Question about MJ Research Mj Ptc-200 Gradient Thermocycler
PTC-200 won't turn on
The machine is plugged in, no other problems apparent except that it will not turn on when on/off switch is pushed.
I have E7 and machine won't work????
E7 sounds like an error code. First step is to look it up in your owner's manual.
Aug 26, 2014 | Singer Sewing Machines
My Jura Capresso F9 keeps making coffee when no one is pushing the buttons. It is always a big cup, mild. Any ideas what could cause this, other than a ghost who likes weak coffee, as my 5-year-old...
Apparently after a few yrs of use the steam wafting up from a cup of coffee works its way into the electronics touch screen mechanism causing it to turn on by itself...since moisture is such a good conductor for electricity it seems like there is a "ghost in the machine"...credit "The Police" band for that quote...my simple solution was a 6-7 dollar desk fan purchased from Walmart and point it up across the front of the unit...problem solved!...just keep the fan running while you use the unit and save a bundle of $$ not having to send it back to Jura!...Bob in SC
Sep 24, 2011 | Jura Capresso Impressa F9 Espresso Machine
Location of a 2010 E450 fuel reset switch
Except for commercial stripped
chassis vehicles, this switch is
located in the front passenger's
footwell, by the kick panel.
On commercial stripped chassis
vehicles, this switch is located on a
bracket above the brake pedal.
To reset the switch:
1. Turn the ignition OFF.
2. Check the fuel system for leaks.
3. If no leaks are apparent, reset the
switch by pushing in on the reset
button.
4. Turn the ignition ON.
5. Wait a few seconds and return
the key to OFF.
6. Make another check for leaks.
Aug 23, 2011 | 2008 Ford F 450 Super Duty
Got MW512 washing machine.turn power on ,lights come on per usual. hit any program to wash but wont start agitating.help.
Hi - its highly likely the start/pause micro switch under the nice panel is faulty, only way is to replace the display module.
I have come across machines with same problems where you can select any function except of course - push start & nothing happens., if your machine does this then I suggest you invest in a replacement display module.
Jun 22, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Dryer won't start. Whenstart button is pushed it makes it's normal sound but dryer does not start to turn
Try switching off at the power and unplugging from the wall. Then plug back in and switch on and then try again to dry. sometimes its like the whole thing needs re-booting. and apparently its best to pullit out of the wall and then put it back in again.
Jan 24, 2011 | Whirlpool Dryers
2009 cadillac cts - ignition won't turn off
Look for a plastic plug directly under key in bottom of column. Under plug is a switch take small philips screwdriver & push on switch while turning key backward to take out.
Jun 08, 2010 | 2009 Cadillac CTS
Washing Machine will not turn on
Check the fuse braker (box out side) The lid switch may be stuck with soap and etc stopping the plunger from operating properly. Lid and door switches stuck, see if not pushed in and release out when lid or door opens. Hope this may help you.
Jun 02, 2009 | Washing Machines
My monitor didn't display anything>.....
REMOVE ALL CONNECTORS AND ADDITIONAL CARDS.
EXCEPT POWER CONNECTION,
PLUG IN MONITOR TURN MACHINE ON.
DOE IT TURN ON IF NOT IT MAYBE A SWITCH PROBLEM.
IF TURNS ON THAN TURN MACHINE OFF AND PLUG IN ONE WIRE OR CONNECTION AT 1 TME AND TURN THE MACHINE ON, IF IT DOESNT TURN ON THAN YOU HAVE FOUND THE PROBLEM.
CANDYMANGANDY
Jan 27, 2009 | Biostar P4M890-M7 Motherboard
3/4 buttons work
mine did the same thing. apparently, if the internal unit gets too cold, it freezes operation in some of the buttons. try turning up the temp to let it thaw, then try the button again. the downside is that when you turn down the temp again, you are likely going to face the same problem.
Jun 06, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
MJ Research Mj Ptc-200 Gradient Thermocycler Logo
56 people viewed this question
Top MJ Research Science & Laboratory Experts
William McMath
ray gallant
Are you a MJ Research Science and Laboratory Expert? Answer questions, earn points and help others
