Question about Maytag Centennial 3.6 cu. ft. High-Efficiency Top Loading Washer
Maytag Centennial Model # MVWC400XW not spinning?
Unit is almost 3 weeks old and it will not go into spin mode. When it does it feels that it is vibrating a lot more then it first did.
  • 183 Answers
SOURCE: Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Posted on Dec 27, 2007
SOURCE: Maytag Performa - Loud Noises during Spin Cycle
This washer is JUNK!!!!!! We have the same washer (2 1/2 years old) and same problem. Tried to replace the bearing myself, no luck. So I called a repair man to come out and look at it. As soon as i told him the model number, they would'nt even come out. Very common problem for this washer. We are on our way to Sears to purchase a Kenmore.....GOOD LUCK
Posted on Dec 31, 2008
  • 12 Answers
SOURCE: Maytag Washer HAV2558AWW loud noise during spin
May be the bearing in your direct drive shaft. If washer is a belt drive, the belt could be frayed
Posted on Nov 17, 2009
  • 274 Answers
SOURCE: Maytag washer (model PAVT244AWW). Won't spin.
Its the clutch ,And it sounds like it time for a new washer,the clutch is expensive and washer are cheap try a second hand store that sale scratched or almost new machines
Posted on Jul 05, 2010
Testimonial: "Response was helpful to figure out our options!"
Daniel S
  • 4323 Answers
SOURCE: Maytag Centennial will not spin
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Sep 22, 2010
Wash cycle will agitate 3 spins then nothing for a few minutes then 3 more and nothing again and repeat over and over
you may want to put it through a diagnostics cycle and check for error codes... Maytag Centennial Washer Repair Guide
The tub sensor can cause the washer to act strangely like that. Also there are two mechanical styles of washer branded Maytag Centennial. The model number would help to know we are talking about the one I think we are talking about.
Hope that helps!
May 27, 2015 | Maytag Centennial 3.2 cu. ft. SuperSize...
Purchased a mvwc400xw washer in 2012. Will not drain and spin. We completed the 3 clicks clockwise and 1 click counter clockwise to get some type of code. Does not give any code. Any suggestions?
are u saying once its reset it does spin? the drain problem can be a clogged water pump. a bad clutch or belt depending on weather its direct or belt driven, also a bad motor coupler will not allow it to spin either other wise u may have abad control board issue
Feb 28, 2015 | Maytag MVWC400XW Washer
Agator not spinning
There is no belt on that unit. It is a direct drive machine. When the unit goes into the wash cycle, does the motor run but it does not agitate?
Nov 28, 2012 | Maytag MVWC400XW Centennial 27" Top-Load...
Maytag MVWC400XW banging during wash cycle
1) try to get the model, name, serial number, from the washing and call to maytag, get the support ONLINE via phone or chat, and give you information from the washing machine, and explain, they will have the record from your washing machine, and guide what the next step for warranty. this the web www.maytag.com
God bless you
Jun 29, 2012 | Maytag Centennial MTW5800TW Top Load...
Maytag Centennial Washer - NO SPIN
OK so it sounds to me like your clutch is just slipping sometimes. Because the issue is sporadic it's hard to test for certain what the issue is, but I would recommened ordering and replacing the clutch to fix the issue. Below is a link to a video that shows you how to replace the part if you'd like.
https://youtu.be/tVc6SZ2DD4U
Jun 01, 2017 | Maytag Washing Machines
After spinning the rinse cycle goes on again. We have the extra rinse OFF. We have tried unplugging the unit.
Thomas,
I have the same washer and the same problem. Our washer is about a year old. It did this for a while once before and somehow corrected itself. I don't remember now what I did back then (if anything) to make it go away but the problem has been back for a week now and nothing I try seems to help.
Sep 13, 2010 | Maytag Centennial MTW5800TW Top Load...
Maytag Centennial 3.6 cu. ft. High-Efficiency Top Loading Washer Logo
44 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
