Question about Lexmark W840 Printer
920.00. Service Fuser Error
I have a problem by displaying the error code 920.00.Service Fuser Error
  • 125 Answers
SOURCE: Fuser Error 50.1 Fuser is hot. What is a fuser?
The fuser bonds the ink powders onto the paper. It is usually located behind the cartridge in the paper path. There may be several reasons why this error shows. (Bad fuser or bad power supply). It looks like this:
http://printerworks.com/Catalogs/hp-supplies/Q3655A-CLJ-3500-3700-supplies.htm
Here is some useful info:
http://www.fixyourownprinter.com/forums/laser/42184
http://www.coldreset.com/modules.php?name=News&file=article&sid=200
Posted on May 12, 2008
SOURCE: H2-00 Error Code, cant clear
Sounds like a tough one, take off the back cover and make sure all connectors are making good contact. You may have a fault in the main logic board.
This might need a tech to check out.
Hope that helps...
Posted on Jun 24, 2008
  • 13433 Answers
SOURCE: Lexmark E342n Laser Printer Fuser Error
920 Fuser Error
Indicates that the fuser is below temperature when printing
Do a Fuser Service Check
Posted on Jun 26, 2008
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: 920.06 SERVICE FUSER ERROR
    A 920 fuser error indicates that the fuser unit in the printer is below the proper temperature for printing. Turn off the printer for 30 seconds. Bypass any surge device or power strips, plug the printer straight to the power outlet in the wall. Make sure the printer is an operating environment where the temperature is above 16°C (60°F). If none of the steps above correct the issue, the fuser unit or possibly the power supply unit on the printer will need to be replaced. This will require a service action on the printer. I hope I can assist you more on this.
    Posted on May 26, 2010
    • 320 Answers
    SOURCE: 922 service fuser error
    a 922 error is created by an open ac circuit(lamp circuit) on the fuser. the t520 t 522's have lamp holder problems that allow arching from the ill fitting metal contact to the end of the heating bulb. it is not uncommon for the end of this contact to be cut completely in half by the arching causing the 922 error. there are 4 components making up this circuit #2 lamp holders a thermal fuse and the bulb it self. percentage wise for this arching causing this failure is really close to 99.5% of the time. this damage is clearly visable if you remove one of the lamp holders and look at the contact
    Posted on Jul 08, 2010
    I am getting error code E000001-0002 in my IMAGE COPPIER 3545.... how to solve it
    E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode:
    press"Additional Functions" button (looks like a picture of a head with a star inside)
    press the #2 and #8 at the same time (simultaneously)
    press "additional functions" again
    The display should show a choice of
    copier,feeder,sorter,fax,or board service modes
    Select copier
    select clear
    select ERR
    press OK
    Turn power off & back on.
    ****IMPORTANT****
    After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils at 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
    Dec 20, 2014 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
    E studio 520 code c447
    All error code soloution of fuser unit Fuser Unit Error Status Counter
    Purpose
    When a fuser unit related error (error code C41, C43, C44 or C45) occurs, the set value of the fuser status
    counter varies, depending on type of error.
    Displaying and checking the set value of the fuser status counter can analyze a cause for the error. If
    any of "2 to 9" is set at the fuser status counter, the fuser unit will not be operated for safety reasons.
    After the fuser unit related error is resolved, if "0" is set, the fuser unit will be operated as usual. If any of
    "10 to 19" is set at the fuser status counter, the fuser unit will be operated as usual, even if "0" is not set
    after the fuser unit related error is resolved.
    C41: Thermistor or heater abnormality at power-ON
    C43: Thermistor abnormality after abnormality judgment
    C44: Heater abnormality after abnormality judgment
    C45: Thermistor abnormality during printing
    C46 to C49: Reserved
    Description
    When this code is used, the current set value of the fuser status counter is displayed. Only "0" can be
    manually entered, in order to restore the fuser unit to its normal operation, after the fuser unit related
    error is resolved.
    For further reason why the counter value differs despite the same error code, refer to 5.1.7 or 5.1.8
    [Fuser unit related service call] in the Service Handbook.
    0: No error 10: C47 (Reserved)
    1: C41 (Once) 11: C47 (Reserved)
    2: C41 (Consecutively occurs) 12: C48 (Reserved)
    3: C46 (Reserved) 13: C49 (Reserved)
    4: C43 14: C47 (Reserved)
    5: C44 15: C48 (Reserved)
    6: C45 16: C49 (Reserved)
    7: C44 17: C47 (Reserved)
    8: C45 18: C48 (Reserved)
    9: C44 19: C49 (Reserved)
    * Default: 0
    Setting Timing
    Use this code to resolve the fuser unit related error (error code C41, C43, C44 or C45). Resolve the
    error, and set "0" (or reset the counter), in order to restore the fuser unit to its normal operation.
    Caution
    Remember to resolve the fuser unit related error, and then reset to "0." also 447
    Jan 17, 2014 | Toshiba Office Equipment & Supplies
    Error code c43
    Purpose
    Description
    error is resolved.
    * Default: 0
    Setting Timing
    Caution
    Jan 14, 2014 | Toshiba Office Equipment & Supplies
    Call for service C 430
    Purpose
    Description
    error is resolved.
    * Default: 0
    Setting Timing
    Caution
    Dec 31, 2013 | Toshiba estudio 255 Copier
    TOSHIBA E STUDIO 207 ERROR C 44
    Purpose
    Description
    error is resolved.
    * Default: 0
    Setting Timing
    Caution
    Jul 08, 2012 | Toshiba E Studio 207
    Ir6000 error code e246-0002
    Select copier
    select clear
    select ERR
    press OK
    ****IMPORTANT****
    After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
    Jan 11, 2011 | Canon Office Equipment & Supplies
    SHARP MX-3501N: The following Error Code is displayed on our unit. H4-00 Error; Call for Service. I need to reset the code, but do not know how
    this error is a fuser unit error. you cannot reset the error code without repairing or replacing the fuser unit.
    Nov 16, 2009 | Toshiba e-Studio162D Copier
    How do I fix this?
    please have the check on fuser for damage. Could be a thermistor, thermo switch, or faulty heaters. To clear error, service morefunction/clear/error/ok/ exit service mode and cycle power.
    fuser over temp means the fixing assy has exceeded the manufactures maximum temp limits
    Fuser error codes cannot be reset by power cycling the machine eventhough that is what the display tells you to do. In order to reset thefuser error code you must enter the service mode & reset the code.To enter the service mode:
    press the #2 and #8 at the same time (simultaneousley)
    Select copier
    select clear
    select ERR
    press OK
    ****IMPORTANT****
    Afterclearing error stay at the machine to see if it comes to ready. Thefuser assy can reach 139 degrees C.(Water boils @ 100C) The error canonly be cleared through the service mode because a technician shouldinspect the fuser to verify there is nothing faulty that could possiblystart a fire. If you enter the service mode & clear the error,power cycle the machine & during warm up the machine throws a codeagain- turn it off, unplug it & call a tech for fuser repair.
    Good Luck!!
    Aug 10, 2008 | Canon LASER SHOT LBP-5200 Printer
    ERROR
    921 Fuser Error Indicates that the fuser is below standby temperature when the printer is idle.
    Error codes 920, 921, and 922 may display for a cold fuser failure. A 920 error caused by low line voltage can sometimes be cleared by turning the machine off and then on again.
    Service Tip: Set the Fuser Temperature to NORMAL before starting this service check.
    Manually spin the fan and check that
    it rotates freely. Check the cable
    connection to the engine board, J13
    for correct installation.
    Jan 23, 2008 | Lexmark Optra M410 Laser Printer
    Error message on screen E000001-0002
    E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair. Good Luck!! I can be reached @ bspier@carlsonsupplies.com if you have any questions.
    Sep 21, 2007 | Canon imageRUNNER 2200
    Lexmark W840 Printer Logo
    1,259 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
