Question about GE Microwave Ovens
Paint peeling inside microwave - GE Microwave Ovens
  • GE Master
  • 9,098 Answers
After removing any chips, the area will have to be sanded smooth and cleaned and dried thoroughly.
If the cavity metal of the oven is cracked or split, you can use a small amount of steel-based epoxy such as JB-WELD to patch the crack or hole.
Once that dries thoroughly, you can sand it very smooth.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
I would suggest you let it dry overnight with the door open before using the oven.
Posted on Dec 11, 2012
MicrowaveSvc
  • 9098 Answers
SOURCE: peeling paint
You need to thoroughly clean it, then sand it smooth to removew all the loose paint.
Once it's squeaky clean and dry, you can apply high-temperature appliance paint, which is available in brush-on or spray-on form at big box stores like Wal-Mart, home improvement centers like Lowe's and appliance parts stores.
Posted on Nov 05, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: peeling interior
This may have already been dealt with, but others can benefit from an accurate, thoughtful reply to this problem.
You can sand the peeled area, even the rusted area in most cases, clean them squeaky dry, and repaint with high-temperature appliance paint available from places liek Wal-Mart, home improvement centers, and appliance parts stores.
No need to replace the microwave if you can clean and paint it properly.
Posted on Nov 26, 2007
sharcnet
  • 2130 Answers
SOURCE: paint peeling inside microwave
If the unit has been operating properly for some time with no issues, I would say it is fine to continue to use. The issue I would have would be with the possibility with the paint falling into the food.
It would be interesting for you to call the manufacturers' support line and ask why this is happening. Maybe they will offer you a replacement if it was a manufacturing process defect. Mention that the paint may have fallen into the food.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Feb 13, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: inside finish is peeling off
No, if the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Otherwise, you can have rust and arcing, which can be messy.
Posted on Nov 23, 2008
  • 4 Answers
SOURCE: PEELING PAINT INSIDE MICROWAVE/TOASTER OVEN
I do have the same problem, but I know they make microwave paint if you can get it from an appliance store or you can order through the web - BUT 2 sites I just looked at said a gloss enamel paint, such as that used to paint "model" toys works just as well. In either case: Smooth the old stuff off, sand lightly (you want no metal dust left -or- damaging any coating on the metal) just sand enough to make sure there's no flakes & it's smooth, then use a gloss enamel paint rather it's approved for microwaves or the Testor's kind.
NEXT -Make sure you DRY with Hairdryer to set the paint, and keep the heat to med or low, don't bubble or scorch your work!) and do not use the microwave for 24 hours!! Leave the door open while drying for several days afterwards if you can. Any fume smells can be absorbed by using -used- coffee grounds and leaving overnight. Google groups was one source the other was a repair listing forum.
Posted on Apr 03, 2009
Inside of microwave top peeling and blistering
If it's paint peeling, then once that paint is gone, rust will set in, which can cause arcing and disintegration of the chassis, when ruins the oven.
This peeling is usually the result of excess moisture accumulating in the oven due to blocked air vents or poor fan circulation.
Once those two issues have been ruled out or dealt with, then always be sure to dry out or leave the microwave open after use.
The peeling paint will need to be removed, then the area should be sanded.
We're
Nov 28, 2011 | Morphy Richards AM925EF Microwave Oven
Paint inside microwave oven bottom is peeling
The oven cavity will probably start to rust where the paint is gone. If you're up to it, sand it and paint it with a color that matches the interior color. Other then colors, there is nothing special about paint inside a microwave.
Jun 20, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
White bottom panel inside the microwave is peeling in two spots. What can be done if anything?
affected area would need to be sanded and re-painted with microwave paint. repairclinic.com sells the paint
Feb 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The paint has started to peel off inside my microwave!
NO. The insides are baked on powder coat. If you paint it, you might as well throw it away. The paint can catch fire, even after it is dry.
Aug 07, 2009 | Electrolux Microwave Ovens
Paint coming off inside microwave oven
HELLO' WITH IT BEING INSIDE A MICROWAVE I'LD ALSO BE WORRIED ABOUT RADIATION POISON SOUNDS LIKE ITS TIME FOR A NEW MICROWAVE
Apr 05, 2009 | Microwave Ovens
Inside finish is peeling off
Nov 21, 2008 | Microwave Ovens
Peeling paint
Here is a link to buy the paint.
If the microwave is not creating a spark inside when in use, It's OK to use.
Mar 09, 2008 | Rival MT660 Microwave Oven
- Jim
Feb 13, 2008 | Sharp R-820B Convection/Microwave Oven
Peeling paint
Nov 02, 2007 | Rival MT660 Microwave Oven
Peeling interior
Oct 16, 2007 | Goldstar MA-1011 Microwave Oven
Microwave Ovens Logo
37 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
