Question about KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher
Kitchen Aid KUDD03DTSS dishwasher flashing lights
SOURCE: Kitchen Aid Dishwasher--model #KUDS01DJ
On mine the "normal" light was the one that was flashing; after a cycling of the breaker switch in the electrical main panel and closing the washer door, it went to a 2 minute rinse before shutdown.
Posted on Jun 22, 2008
aborcass
  • 2651 Answers
SOURCE: Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
Posted on Oct 19, 2008
  • 3 Answers
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Posted on Apr 27, 2009
localwonder
  • 6784 Answers
SOURCE: Kitchen Aid dishwasher is not cleaning like it use to
Check the following to address this issue further.
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there.
Posted on Jun 21, 2009
SOURCE: Need door latch diagram Kitchen Aid dishwasher (Part No. 9744033)
I thought the metal bar had to be locked into place somewhere in the black latch. This was not the case. I just put the white plastic latch in place in the slot in the door and closed the panel and the metal bar went into the correct position against the black latch.
Posted on Jan 23, 2010
Kitchen aid dishwasher whisper quiet model door stuck closed
I found this on another site hope it works for you.Take a bamboo shishkabob skewer and look were the handle is underneath the plastic console head unit and place the skewer on the right hand side... angle towards the center of the console and wiggle it in and push up...After i thought of the skewer it took me around a minute to push the latch up.
Read more: http://appliancejunk.com/forums/index.php?topic=5096.0#ixzz3Yhgf8Ihd
Feb 24, 2015 | KitchenAid Kitchen-Aid KUDD03DTSS...
Upper drawer dishwasher won't drain
First =check for a plugged drain line
Second = check for plugged screens in the unit.
It could also be your pump. The vanes are only plastic and they sometimes just give out.
Jan 07, 2014 | KitchenAid Kitchen-Aid KUDD03DTSS...
Top drawer will not stay closed
Check the machine to confirm it is level from side to side and front to back. Wonder why the support people didn't think of this
Feb 20, 2013 | KitchenAid Kitchen-Aid KUDD03DTSS...
I have a Kitchen Aid 2 drawer dishwasher and its about 2 years old. My problem is the top drawer will not drain during wash cycle. The bottom drawer drains fine. model number KUDD03DTSS 10
You may have clogged pump to the drawer. open drawer, lay on your back under the dish drawer, removed the black cover (3 screws) remove 2 screws to the pump and allow the water to drain out into a bucket or bowl. make sure the pump can turn easy. Reassemble and test unit again. If fails, replace pump.
Pump
I hope this helps, good luck
Aug 14, 2011 | Dishwashers
What is the reset sequence of a kitchen aid kudi01fl my dishwasher wont start the control lock button is on
Press and hold the heated dry button for 5 seconds to unlock the controls. If that doesn't work go to the link below and it will tell you how to reset the control board.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Good luck
Mar 01, 2011 | Dishwashers
My kitchen aid whisper quiet dishwasher will not start and the clean button is flashing
The flashing clean light is an indication that the water did not heat properly. Follow the link below to some instructions I put together that will show you how to reset the control so you can use the dishwasher again and what may have caused the error. Let me know if this is helpful.
Clean Light Flashing
May 22, 2010 | Dishwashers
Kitchen aid dishwashers model kudi1o1ilbl6 won't function. Cancel light flashes 7 times pauses and flashes 7 times repeat for ever. killing the power did not reset. Advice?
open door, press in rapid sequence the following keys: hi temp scrub, energy saver dry, hi temp scrub, energy saver dry. Close the door until it latches, then open it and depress the cancel key. The lght should clear. It's a beautiful thing.
Aug 15, 2009 | KitchenAid 24 in. KUDS25 Built-in...
Oct 19, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Sep 01, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
May 17, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
