Question about Jenn-Air Kitchen Ranges
Jenn air model jdr8895 ignitor turns on by itself
All 5 burners start sparking at once, by themselves and won't turn off unless I trun of the breaker
  • 12 Answers
SOURCE: igniter stays on
Usually this happens when water or some type of liquid gets on one or more of the igniter switches. Let it dry for 48 hours, turn the power back on and see if it keeps on clicking. If it does, one of the switches needs to be replaced. Not a very difficult job. Hope this helps, APP tech http://www.AppliancePartsPros.com
Posted on Aug 08, 2006
  • 22 Answers
SOURCE: Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago
If they ignitors worked properly before you aunt cleaned them, the problem could be with the way they were cleaned and what they were cleaned with. Please tell me how she cleaned them and with what. Also, had she cleaned them before without incurring any problems, or was this the first time she had cleaned them?
Posted on Dec 03, 2007
  • 3 Answers
Apparently there was a water spill around the burner control knob and in the burner itself; We ran the burner to create heat and then turned it off and let the water dry out and evaporate from the burner and igniter area.
Posted on May 28, 2008
  • 330 Answers
SOURCE: All igniters sparking
the only thing which I found is after I clean the burners, maybe some dirt in.
Posted on Jul 06, 2008
SOURCE: jenn air range, model CVG4280B,
I do not know the cause BUT the fan behavior (on for left burners, off for right burners) is by design. The high-speed fan has two switches; 1) the primary switch visible centered between top two knobs, 2) secondary switches integrated with left burner knobs.
Posted on Jul 13, 2008
Two burners on jenn air counter top make sparking sound but burners won't ignite
turn electricity off to ignitors. remove grates and clean up the burners good, they might have a clogged up hole. gas may not be coming out of burner holes. good-day !! if all else fails, just use a wooden match to light that burner.
Jul 11, 2011 | Microwave Ovens
Jenn air downdraft cooktop. We had a new Jenn Air
This is normal, Jenn Air along with many manufactures use one ignition module for all the burners. So when you turn one knob on all the ignitors on top will spark but gas will only flow to the burner with the knob on.
Here is a copy paste from a Jenn Air Owners Manual, I do not have your model number so I cannot be sure this is the exact phrase in your book.
I hope this helps!
To Set:
1. Push in and turn knob counterclockwise to light the burner.
All surface burners will click. Only the burner that has been
turned on will produce a flame.
2. Turn knob to anywhere between HIGH and LOW. Use the
following chart as a guide when setting heat levels.
May 02, 2010 | Jenn-Air Freezers
We have a Jenn-air JGC8430ADS. The rear left
WE have a Jenn-Air JGC8430BDW gas cooktop. How do i replace a broken ignitor?
Feb 13, 2010 | Jenn-Air Cooktops
Two from burners will not start , unless a match is used
Check the position of the ignitor that sparks, compare it to the burners that do lite.
The other one may ne replacement
Mar 18, 2009 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Ignitors won't stop clicking
there is dirt between the ignitor and the burner or the ignitor is to close to the burner
Feb 15, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-Air JDG8430 Ignitor won't stop sparking after burner ignites
Test the ignitor first, if the ignitor does not spark should be the ignitor itself.
Oct 12, 2008 | Jenn-Air 30 in. JGD8430A Gas Cooktop
Problem with getting burner to light.
All my ignitors spark when I turn one of them on. I'v been told it is normal. I had a problem before and the tech that replace the ignitor said the issues is with alignment. Try to rotate the burner a bit left or right and see if it fixes it.
Aug 26, 2008 | Jenn-Air JGS8850BDS Stainless steel Gas...
Jenn-Air Expressions cvgx2423b manual request
I have the same model with the same problem. The replacement is simple. Remove the burner cap (no tools needed) Take a large crescent wrench and remove the large center nut holding the burner assembly in place. The ignitor will slide out of the assembly once it is removed. Good luck
Aug 14, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Ignition sparking repeatedly
I have a Creda gas stove ,yesterday some water boiled over. I have a continuous spark ever since and the stove is not even on. Is there any way to reslove this without calling a repair person?
May 01, 2008 | Cooktops
Jenn-Air Gas Cooktop Model CVGX2423
you will need to contact your certified local service tech.you might have a distributor problem at yor ignitor box.if the problem is not with your ignitors.
Jun 30, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Kitchen Ranges Logo
19 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
