Question about Electronics - Others
Cannot remove write protection from pen drive
My name is Dzotepe,I bought a 4GB GXT Mobile Disk USB2.0 and loaded some images on it leaving a free space of 1.63GB. Anytime I want to copy something else on it or download sth on it this message keeps on popping up i.e.The disk is write protected.Please heip me because i want to delete some of the images and also save other materials on it. Thanks.
  • 2,878 Answers
Write protect can mean:
  • You do not have enough rights to modify. I came from another account.
  • It has an actual dip switch you move up and down.
  • The file is in use.
Posted on Dec 12, 2012
5 Suggested Answers
ashishd19
  • 35 Answers
SOURCE: Remove Write Protection
Try this,
1.
Check out if the USB drive has a small swich for write protection. If its there try toggling the switch.
2.
Windows can all write protect flash drives. Check out this registry path,
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
You may find a key here on the right side by the name 'WriteProtect'. If it's not there this would not be the cause of problem. If it's there, make sure that the value is 0.
Please let me know if this does'nt work.
Posted on Nov 21, 2008
karandhir
  • 55 Answers
SOURCE: disk write protected
you need to format your pen drive. insert your pendrive into it's port. then you'll get the drive for your pendrive ( which you find in my computer along with c, d and other drives). right click and you will find your format option over there. rest of the process is easy.. you'll figure it out :)
Posted on Jul 31, 2009
softwareguru
  • 78 Answers
This seems to be the problem of most of us these days and some of our readers who wanted to know the methods how they can remove the Write Protected error from their USB drives like Pen Drives and memory cards.
What is Write Protected error and why it happens?
In the Write Protected error, we can’t write or copy any data in our flash drives and even can’t format the drive.
There are many reasons that cause this problem, let’s see solutions of them.
Solutions:
• First of all try to locate a small switch (if any, that you may have not noticed) at some place on the drive or memory card reader. This is the prime reason for this error. If there is one, switch it to the other side to turn the protection off.
• Yes I know this problem is also occurring these days without this switch but not to worry. Just download this helpful software form here
http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Low-Level-Format-Tool.shtml
and run it to execute a “low-level format” on the drive. This software is quite handy and may take few attempts to actually remove the error.
• The problem can also be caused by some virus activity so just get it scanned by some updated good anti virus which may solve your problem.
• BUT if none of the methods listed above solves your problem then your pen drive might have gone corrupted, so just get it replaced.
Hope any of the methods listed above solves your problem.
Update 1:
After the low level format, you may need to “Partition the drive“. Dont worry, partitioning a pen drive means allocating it its File System and Cluster Size that was lost after the Low Level Format.
For that:
  1. Run diskmgmt.msc in Run.
  2. In the disk management window, select the pen drive, right click on it and click on Format.
  3. Now choose the File System and Allocation Unit Size and do not check the boxes below.
Click OK and the drive will be reusable after this.
Update 2 (Better Solution):
Follow the steps in this post and just put the value 0 (zero) in step 5.
This will surely solve your problem now.
rate me and vote me..
Posted on Jan 08, 2010
piyush_gajer
SOURCE: Write Protected Problem
Hi Sir myself piyush gajera sir i was used my pen drive from winxp to another os version. afterwards it gives me an error that disk is write protected. i tried to remove or format but again it gives me prob that it is write protected and not able to format. i used different solutions but unable to format or remove write protected. please help me. how can i remove this write protection. sir my email id is piyush_gajera147@yahoo.com kindly mail me as soon as possible. my Pen Drive is transced d33193. and it has no any stick to remove write protected. Thanks in advance. i have the same error while deleting or formating my pen drive My transcend 4GB pen drive when deliting data it ask to remove the write protection while formating the disk it shows write protected. when copying data it ask to remove the write protect
Posted on Aug 21, 2012
Sir my pen drive is no format it is show is write prodected
Download this tool it will help you:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?swItem=MTX-UNITY-I23839
Feb 07, 2013 | Kingston Data Traveler 100 G2 4GB USB 2.0...
HOW DO I REMOVE WRITE PROTECTION FROM PEN DRIVE
You have to be the computers administrator to change any values on any hard drive on your computer click start control panel user accounts on the users tab click the name of the computer administrator you must have full control click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
if you need more help with this post a reply
Hope this helps.
Dec 11, 2012 | Electronics - Others
How do i remove write protection from usb pen drive
Click permissions
Hope this helps.
Dec 11, 2012 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
I have a transcend 4gb pendrive.Can I able to set a pasword for it. Any utility is available to protect my pendrive?
Hi Vgvimalgouta,
To protect your Pen Drive , Please follow the below steps :-
  1. Physical Security is the best security in case of Pen Drive, I would say keep the Pen Drive out of reach of anyone but you.
  2. Make sure that you keep only the data that you have already encrypted , if it's very confidential, for e.g. password protect your files and folders into one zip/rar archive , so that even if someone get's your pendrive , he would not be able to have access to your files and folders.
  3. There are many paid software for protecting files and folders, However I know of a Free application that can help you out.
  4. The free Application is Remora USB Disk Guard , You can download the application from this link -- http://bit.ly/moVnDu
Hope this helps ..:) Your feedback would be appreciated.
May 19, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Transcend JetFlash V60 16GB pen drive is write protected
Flash drives by default use the FAT32 file system. FAT32 has a limit of 4gb per file. So you could have four 4gb files on your pen drive, but no files bigger than about 4gb. You could use the NTFS format, but it's not suggested for flash drives since it reads/writes much more often than FAT and will make the drive lifetime MUCH shorter.
Aug 26, 2009 | Electronics - Others
Jul 09, 2009 | PNY 2GB microSD Memory Card
Solutions:
Update 1:
For that:
May 18, 2009 | Kingston 4GB Secure Digital High Capacity...
Try this,
1.
2.
Nov 06, 2008 | Transcend (589307) Media
Pendrive write protection removing
Hey, the transcend pen drives usually have a small switch on the side of it, ie to turn the write protect on and off, usually a small lock symbol on it, the problem with unreadable files names etc, could be a corrupt partition, i would suggest formatting the drive as long as you aint got any important information on it,
All the best
John
Jul 27, 2008 | Computers & Internet
How to remove write protect from pen drive
I OWN A TRANSCEND pen drive of 8gb when i try to copy or format the command it shows is "cannot create,remove the write protected"what shall i do .the pen drive is very new
Jan 12, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Electronics - Others Logo
47 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
