Question about Reddy HEATER R115 115,000-BTU PORTABLE KEROSENE FORCED AIR HEATER
Will not fire up not blowing out fule - Reddy HEATER R115 115,000-BTU PORTABLE KEROSENE FORCED AIR HEATER
2006 ford f150 keeps blowing the fule pump fuse #9 what should I do
Well don't put a bigger one in u can cause a fire you have a short between circuits on that fuse
Dec 22, 2012 | Rear Right Window Regulator & Motor for...
My car want get any fule iput a new fule pump still no fule istraight wired it and got fule but no fire is there a sensor that would cause it to loose power to the fulepump and cause it not to get fire
Check out your fuel pump main relay and fuse. Often the relay that controls the main fuel pump is also the one the supplies voltage to the coils.
Oct 13, 2010 | 1998 Buick LeSabre
1989 Corvett After running great, started missing and stopped will not start again
cheek youre plugs and plug wires four the miss firing depinding if the car spudder before it died could be fule problem cheek the fule pump fule injectors and fule filter if its carb make sher its set rite <is it still turn over or complety ded win you put the key in
Feb 28, 2010 | 1989 Chevrolet Corvette
No fuel to the plug. only starts with starter fluid n runs for a second. dry plug
start by cleaning all the fule lines and pipes out look at the fule tap in the tank it may have a blocked filter on it,then blow trough all the lines right back into the fule tank if fule is reaching the card strip the carb and clean out all the jets plus the flote bowl your bike is not getting any fule
Jan 19, 2010 | 1992 Suzuki DR 350 S
Why is my 1995 sts blowing 20 amp fuses for the fuel pump?
try to relase the fule pump conector and use new fuse then turn switch on if its blow the fuse again thats mean there is short in the wire harness or in the fule pump relay
Mar 16, 2009 | 1995 Cadillac Seville
Car will not start has spark and fule
try removing the coil pack and see if its cracked ,it might not be throwing out enough power to spark under compression .
Feb 16, 2009 | 2004 Mazda 3
Heating & Cooling Logo
43 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
