Question about Logitech QuickCam Communicate STX Personal Web Camera
Logitech QuickCam STX vista compatibility?
I'm running Windows Vista and have finally found a good webcam that says it's Vista compatible, the Logitech QuickCam Communicate STX. However I installed the software, made sure I had the latest drivers, and when I try to open the webcam software, it all freezes up and doesn't recognize it, or gives me a series of popup error codes, and I end up having to forcequit the program with task manager. Tried using the cam on Yahoo Messenger (Logitech's site says it works) and it simply tells me the cam is not connected, despite the fact that it is. Any ideas?
  • 1 more comment
  • thomasproudf Apr 27, 2009
    I have the same problem - it is just not compatible with Vista im affraid. I have a to buy a new webcam now aswell! Does anyone have a programme to help ?? ????
  • ndsmith67
    ndsmith67 May 09, 2009
    Mine sometimes works with yahoo messenger, but usually says no webcam found. It works fine on msn, oovoo and skype, so not a vista problem I'm thinking. I found elsewhere that it may be a conflict with another program using the camera, but even if I boot and go right into yahoo it can fail.
  • Anonymous Mar 23, 2014
    I'm having a terrible problem with my Logitech Quickcam Express/Go. Firtly, my computer doesn't recognize it a lot of the time (I've tried every suggested solution there is). When it does get recognized it gives me totally new screens and then says the camera can't work because it's inm use by LWS.exe (the software that runs it). So, it's telling me to turn off the software and then reconnect the camera. But naturally, when I close the program, everything closes--because that's the program that runs it. I'm pulling my hair out!
  • 2,961 Answers
When you were installing the software did a taskbar pop up appear and tell you that hardware was found, and then proceeded to install the cam and inform you that the Logitech STX is now installed and ready for use? If not then the cam may need to be tried in another usb port as of yet it has not been recognised by windows. Also if this is being used on a laptop, sometimes there is not enough power amps being sent be the usb port to recognise, again trying a different port may solve that. If all else fails re install the software again, but make sure windows is allowing the cam to work, as sometimes there is an updater programme that works in conjunction with the cam to update drivers etc, this will probably be being dissalowed by either windows or your internet security programme and any part of the software that is being blocked may be stopping your cam also.
Posted on Jun 11, 2007
  • Logitech Master
  • 2,130 Answers
1st You download Webcam Driver.
Logitech QuickCam
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Posted on Sep 16, 2013
Will the logitech quickcam stx work with windows 7
No, you can install it now. There should be no issue with upgrading later.
Only thing I would suggest is that you check if the webcam is compatible with Windows 7, but I think almost all Logitech webcams are, so no issue.
Dec 28, 2009 | Logitech QuickCam Communicate STX Personal...
No audio on my logitech quickcam when i install it, it worked ok on my xp pc, but not on vista, i installed it with original cd, then tryed later with updates of logitech website, still no audio can you...
some logitech quickcam may installed in xp or vista but it depends on your os you using in, in vista some of these is not compatible that means the hardware cannot respond on your pc
Aug 07, 2009 | Logitech QuickCam Communicate STX Webcam
I have QuickCam 8.3.0 and just bought a new computer with Windows Vista 64 bit ... where can I get a driver for this ? I found drivers that support other windows apps such as XP .. but not for Vista
According to Logitech's support site, the QuickCam Messenger series web-cams aren't supported in Windows Vista. :(,en?osid=13
Also, being that it is considered a "legacy device" now, they probably will not invest the time into writing drivers for Windows Vista.
Here is a link to their newer web-cams, almost all of them are vista compatible. You can verify their operating system compatibility under the "Specifications" tab of each products page.,en
- Joshua
Jun 10, 2009 | Logitech QuickCam Messenger Web Camera
Logitech quickcam zoom with vista?
I haven cheked this ,
this is a patch to make your webcam compatible with vista.
try this
i m sorry if it doesn work becos i don ve the webcam to check wit the patch
Sep 20, 2008 | Logitech Quickcam Zoom 5 Pack Webcam
Windows vista home premiun
Please click on the link mentioned below to download the drivers:
Windows Vista Multilingual 32-bit
* Title: QuickCam v11.1.0.2030
* Software Version:
* Post Date: 8/7/2007
* Platform: Windows Vista
* File Size: Approximate download size is 30.7 megabytes.
Windows Vista Multilingual 64-bit
* Software Version:
* File Size: Approximate download size is 36.3 megabytes.
Also visit this website:
Aug 22, 2008 | Logitech QuickCam Messenger Web Camera
Haveing trouble installing logitech quick cam onto my comuptor thats running windows vista
This problem was caused by a compatibility issue between Windows Vista and Logitech QuickCam Messenger.
Logitech QuickCam Messenger was created by Logitech, Inc..
To search for similar devices that are compatible with this version of Windows, visit the Windows Vista Hardware Compatibility List website online.
However, it’s not totally out of hope for owner of Logitech QuickCam Messenger who has upgraded to Windows Vista. The following hack will use Windows XP driver (a common trick to use non Vista compliant device) to install the webcam in Vista:
  1. Download QuickCam 8.4.8 with driver for WinXP.
  2. Install WinRAR if not already installed yet.
  3. Open the setup installer qc848enu.exe and unpack its contents to a folder. Alternatively, right click on qc848enu.exe and select “Extract to qc848enu\” option.
  4. Insert or plug in the Logitech QuickCam Messenger to a USB port if not already done so.
  5. An “Driver Software Installation” icon in systray (notification area) should appear, which will pop up detailed message if click. It should fail, and “Add Hardware Wizard” dialog window will appear. Choose to install the driver manually by instructing the Wizard to locate and look for the web cam driver inside the Drivers folder under the unpacked folder of the qc848enu.exe setup program. You can use browser button to select the folder.
  6. Windows Vista should grab the XP driver and install it properly.
  7. Download the latest version (10.5.1) of Vista compliant QuickCam software from Logitech to install the software on Vista.
  8. Run the setup (qc1051enu) normally. You may need to skip the detection of webcam near the end of installation process.
Voila, you can now use the Logitech webcam to capture images or use it in conjunction with video chat in IM programs such as Windows Live (MSN) Messenger, AIM Messenger, Yahoo! Messenger, Skype or run Logitech VideoCall.
i hope thist post can solve your problem
Mar 14, 2008 | Logitech Webcam
Problem installing
During the upgrade installation to QuickCam 11.5 the installer will hault and display error code 2738.
Windows XP user:
  1. Please visit the Microsoft website and download Window Scrip 5.6.
  2. After installing Windows Scrip 5.6, please reinstall QuickCam11.5.
Windows Vista Users:
  1. Click on Start Button
  2. Click on All Programs
  3. Click on Accessories
  4. Right click on the Command Prompt, select "run as administrator"
  5. At the prompt type "regsvr32 vbscript.dll"
  6. You will now get a message box saying "vbscript.dll" has been registered
  7. Reinstall QuickCam 11.5
This resolve the problem.
Mar 11, 2008 | Logitech QuickCam Communicate STX Personal...
You will need to download the software that makes it work with windows Vista.
It can be found here,en
Nov 15, 2007 | Logitech QuickCam Pro 5000 Webcam
Have you updated DirectX?, I'm not sure if Vista has DX9.0 or 9.0c, but you could try and update DirectX before you install the cam software. Also if the cam is usb, did you install the software "before" connecting the cam?, some people aren't aware that usb devices have to have the software installed first, before connecting the device.
Jun 11, 2007 | Logitech QuickCam Communicate STX Personal...
Logitech QuickCam Communicate STX Personal Web Camera Logo
595 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
