Question about Home
Tuscany holland tub handheld shower faucet Putting in basemencan the distance between aterspout and shower head be shorten and will 1\2in pvc be ok model #673 7247 phone # 269 651 8920
Can the distance between waterspout and shower head be shorten? And will 1/2 in pvc be ok?
    Sergeant:
  • 462 Answers
Wouldnt recommend pvc visit your local hardware store for best recommendation i can give you where im not familiar with the setup if it is inside the wall enclosed copper or crimped waterline usually used
Posted on Dec 12, 2012
  • 27 Answers
SOURCE: I have a Moen single handle tub/shower faucet. I
Your problem is in the water restrictor located inside the shower head. All plumbing manufacturers install these small plastic internal blockers to reduce water down to 2.5 gals per minute. In your case, this restrictor is most likely filled with sediment which is restricting it even further. Remove the shower head from the curved shower pipe. Look inside where the water goes through it. You should be able to see the restrictor. Maybe you can flush out the sediment. Otherwise, remove it and I'm sure you'll get more pressure then originally installed. Because most restrictors are sort of plastic screens or cones, I usually put a wood screw through the center of this product and then once a few threads bite in, I use a plyers on the head or the screw and pull outward while holding the shower head in a stable position. If you are able to get it out, technically your "out of code" because now your going to get all the water it can really supply.Most people are delighted to have it gone.
Nimsgame
Posted on Feb 15, 2011
  • 21 Answers
SOURCE: single handle tub faucet will not divert to shower
the diverter on the tub spout is bad you need to replace the tub spout or the pull up diverter if its a separate piece if you have the owners manual with a parts diagram you can order it on line from the manufacturer or a plumbing supply store. you will need to unscrew the tub spoup from the wall to do this use a broom handle or something similar inserted inside the spout and turn it to the left to remove it from the wall
Posted on Dec 03, 2009
  • 12650 Answers
SOURCE: water steams out of shower head when tub faucet is on
check the tub faucet the pull lever maybe slightly faulty causing back pressure in line and pushing water up to shower head --u may have debris in tub line causing partial blockage -or u have alot of water pressure coming in and it is to much for the lines to handle and it is pushing up to shower head
Posted on Mar 02, 2010
jyackle5
  • 8197 Answers
SOURCE: distance from floor for shower head, water
Look at link below to get the measurements you need.
http://www.moen.com/shared/pdf/instruction_sheets/ins2437b.pdf
Good Luck and please rate 4 thumbs for the free answer
Posted on Mar 27, 2010
  • 4340 Answers
SOURCE: leaking shower/tub faucet, looking for replacement
Call Moen directly. They will ship what you need to your door, for free.
Posted on Sep 18, 2010
We have a tuscany/Asti tub and shower faucet and we just installed it and when we turn it on the water starts coming out of the shower, without pulling the knob for the shower to turn on. Any ideas?
The knob is most likely binding or just stuck a little try putting a drop or two or oil, WD-40, or even cooking oil on the knob shaft, work the shaft up and down to spread the oil and see how it goes. Worse case you have a cracked knob shaft and then you will have to take it back where you bought it or see if they can give you a knob shaft and replace it, as I said worse case scenario. Good Luck...
Jun 04, 2011 | Home
On new Moen shower faucet, when I turn on faucet, water drips from shower also.
The faucet was installed upside down.
The shower riser pipe in the wall is to short( the distance between the faucet and shower head).
One of the biggest problems is if your shower faucet was installed with Pex pipe to the tub spout. Pex pipe will restrict the flow and force the water back up and out of the shower head.
The tub spout must be piped with at least 1/2 brass pipe nipples and fittings, or 5/8 OD. copper pipe and fittings.
Hope this helps, if you further questions please let us know.
Sep 08, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Installation of multichoice valve trim series 13/14
From rim of tub the spout should be 4" up. From spout to valve body is 8" between. Shower head height is typically from the floor is 72" to 78" in height. Hope this helps, please rate on it's helpfulness and thank you for using FIXYA. Have a great week. Jeff
Apr 06, 2010 | Delta & Single Handle Shower Faucet
Water steams out of shower head when tub faucet is on
Feb 26, 2010 | Delta & Leland Lavatory Faucet
Delta 134900 handle Water coming out faucet and shower both
well the Diverter is not working it dose not matter the distance. when applied it should shoot the water to shower or tub if not working will come both.
Jun 15, 2009 | Delta & Single Handle Shower Faucet
Just installed shower and faucet in bath tub when you turn the water on the water comes out of the faucet and shower head. When you pull the lever for just the shower the water cuts off at faucet and comes...
Verify the height from the shower valve to the Shower head, the instructions specify the correct distance if it is too short the pressure could be getting up to the shower head.
Perhaps the water pressure it too high at the valve not allowing all the water down the faucet outlet, there are set screws on the sides of the shower valve to adjust the water allowed in the mixing chamber.
Something is restricting the water flow to the faucet, creating enough pressure to send some of the ater supply up to the shower.
I hope some of these ideas help
Mar 01, 2009 | Plumbing
Home Logo
551 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
