Question about Apple iPod nano
Ipod won't do anything, not even charge
You can see the connection symbol on the screen even when it is not connected. the screen has no back light. when it is plugged into the port it won't turn on or charge
    Problem Solver:
  • 18 Answers
My friend had the same problem, try resetting the ipod. or it may have water or being dropped damage
Posted on Jan 13, 2009
My ipod touch has a dark screen and doesn't show anything. no light at all as if it is turned off. but i can listen to music for example. it's working but there is no light.
  1. Turn iPod touch off and turn it on again.
  2. If the issue persists, try to reset the iPod touch while it is connected to power. To reset, press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge the device until it is fully charged.
  3. If that does not fix it. Connect to computer. Open Itunes and make sure you have the latest update.
May 04, 2011 | Computers & Internet
I was playing a game and all of a sudden the screen went white and wont do anything,not even make a noise.how can i fix it?
Try to reset it. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge iPod touch until it is fully charged.
If this doesn't work, try restoring the iPod from within itunes.
Apr 07, 2010 | Apple iPod touch
Mmy ipod is at the music screen where it shows the
that happened to mine once i think i just let it charge...but u have to unlock it
Jan 11, 2010 | Apple iPod nano
The Backlight won't come on. i went to general settings and made sure the auto light was on.. and i even turned the brightness all the way up thinking that would help.. but nothing has changed. what else...
Try the following
Turn the ipod off and then on again.
If that does not work reset the ipod while it is connected to the power. You do this by pressing and holding the sleep/wake button and the home button at the same tme for at least 10 seconds, until either the apple logo or battery symbol appears. If the battery symbol appears, charge the ipod until it is fully charged.
Hope this helps.
Nov 15, 2009 | Apple iPod touch
Some sweat fell on the wheel and the ipod turned off. when i tried to charge it it got very hot it still wont turn on
Did the ipod show any symbol while it was on charge. Sometimes, the atmospheric temperature & humidity of surrounding area makes the device hot even after a few minutes of charge. if this is the case then
1. Remove any jacket/covering/sleeve of your ipod. 2. Connect to power outlet or usb for charging however make sure it is as far away from pc/laptop as possible and in a breezy area. 3. Charge for 15 minutes. 4. Hold down the menu and middle button for 30 seconds until the apple symbol appears.
In case there is a problem with internal circuitry, the ipod will show one of its distress symbols.
Aug 19, 2009 | Apple iPod nano
THE SCREEN SHOWS ITUNES AND USB CORD
You need to connect it to a PC/Mac to register that iPod with Apple before you can even use it.
Jun 21, 2009 | Apple iPod touch
Ipod screen says connected eject before disconnecting shows picture of charger but won,t do anything the time is stuck the battery isn,t charging help
I had a temp problem like this too! I found that by purchasing the plug adaptor, it got around to charging the battery on the iPod eventually. Check that the points of the USB cord at either ends haven't been bent or are at least clean.
Apr 05, 2009 | Apple iPod nano
Ipod 5th Generation Video froze and is now dead
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Mar 26, 2009 | Apple iPod nano 3rd Generation
Hi. I plugged in my iPod nano 4th generation to charge it. It opened iTunes as it usually does and I could see my iPod in my device list. I left it to charge as normal. I came back a while later and my...
Mar 22, 2009 | Apple iPod nano
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
