Question about Honeywell HZ-680 Oil Filled Radiator Heater
NEED NEW POWER ON SWITCH
HONEYWELL RADIATOR OIL HEATER MODEL #HZ-680 . WHERE CAN I BUY THIS SWITCH ? I LIVE IN 90250 ZIP CODE.
  • leemlapr Jan 14, 2009
    I DONT THINK THE HARDWARE STORE WOULD HAVE IT. ITS A DOUBLE SWITCH WITH AN ANTI-TIPPING TRIGGER MERCURY I THINK} IN EACH SWITCH. ALSO IT HAS TO BE AN EXACT SIZE BECAUSE IT HAS TO FIT IN THE CUTOUT ALREADY PROVIDED. I WAS HOPING FOR INFO TO BE ABLE TO ORDER HONEYWELL SWITCHES DIRECT FROM A HONEYWELL DISTRIBUTOR.
Email me at hokrazees85@tmo.blackberry.net
I have the part you need
Trevor
Posted on Jan 22, 2009
  • David Mar 07, 2013
    can you get a off on switch for a home fushion radiator 1500w model ho-0221
    the power off then its low med high i believe
  • 24 Answers
Generally if you remove the switch and visit your local hardware store you can find what you need.
Posted on Jan 13, 2009
  • Brian Markstahler Jan 15, 2009
    i am unable to find anything on parts. Unfortunately since these are distributed through retail stores there is no real dealer. They are primarily intended as disposable as they cost less than you could normally repair them for. Best bet i can think of would be an small appliance repair shop (vacuums, toasters, etc.) we have virtually none of them where i am hopefully you do. Sorry i couldn't be of more assistance. Good luck
Why isn't it heating?
The heating element could be burned out.
Feb 27, 2014 | Honeywell HZ-680 Oil Filled Radiator...
Need a switch for a honeywell HZ680 oil filled heater
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Feb 10, 2011 | Honeywell HZ-680 Oil Filled Radiator...
Whenever the radiator is switched on it emits a shrill whistling noise - it still heats up but too loud to live with. Any ideas?
Sounds as if its low on oil. You probably have a crack in the radiator. My suggestion is to replace the unit with a new one.
Jan 25, 2011 | Honeywell HZ-709 Oil Filled Radiator...
I have a Honeywell Oil filled heater, HZ 680 series. When both switches are turned on, they light up but there is no heat. Also, a funny smell then the switches automatically turn off. Is there anything...
These heaters last about three years,and are throw aways,unless you have some in the ole shed like I do.Checking the switches is the first thing to do,remove them to see if they are burned up on the other side where the connection is.If they are,that could be the smell,or the thermostat is melted down,and smelling,again,throw away,,or save it,and buy a new one,and you will have parts for when it goes out,if the switches are melted down,a compatible switch,if found,can be replaced in the heater,but something made the switches melt down,most likely a heating element in the tanks,non replacable.
Jan 05, 2011 | Honeywell HZ-680 Oil Filled Radiator...
It is not heating as strong as it recently was and this morning I found a small leak of oil on the hardwood floor. Can it be repaired and is it ok to use?
If it is leaking ,when it gets low enough,the heating elements will burn up,it is best to trow it away,and buy a new one,getting parts for these are an act of congress and you can buy a new one for the cost of repairs,and the tanks can not be fixed,or filled.
Jan 04, 2011 | Honeywell HZ-680 Oil Filled Radiator...
Our HoneywellHZ-690 oil - filledheater is leaking and I want to know if it is safe to use.
Here is a tip that I wrote that will help you to understand about oil filled radiator heaters....
Oil Filled Radiator Heater Leaking
heatman101
Dec 03, 2010 | Honeywell HZ-680 Oil Filled Radiator...
Heater is clicking on and off and on and off every minutes when both switches are on
Pl check the manual. There are certain heaters designed this way! I can not comment unless the manual is read.
Sep 23, 2010 | Honeywell HZ-680 Oil Filled Radiator...
All of a sudden the heater is not heating up. The
make sure the thermostat dial is not turned all the way down. The red rotary dial, set it to 6.
Dec 15, 2009 | Honeywell HZ-680 Oil Filled Radiator...
I need operation instructions for HZ 680
I happened to be sitting here with a manual looking for a retail price so I could price it for a yard sale on Sat. I could email a scan (It's not lenghty)
Jan 27, 2009 | Honeywell HZ-680 Oil Filled Radiator...
Honeywell HZ-680 Oil Filled Radiator Heater Logo
516 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
