The source button on my tv remote has just stopped working its a hitachi rc1800. i can turn over and the volume its just the sourcs and the 4 colours dont work please help me
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Single buttons not working is rare but not unheard of .
Get the remote tested so you know, most shops have a tester==point remote at it and press any button and if good tester reacts.
Many digital cameras in a very dark room will react in same way when remote pointed and push buttons with a tiny flash of light on the camera display screen.
This tells you if any are not sending.
Someone else just had a similar question and I dug out a old tip of mine, here is the link and its on this site with how to correct if those buttons are not working.
http://www.fixya.com/support/r4037663-repair_remote_control_not_working
Have a look.
Posted on Dec 11, 2012
SOURCE: Samsung TV remote control
I HAVE THE SOLUTION TO THIS PROBLEM.
Confirmed with Samsung tech support. Problem is with remote. to fix, simple take the batteries out of the remote. Press and hold the UP Volume button for 2 Mintues (no cheating, it has to be at least 2 minutes), this Reset's the Remote Control. Put the batteries back in. Bob's your uncle. all fixed.
Posted on Jan 26, 2008
  • 1694 Answers
SOURCE: Pregramming my RCA Gemstar Video Plus remote with no codesearch button!
www.remotecodelist.com ........................................T.
Posted on Mar 22, 2008
dinomb
  • 16 Answers
SOURCE: Harmony 880 Logitech tv remote - won't change channels on direct tv
you may need to reprogram your remote, or, if you have your profile setup on the harmony website, reload from there
Posted on May 11, 2008
SOURCE: My samsung remote...model #BN59-00599A is
try removing the batteries and pressing every button one at a time. If it still fails to work contact remotes.com
Posted on Nov 26, 2008
SOURCE: my sky remote wont control the volume on my tv
Hi Re Easytouch 42" HD TV - look for Hisense - I took a guess and LCD3204 EU code 376 - remote works but buttons don't tally up - getting there slowly!
Just bought a madeforyou 4:1 remote that is programmed on my PC.
Ok - not proper solution yet but nearly there!
Posted on Aug 05, 2009
I have a Proscan pledv2488a. There is a disk in the DVD player, but I cannot find a way to eject it. There appears to be no eject button on the remote. What can be done?
Do you have the original remote or a universal remote? On the original remote, the Eject button is also the Favorites (FAV) button. It's just below the Volume - section of the Volume toggle on the left side of the remote. The button has an upwards arrow above a line on it. You probably need to set the source to DVD for the Eject button to work properly. (If the source is TV, the button will add or delete the current channel to the Favorites list.) You can cycle through the input source options by pressing the Source button on the TV or the remote. On the TV, the Source button is between the Power and Menu buttons. On the remote, the Source button is on the right hand side above the Up arrow key.
The manual for the PLEDV2488A is available from Proscan at the manufacturer's site: http://www.proscanvideo.com/product/PLEDV2488A . Click on the Downloads tab. The direct link is http://legacy.curtisint.com/html/CustService/Manuals/PRO_PLEDV2488A_EN.pdf . Page 8 describes the remote buttons.
I hope this helps.
Dec 24, 2016 | Proscan Televison & Video
Buttons stopped working
If there is a tv button on the remote, try pressing that..
Chances are its damaged and you might need to order a new one from Hitachi or possibly use a universal.. With remotes there really isnt much you can do when they stop functioning.
Jul 17, 2008 | Hitachi VT-RM391A Remote Control
No sound
  • 1 Make sure that your audio cables are plugged in properly to the correct ports if your audio is distorted or noisy. Every cable should be inserted completely. If you still encounter bad audio, replace the cable and then attempt to use a different device with the old cable. This will help you pinpoint the source of the bad audio problem.
  • 2 Use the "Volume up" button on the remote or TV buttons panel to turn up the TV audio volume if the volume is quiet. If the volume is still quiet, check to see if your audio source device has volume settings. If it does, turn the up the volume on your device (see your device documentation if you need help with this).
  • 3 Press the "Mute" button on your remote control to disable the mute function if you can't hear any audio. Once disabled, press and hold the "Volume up" button on your remote control to turn up the volume. If there is still no audio, press the "Menu" button on your remote control, select the "Audio" menu, and ensure that the "TV Speakers" are set to "On." If you are still not having any luck and are using the built-in TV tuner, open "MTS Audio" inside the "Tuner" menu and make sure it is set to "Stereo/English." If there is still no audio, verify that all your audio cables (including the antenna cable if you are using one) are plugged securely into the proper ports on your TV and audio source device (if applicable). If you are using an antenna, reposition it to a clear, open area; preferably near a window. If your audio source device has audio settings, check to make sure they are set the way they should be (see device documentation).
  • Read more : http://www.ehow.com/how_7498064_troubleshoot-vizio-sound-problem.html
    Mar 08, 2014 | Vizio Televison & Video
    My tv is a hitachi hd ready flat screen plasma tv and i am using universal remote control The tv was working fine until i swtiched it off and hit one of the buttons on the remote - possibily the av...
    What are u using for a signal source? Cable, Satellite, Over the air? My best guess is that you hit a wrong button such as the "source" button and the remote doesn't know what device you are wanting to opperate. Press volume up then down and see what light lights up?
    If it is other than "TV" then you probably have the wrong device selected... Hope this helps... Sincerely HDTV GURU JAY
    Mar 15, 2011 | Hitachi Televison & Video
    Remote control has stopped working.
    your remote needs to be put back in TV mode. press the tv button or slide the switch to tv
    Apr 07, 2009 | Samsung TV Remote Control
    I signed on last night, asked a couple of questions, but the info sent to my e-mail didn't have anything to do with the questions I asked. Noticing in the forum, several people has the same problem:...
    Howdy Mike-d. here, mikedee4@gmail.com
    Hi CindyCee,
    I have tried to post solutions, but they seem to be too long, so I will have to post more than once to get the info to you.
    First part- the "Line-In" Video Source thing many people are having fun with. Try these options from the Samsung FAQs website.:
    How Do You Switch Video Sources? spacer.gif Depending on the model TV you have, there are up to four ways to change the video source:
    • Through the on-screen menu controlled by your remote
    • Through the on-screen menu accessed through the Menu button on your TV's front panel
    • Through the TV/Video, TV/Component, or Source button on your remote
    • Through the TV/Video or Source button on the front panel of your TV
    Your TV could provide any combination of these methods. Instructions for all the methods are below
    Changing the Source Using the On-Screen Menu Controlled By Your Remote To use the on-screen menu of your TV controlled by your remote to change video sources, follow these steps:
    1. Turn on your TV.
    2. Press the Menu button on your remote. The Main Menu appears.
    3. Select Input, and then press the Enter button. The Input menu appears.
    4. Select Source List, and then press the Enter button.
    5. Press the Up or Down arrow button on your remote to select the signal source, and then press the Enter button on your remote.
    6. Press the Exit button on your remote to exit.
    Changing the Source Using the On-Screen Menu Accessed Through the Menu Button On The Front Of Your TV To use the on-screen menu of your TV accessed through the Menu button on the front of your TV to change video sources, follow these steps:
    1. Turn on your TV.
    2. Press the Menu button on the front of your TV. The Main Menu appears.
    3. Use the Up or Down Ch button on the TV to select Input, and then press the - or + Vol button. The Input menu appears.
    4. Use the Up or Down Ch button on the TV to select Source List, and then press the - or + Vol button.
    5. Press the Up or Down Ch button on your TV to select the signal source, and then press the - or + Vol button.
    6. Press the Menu button to exit.
    Changing the Source Using the TV/Video or Source Button On Your Remote To use your remote to change the video source, follow these steps:
    1. Turn on your TV.
    2. Press the TV/Video or Source button. The current source appears on the TV screen.
    3. Press the TV/Video or Source button repeatedly to cycle through the available sources. Stop when you reach the source you want.
    Changing the Source Using the TV/Video or Source Button On The Front Of Your TV To use the TV/Video or Source button on the front panel of your TV to change the video source, follow these steps:
    1. Turn on your TV.
    2. Press the TV/Video or Source button on the front of your TV. The current source appears on the TV screen.
    Part 2 -next
    Jan 20, 2009 | Televison & Video
    ILO'26HD got stuck, its freezed
    Yes, Walmart sells ILO, I would not buy that brand. Anyway I am not familiar with the model of the tv, but it should have buttons on the front bottom or right side of the tv so you can change the source and change the volume. So my questions, does anything on the remote work? Do the buttons on the tv work? The DirectTV should not be interfering. It was working fine, correct?
    Aug 14, 2008 | iLO 2600 Television
    Mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
    Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
    Jun 27, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
    After programming my new universal remote, the tv keeps changing chanels! wont stop!
    you need to program your remote control. take the battaries out. and maually turn the tv on. then hit the source you want to view. for example, I want to control the tv set. I push, code search and hold it then push the source button and then release the source button and then release the code search button. now, aim at the tv and then keep pressing power button till it goes off. when the tv is off, hit return or set or something like that.( every remote has different calling for it but still the same function) it should work. try it and let me know.
    Mar 06, 2007 | GE HO976855-Device Universal Remote with...
    Televison & Video Logo
    191 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
