Question about Toshiba E-STUDIO 450 Copier
The copier toshiba e-232 keeps saying to put doc. feeder down. what can I do to resolve this problem
5 Suggested Answers
  • 126 Answers
SOURCE: The copier keeps saying to put doc. feeder down and i it is. I ha
When you lift/ open the ADF you should see a tab in the back corner (slightly in from the corner) of the ADF. This tab is for the machine to see that the ADF is closed. Make sure tab is there. On its sister model they used a depression switch, check that and make sure it is there and working properly.
Posted on Jan 05, 2009
There is probobly a mictroswitch mounted on or near the hinges that detects the feeder position. See if it is loose or bad.
power supply has the fuse open that feed the voltage for the ardf
Posted on Sep 04, 2009
  • 66 Answers
SOURCE: I'm getting a
On the rear left side of the copier there should be a black hinged actuator sticking up out of a hole in the panel, directly opposite of that there should be a white plastic tab that pushes that actuator down. If not try taping the actuator down flat with the cover.
Posted on Aug 17, 2010
It shows in the screen place doc.feeder in the down posotion
90% it is the RADF PCB. Before replacing it check the sensors and switches of the RADF in 03 mode. Refer to page no 2-29 of SERVICE HAND BOOK.
Dec 05, 2012 | Toshiba e-Studio 232 Black and White...
Toshiba 2860.. auto doc feeder keeps jamming.. seems like one side is feeing and other had side isnt or something similar. Any ideasa?
In any doc feeder, the initial two feed rollers and one paper separator pad/roller handle most of the paper transportation. So usually if you have misfeeds, and the paper is not crumpling up, you have a problem with worn or dirty feed rollers. However, if the paper is getting crumpled up, you most likely have a physical obstruction blocking the paper path. My recommendation for when this happens is to take a thick piece of card stock and manually feed it through the paper path on the doc feeder, this usually acts to unclog any jammed paper bits or debris.
-David.
Oct 30, 2010 | Toshiba 2860 Copier
I'm getting a "PLACE DOC. FEEDER IN DOWN POSITION" message when I place a document in Doc Feeder input tray of my Toshiba E-Studio 3511 copier. It is down. I have removed and reinstalled the feeder...
Jul 12, 2010 | Toshiba E-Studio 3511 Color Copier
Place doc , feder in the down postion
Something is blocking the Original Present sensor in the document feeder. The machine thinks you are trying to use the doc. feeder to make a copy. Clear the obstruction and this should remedy situation.
May 23, 2009 | Toshiba E-STUDIO 450 Copier
Mar 20, 2009 | Toshiba E-STUDIO 450 Copier
Jan 05, 2009 | Toshiba 2060 Copier
The copier keeps saying to put doc. feeder down and i it is. I have to lift cover to like reset the thing.
35 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
