My router is asking for a host name - Computers & Internet
    Genius:
  • 1,269 Answers
You can just type any name for the host name.
Posted on Jan 13, 2009
Tip
Virtual Server / Port Forwarding does not work from within the Local Network
When you use port forwarding in Virtual Servers and try to test it from within the local network, it may fail. When for example, port 80 is forwarded to a web server in the local network, you may get the router's home page instead of the web server's one or you may get nothing at all. When you try to use the server from outside the local network it will work fine though.
This can happen when you try to access the router's WAN IP address from within the local network. In order for port forwarding to work from within the local network, the router needs to support a feature called NAT loopback. This is not a part of the specification of Belkin routers and modem-routers, so most of them will not have the feature, and if a router does have it, it is not supported.
In order to use the server from within the LAN, you can address it by its internal LAN IP address (e.g. 192.168.2.101).
If the WAN IP address has a DNS host name associated with it, such as www.example.com, and you need to use that name to connect to the server, you can do so by associating the name to the local IP address in the hosts file (a file called hosts with no extension). This file lists IP addresses and host names and is used before actual DNS lookups are done. You can add lines to the hosts file using a text editor like Notepad on Windows. The lines look like:
192.168.2.101 www.example.com www.otherdomain.com # comment
The lines contain an IP address and one or more host names separated by white space. Anything that follows a hash sign is a comment and will be ignored. You will need to change the hosts file on all machines in the LAN that need access to the server.
On Windows, the hosts file can be found in C:\Windows\System32\Drivers\Etc on Windows XP, Vista and Windows 7, in C:\WinNT\System32\Drivers\Etc on Windows 2000, and in C:\Windows on Windows 98 and ME. You need to have administrator rights to edit the file; on Windows Vista and Windows 7 you need to run Notepad as administrator.
on May 05, 2010 | Computers & Internet
Remote access DVR through dydns
the host name does not reside in DNS. Try accessing with the external public ip address
Jan 20, 2010 | 2wire 2700HG-B Router (2700HGB)
HP JetDirect J3258B asking for host name
Question is, if you DO type anything does it save then? I had a similar problem and the box was faulty. Having a host name in their won't stop it from working.
Dec 12, 2009 | HP Jetdirect 170x Print Server
DIR 615 router. Host computer can not find network.
I dont know your router personally but what you need to do is setup a network bridgefull explanation is given here
http://www.microsoft.com/windowsxp/using/networking/expert/crawford_02april22.mspx
Oct 27, 2009 | Computers & Internet
Linksys Wireless-G WRT54G
Try the following on your router
1.) if internal firewall of router is activated, try to disable it.
2.) re-check your DNS settings in the router.
3.) Don't put as local ip address the IP address of the ADSL modem!
4.) Last but not least: if everything fails use static IP setup
Hope it helps...
jowunger
Jul 22, 2008 | Linksys Wireless-G WRT54G Router
Router and xbox 360
in the DMZ zone of your router, it has to be capable to accept incoming connections .
to access your router..192.168.1.1 in internet explorer >>> go >>> it will gonna ask your passwor d and user name(by default they are admin) >>> go to application & gaming...select DMZ...DMZ Hosting -select enable..and tipe your IP address in the form below.
You can find your IP address in Status >>> select Local network >>>> DHCP client table >>>> and you'll gonna find your PC name and IP address in there.
Jan 19, 2008 | Linksys Wireless-G WKUSB54GS Kit
Why can't I access my ISP's resources, such as their mail and news servers on my RO318?
If the servers have simple names like 'mail' or 'news', the problem may be that the ISP's domain suffix is not being added to these names before DNS lookup. Add your ISP's domain suffix as Domain Name in the RO318's System menu. In addition, the ISP may be looking for a particular host name for your account, in which case you should enter the host name as the System Name in the RO318's System menu. Example: Consider the following account with the ISP "earthlink.net". 1. Host Name: C-223344-A 2. Domain Name: www.earthlink.net Mail Server mail Although the ISP lists the name of their mail server as 'mail', the fully expanded name is actually: mail.earthlink.net If the ISP automatically provides the domain suffix to your router, the router will append the domain suffix to DNS requests. If not, you can try one of these methods: 1. In each application (such as mail client or news reader), list the fully expanded server name, 2. Manually configure DNS parameters in the network settings of each of your PCs, and enter the domain suffix manually.
Feb 19, 2006 | NetGear RO318 Router
Computers & Internet Logo
141 people viewed this question
David Payne
David Payne
