Question about Back to Basics Blender Solution 5500 Blender
Hello, we stored the blender in a box w. the jar on the base and now the jar is stuck on the base...anything that might help?
  • 8,596 Answers
1) Vinegar - apply vinegar to a rag and apply to any exposed areas - use a q-tip to dribble vinegar into hard-to-reach places. Let a cup of vinegar sit in jar itself. After 20 minutes, try to remove.
2) Hot Water in blender jar.
3) Freezer - don't let it sit too long - 10 mins tops - last resort.
If all else fails, break parts, and reorder them here:
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=3635&linkon=subsection&linkid=120&secid=53
-Tha Mp3 Doctor
Posted on Mar 25, 2009
How to open nutribullet jar stuck on blade base?
try heating the jar with hot water before removing it
Jun 30, 2014 | Magic Bullet Nutribullet Blender
Blender glass jar is leaking at base
It will either be the rubber gasket (it goes between the glass jar and the blade assy) or it could be a worn bearing/bush around the chopping blade shaft. Replace either the gasket or the blade assy.
Apr 02, 2014 | KitchenAid 5-speed Blender With Glass...
Blender Base is stuck and won't budge
Please use the WD-40 and let by 1 hours, and ready.
God bless you
Nov 06, 2013 | Cuisinart SPB-7CH-LR Blender Jar Base
Leaks from the bottom of the glass jar. Bought a new gasket and it is worse than ever.
Are you sure you are installing the gasket correctly?
Leaks are usually the result of a misaligned or cross-threaded blender jar base or from the gasket being installed incorrectly. Make sure the gasket is installed between the blade assembly and the screw on base.
If this does not help, please reply or repost.
Dec 07, 2012 | KitchenAid 5-speed Blender With Glass...
Can not remove base from blender model BL5500SC
leave the blender jar on the blender. with one hand grab the glass jar handle with the other hand hold the base of the blender. then twist or push the handle counterclockwise to free it up so you can completely remove it from the blade
May 19, 2012 | Blenders
How do i get the bottom off the blender jar?
The best way that I've found to remove the bottom from the blender jar is to put the blender jar back on the blender base (make sure it locks in place) and then turn the jar to the right. You'll feel the jar detaching from the base. Once it's loosened up, remove from the base and finish turning the bottom, manually. Before I found this method, I had tried everything to get the plastic bottom detached from the jar. Without removing the bottom, there's no way to clean it properly and rather than be unsafe I'd need to throw the whole works in the trash. But the method I've described above works every time!
Aug 13, 2011 | Jenn-Air JBL800 Work Top Blender
Blender does not blend, only buzzes. So I took the blender jar off the motor base and tried running it. It ran just fine. Put the jar back on the base and it only buzzed. Figured a piece of frozen fruit...
Smart move. The blade assembly is almost frozen and the motor does not have enough torque.. You need to remove the blade assembly and completely clean out the bearing and reassemble after the Mr. clean operation. A lite dab of oil is also called for.
Sep 10, 2017 | Oster 006832000000 10Speed Blender
BC-1352 model blender
Somehow you need to find the name of the manufacturer. If the store where you bought it can't help, try your public library. I would get the contact info for: Hamilton-Beach, Waring, and Black & Decker division of GE. Those are the big 3 blender makers. It's possible that one of them made your blender and sold it under the Betty Crocker label.
Feb 27, 2008 | Betty Crocker BCF1353 Work Top Blender
Cuisinart bc56 blender
how to get the base off the glass container. turn in what directionss it seems stuck
Feb 27, 2008 | Cuisinart CBT-500 SmartPower Premier Work...
Back to Basics Blender Solution 5500 Blender Logo
465 people viewed this question
Top Back to Basics Blenders Experts
Mike
Are you a Back to Basics Blender Expert? Answer questions, earn points and help others
