luck!
Apr 01, 2017 | Panasonic CT-36D32 36" TV
Panasonic PT-50DL54 50 in. Color spectrum off
Yes, I have a cable box, and I do get high def channels.
Jul 09, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Color problem
Replace D805 (?) Thermistor for permanent fix, manually
degauss with coil is temporary........T.
Oct 29, 2007 | Panasonic CT-36SF37 36" TV
Panasonic TX-36PF10 TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
