Question about Kenwood KDC-MP228 CD Player
Kenwood Head Unit Making a Loud Popping Noise at the Start and Finish of each track
I have recently wired up a Kenwwod head unit to a clarion 4-channel amp feeding a 12inch clarion sub and a pair of 6.5inch splits. My problem is that at the start and finish of every track, there is a loud popping noise (The track plays the music perfect for the whole track). I have double checked all the connections and wiring loom and all seems to be fine. Any help would be greatly appreciated.
My mate had the same problem with his stereo in his case it was power related if u are usin crimp connections or any other form of connection to the speakers or the subs that is not a soldered joint it could be that we had to re wire his system with soldered joints and it worked ok. but other than that it could also be ur wires themselves with power cutting out cos the poppin sounds to me like the power cuttin out or in. other than that i really cant think of anything hopefully that helps
Posted on Jun 20, 2007
Clarion NZ502E audio problems
The issue has to be with either the head unit or the external amp that is being fed. Reverse the feed to the amp from the Clarion. If the audio issue now shifts to the other side the problem is with the Clarion. If the issue stays the same then the problem is with the amplifier.
Jun 19, 2016 | Clarion Car Audio & Video
Amplifier remote start wire
There are dedicated terminals / connection points for "remote" input and output on both the amplifier and head unit. This info usually figures prominently in the manuals of both products. Without knowing the which brand and model head unit and amplifier you have, the info may be incorrect. In the past, many head units made use of Blue or Blue/ White for a remote signal. It was used to control an external amp or automatic antenna. An example is the image below of the wiring of a Kenwood KDC-3011 head unit:
Check your manuals (or Google model numbers) to find yours.
Dec 01, 2011 | Kenwood Car Audio & Video
I purchesed this head unit new around xmas of 08. My husband installed it and everything was fine. No noise or any other problems. We bought a new car and transferred the stereo system over to it. Now,...
good day. well its a common head unit problem, have you tried to check on the noise filter of the head unit if it is properly connected. if its not then connect it for it maybe the reason your having the annoying noise. hope this helps. have a nice day
Feb 04, 2010 | Car Audio & Video
My clarion dc 628 cd 6 disc changer will not switch on
Well, I have just had the same problem with the same model.
I had a look inside and it turned out in my case that the din socket that connects the multichanger to the head unit had one pin that had failed, (the power 12V). I had to go through every pin, one by one and found that the 12V was present on the lead coming from the head unit, but was not making its way to the board. It had failed within the socket surprisingly.
So I wired in a new, fused 12V feed to the circuit board, and hey presto, everything came back to life!
I thought I would just add this in case anyone ever searches for this problem in the future.
Jb
Sep 03, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
I have a kenwwod ddx 6027 double din head unit in my car, what cd interchangers will work with my head unit?
Any kenwood changer will work. That head unit also supports DUAL changers
Any FM Modulated changer wil also work.
Changer Control Features
  • Dual Disc Changer Control Capability (CH1/CH2 & AUX)
  • DNPS (Disc Name Presets) with Compatible CD Changers
  • DNPP (Disc Name Preset Play) by Remote
  • CD Text Ready with Compatible CD Changers
  • Direct Access with Remote
  • Random/Repeat/Scan Play (Disc/Track)
Jan 09, 2009 | Car Audio & Video
Clarion drx9675z head unit connector
Go to pacparts.com
They are authorize parts dist. for Clarion
Feb 01, 2008 | Clarion DRX-9675Z CD Player
Kenwood kvt m700
The unit is clipping which means it's too loud, lower the volume and should be fine.
Jan 15, 2008 | Kenwood KVT-M700 Car DVD Player
Rampage amplifier
The amp is supposed to turn on and off with the head unit. The remote wire on the amp should be connected t othe amp control/power antenna wire of the head unit.
The pop should go away when the remote is being switched on with the head unit.
If the amp is staying on with the key removed, it will drain your battery. You need to re-wire it so you don't get stranded.
Nov 29, 2007 | Audiovox Rampage 1200 Watt Amplifier Car...
Audio Output problems
Currently you have the blue wire from your Kenwood head unit connected to the blue wire in the Chrysler wire harness adapter. You need to disconnect this wire, and reconnect it to the blue/white wire coming from your Kenwood head unit instead. You probably already have the remote wire from your subwoofer amp connected there; both wires need to be attached to the blue/white Kenwood remote output. Your LHS is equipped with a factory amp. The blue wire in the Chrysler harness activates the amplifier, but it's connected to your Kenwood's power antenna activation output; therefore it's only being turned on when the tuner is selected.
May 30, 2007 | Kenwood KDC-MP828 CD Player
Kenwood KDC-MP228 CD Player Logo
189 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
