Question about Pegasus Technologies Plumbing
How to fix a broken faucet - Pegasus Technologies Plumbing
  • Jack Duff
    Jack Duff Nov 07, 2017
    It is a bummer that your faucet is busted. I have been having some issues with my faucet as well, so I have been looking for some info online. Have you considered calling a plumber? It makes sense that a plumber would have the right knowledge and tools to fix the problem quickly. Best of luck to you! http://www.richardsplumbingrepair.com/se...
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 27 Answers
Simplytighten packing nut located at base of valve handle
Posted on Dec 21, 2012
Stiff cold water handle bathroom Hansgrohe
If the handle is hard to turn it is most commonly caused by water deposits in the handle or in the cartridge below. I would try removing the handle to ensure it turns freely when not installed on the faucet. If not you can clean it with CLR to remove the water deposits that are making it difficult to turn. If the handle turns freely when not installed you will need to remove the cartridge and inspect it to ensure it is not broken or damaged in any way. There could be debris in the cartrige that has either made it hard to turn or broken the ceramic disks. Our handles are easily removed by turning the bell shaped ecutcheon below the lever or cross handle. There are not set screws that hold them on. If you need further information feel free to call me at 1-800-334-0455. Press 2 for tech and ask for David Scarborough.
Aug 07, 2012 | Hansgrohe - Lavatory Faucet - Centerset -...
How do i fix broken handle
HI, The tool you are looking for is a Basin Wrench. Google Plumbers tools pictures. I am sorry I can't provide you with a picture myself, kind of new on the computer. Good Luck. Home Depot, Lowe's or a hardware store has them.
May 21, 2010 | Kohler FortĀ© Widespread Lavatory Faucet...
Ihave a two handle Moen bathroom faucet that the right handle came off showing a broken plastic part inside, how do I get the broken part out?
There is a little cap on the top of the handle, after removing in there is a philips screw under that and that will release the broken plastic part.
Mar 18, 2010 | Moen Kingsley Two Handle Bathroom Sink...
Kitchen faucet single handle pull-out. The base of
I have the same problem with an American Standard Reliant Kitchen Faucet that wont swivel anymore. I called American Standard and they are sending me the replacement parts to fix it free of charge, I have had mine 6-7 years and they said it was under warranty. Call 800-442-1902. Good Luck
Jan 09, 2010 | American Standard Kitchen Faucet 6310 020...
How do you fix a no flow problem on a Franke Orient-Express faucet?
Close the main water valve, and take the Franke Orient Express faucet off from where it is installed. Check the valve, by opening the faucet. Blow air into the inlet hole, and feel the air coming out of the other end.? If there's none, unscrew the top case using an adjustable wrench, and find out if it is broken or just clogged up. If broken, you have to replace it. If clogged, just clean it up. Also, check if the gaskets
are still okey.
However, if you feel the coming out, close the faucet
and repeat the check up. You must not feel the air
out since it is closed. Your faucet under this condition
is therefore alright. Your problem now will be the pipe
lines going to your faucet. I hope this will not be the
case since this will be a major problem. This will be
the worst scenario, since it involves a repiping of the
lines.
I hope it will be just the faucet problem that can be
easily solve.
Nov 27, 2009 | Water Heaters
Need to fix a broken moen kitchen faucet
I had the same problem with my Aberdeen single lever with a pull-out sprayer a few months back. If you are the original owner of the faucet, it's under warranty; you shouldn't have to pay for any parts. Call: 1-800-BUY-MOEN (1-800-289-6636) and tell Customer Service what the problem is. They will send you the Handle Mechanism Kit at no charge. (Mine was part #93980 for my Aberdeen faucet, but yours may be a different part number.) It's tricky to take apart and get back together but my husband and I have zero plumbing experience and got it all fixed in about 20 minutes. The Moen.com website also has exploded parts diagrams of all their faucets so you can identify exactly what part you need, and they have some little videos and slideshows to show how to replace parts. If you can't reach Customer Service on the phone, you can go to "Contact Us" on their website and email them a description of your problem.
Jun 17, 2009 | Moen Plumbing
Moen Bath Tub Faucet
Hi varn4620,
I'm Harvey the Master Plumber.
Your question is: You had to replace the faucet in the tub due to a broken plastic piece in valve stem. Bought a Moen ripped the wall out and put new faucet in. Went good untill we turned the water on and the shower rained on us. Tightened everything you could find to tighten .Every time the water is turned on the shower rains. Can this be fixed or is the faucet broken?
Is this new faudet a single handle? If so I"ve had this experience also. Most of the time it's because the guts were not lined up properly at the factory. You may have to play with it a bit.
Turn off the water and take the handle off and remove the sleave, remove and rotate the guts. Try 90' at a time. Turn water on to try it. Useually one of the other 3 positions will be right. The correct position is there, but it may take time to find it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Moen 2919 Chateau Two Handle Tub and...
Plumbing Logo
309 people viewed this question
Top Pegasus Technologies Plumbing Experts
Don Numinen
Don Numinen
jdthefixer
Andrew Bugbee
Are you a Pegasus Technologies Plumbing Expert? Answer questions, earn points and help others
