Question about Acer Aspire 6930-6771 Laptop
Acer 6930 freezes up
Brand new (actually 2nd one, returned the 1st one with same problem.)
Laptop freezes up when goes into sleep or hibernation modes. Techs at Bestbuy finally told me this is a long standing problem with Vista. Is this true. Please suggest solution. Thanks. Dennis
  • Anonymous Jan 19, 2009
    sometimes cant boot up vista and still black screen and sometimes all the laptop freezing , no mouse no keys everything freezing .....plz what i do??
    Genius:
  • Acer Master
  • 1,102 Answers
Is it a problem with vista
Control panel
screensaver then power set standby to never
when you press power button turn off set when you close lid do nothing when I press sleep do nothing and then go to hibernate and remove the check in box
set your times for harddrive and monitor shutdown then press apply and restart
Posted on Jan 22, 2009
Acer one with windows 7 ultimate fall into sleep mode
A laptop computer is typically set to conserve battery power. One of the common settings called standby, sleep mode or hibernation turns off power to the screen and the laptop itself after a preset time limit passes without any mouse or keyboard activity. It can be inconvenient for the computer to shut down while you're working on an open page or during a download. Change the setting if you don't want your laptop to going into automatic shutdowns
Turn the laptop computer on with the power button if it's not set to turn on upon opening. Allow the system to boot up. Open the panel for adjusting the sleep settings. This varies among the popular versions of Windows operating systems. To change the sleep mode setting on a laptop running Windows XP, click the "Start" button, and click the "Control Panel" selection. Choose the "Performance and Maintenance" selection, and click on "Power Options." Click the "Power Schemes" tab, and click the drop downs next to "Turn Off Monitor," "Turn Off Hard Disk," "System Standby" and "System Hibernates." Select "Never" for each drop down in both the "Plugged in" and "Running on Battery Power" columns. Click the "Hibernate" tab and click to remove the check mark in the box next to "Enable Hibernation." To change the sleep settings on a Windows Vista laptop, click "Start," "Control Panel," "Systems and Maintenance" and "Power Options." Then click "Change Plan Settings" under the currently established plan. Click on the "Advanced Settings" tab and select the "Never" option on the "Sleep," "Sleep After," "Hibernate After," "Display" and "Turn off Display After" drop downs. Click the "OK" and "Save Changes" buttons to confirm the settings. To change the sleep settings on a laptop running Windows 7, click the "Start" button, choose "All Control Panel Items," select "Power Options" and click "Edit Plan Settings." Click the drop downs for "Turn off the Display" and "Put the Computer to Sleep." Choose "Never" for both and click the "Save Changes" button.
Feb 06, 2013 | Acer Aspire One PC Notebook
Sony vaio laptop shutting down while plugged in
If it's left on for a period of time, specified by the power settings, it will dim the display, Hibernate, Sleep, etc. In the Control Panel, Power settings, Advanced Power setting , Change to High Preformance, adjust Hibernate and Sleep to Never, adjust advanced power setting to your specs. Shut down and unplug laptop , remove battery, when not in use, if you use on AC most of the time remove battery.
Jan 05, 2013 | Computers & Internet
Within the last few days the moniter "blue light" when it is turned on suddenly turns yellow and the screen goes dark. I move the mouse briskly and turn the moniter off and on again and...
You should check the "Power Options" when the computer "Sleeps" & "Hibernates". Go to the "Control Panel" if you Win 7 or below, if you have Win 10 just type "Power" on the "Search Box" on the bottom left of the screen and then click "Edit a Power Plan" and set when the Computer "Sleeps" and when it "Hibernates". Basically when you move your mouse you are waking up the Computer from "Sleeping" or "Hibernating". Goodluck.
Dec 14, 2017 | Acer Brand ACER P191W 19" LCD Monitor
My name is Luis and my Ibm thinkpad r40 keeps freezing and my screen goes black.
Hi, could be simply your computer is going into sleep mode and not waking back up. try changing your screen saver option to not hibernate or sleep.
Aug 18, 2009 | IBM ThinkPad T40 2373 Notebook
After my Acer Aspire 5100 sleeps and the screen does not return
this is a problem with the standby feature there is a patch that Microsoft has put out that should fix the problem i think the main cause is having a usb device plugged in when going to sleep, search Microsoft knowldege base and it should pop right up
Jul 11, 2009 | Acer Aspire 5100 Notebook
Acer Aspire 6930 on Vista. Will play CD's but will not burn CD's. Tried 4 brands of brand new CD's.
I had similar promblem burning dvds, seems i had to format the disk first. never had to do that on other pc. but itseemed to the problem AA6930 !!!
Apr 11, 2009 | Acer Aspire 6930-6771 Laptop
Aspire one with windows XP. Won't turn back on while in sleep mod
I've had spotty luck with Windows and sleep or hibernate modes. I would suggest just disabling sleep/hibernate mode. The options can be found under the control panel under power options. While turning off the sleep mode won't help your battery life, if you ask me, it beats having to power off the laptop by pulling the battery out. If you don't want to turn it off, you can try adjusting the amount of time it lets pass before it goes to slee.
Mar 05, 2009 | Acer Aspire One Netbook 8.9" Notebook
MSN Heavy Echo During Video Call
Which microphone do you use? an external one or built in?
Jan 05, 2009 | Acer Aspire 6930-6771 Laptop
Acer Aspire 6930-6771 Laptop Logo
638 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
