Question about Gateway NV5215u Notebook
Nv52 power button cable replacement instructions
  • 1,591 Answers
Https://www.youtube.com/watch?v=H9ZuAEHXRnQ
Nice video here for this unit.
Posted on Dec 12, 2012
Have acer 7540 On restart have error 0211 key
Try this fix:-
This problem was on a Gateway NV52 running Vista Home Premium (64) and this is how it was resolved, with the help of their tech support:
1. Turn off computer and unplug power cord.
2. Disconnect all external devices
3. remove battery
4. press power button and hold for 10-15 seconds
5. plug power cord back into computer and press power button.
6. Check LED's and listen for power supply fan.
7. If LED's are on or power supply fan starts spinning, watch for boot screen
8. If computer begins to turn on, turn it off.
9. Reconnect battery and external devices.
10. Press power button and make sure computer starts.
Sep 22, 2014 | Computers & Internet
Gateway NV52 won't wake up.
Is it clean? fan and vents? Unplug, remove battery, leave battery out, plug in, reboot. If that fails, Re Boot and try a System restore/recovery to a date before this issue. OR, Boot to Safe Mode, use this procedure to select Normal Boot: http://www.netsquirrel.com/msconfig/msconfig_win7.html When/If you get a Normal Boot, Open Control Panel, Power Options, select High Performance, select Change Plan settings, set plugged in both to Never, set advanced setting to your preference. Use this procedure: http://windows.about.com/od/customizingwindows/ss/set_power_options_all.htm Always shut down and unplug your laptop when not in use, remove battery when you use on AC, your Laptop/components will last longer, and will not be subject to possible power surge damage and the battery, IF it malfunctions will not cause a fire hazard.
Mar 01, 2013 | Gateway NV5214u Notebook
Gateway nv52 won't charge
It sounds like you either have a dead mother board or a bad power inlet. Did the machine work with the new battery while it was charged? If so, then the battery connector was good and the inlet was bad. If not, your motherboard could be dead. I've also seen where a bad battery connector would syphon off enough power to not power on the machine or charge the battery.
Nov 14, 2012 | Gateway NV5215u Notebook
What's your problem?where is switch located that shuts off NV52 when lid closes
go to control panel /appearence personisation /system security go downtoo power optionsedit plan settings (change when comp goes to sleep /change advanced power settingsbox will open power options work way down to power buttons and lid open that up + on battrey open lid close action you will see do nothing open that up and press shut down
that will shut down youre comp when lid closes
Jul 16, 2012 | Gateway NV5215u Notebook
Nv52 has the power light come on but no display or hdd light
cmos battery being charged. You can keep the laptop on to fully charge it or replace it with a new cmos battery.
Mar 15, 2012 | Gateway Computers & Internet
Asus g53 keyboard lights not working
Please try to clear the connector of the keyboard and fix it correctly, it may solve the problem. else you have to replace the keyboard.
<a href="http://www.laptopparteshop.com/asus-g53-g51-keyboard-replace.html">Asus G53 Keyboard</a>, <a href="http://www.laptopparteshop.com/asus-eee-pc-1005ha-keyboard-replacement.html">Asus 1005HA Keyboard</a>, <a href=" http://www.laptopparteshop.com/asus-k52-k52j-lcd-cable-replacement.html">Asus K52F lcd cable</a>, <a href=" http://www.laptopparteshop.com/asus-k52-k52j-lcd-cable-replacement.html">Asus K52J lcd cable</a>, <a href=" http://www.laptopparteshop.com/lenovo-g570-g575-lcd-hinges-replacement.html">Lenovo g570 hinge</a>, <a href=" http://www.laptopparteshop.com/ibm-lenovo-b570-g570-v570-z570-keyboard-repalce.html">Lenovo g570 keyboard</a>, <a href=" http://www.laptopparteshop.com/ibm-lenovo-g550-keyboard-replace.html">Lenovo G550 keyboard</a>, <a href=" http://www.laptopparteshop.com/sony-vaio-vgn-ns101el-keyboard-replace.html">Sony Vaio VGN NS101EL keyboard</a>, <a href=" http://www.laptopparteshop.com/sony-vaio-vgn-ns101el-keyboard-replace.html">Sony Vaio VGN NS101EL keyboard</a>, <a href=" http://www.laptopparteshop.com/hp-g42-laptop-cpu-fan-replace.html">HP G42 fan</a>, <a href=" http://www.laptopparteshop.com/hp-g62-laptop-cpu-fan-replace.html">HP G62 fan</a>, <a href=" http://www.laptopparteshop.com/hp-g62-233nr-234dx-cpu-fan-replacement.html">HP G62-233NR fan</a>, <a href=" http://www.laptopparteshop.com/gateway-nv52-nv78-cpu-fan-replacment.html">Gateway NV52 fan</a>, <a href=" http://www.laptopparteshop.com/gateway-nv52-nv78-cpu-fan-replacment.html">Gateway NV78 fan</a>, <a href=" http://www.laptopparteshop.com/gateway-nv52-nv78-cpu-fan-replacment.html">Gateway NV56 fan</a>, <a href=" http://www.laptopparteshop.com/lenovo-a600-cpu-fan-replacement.html">Lenovo A600 fan</a>, <a href=" http://www.laptopparteshop.com/samsung-r60-r70-keyboard-replacement.html">Samsung R60 Keyboard</a>, <a href=" http://www.laptopparteshop.com/samsung-r60-r70-keyboard-replacement.html">Samsung R70 Keyboard</a>, <a href=" http://www.laptopparteshop.com/toshiba-t135-t135d-keyboard-replacement.html">Toshiba Satellite T135D Keyboard</a>, <a href=" http://www.laptopparteshop.com/toshiba-satellite-e205-keyboard-replacement.html">Toshiba Satellite E205 Keyboard</a>
Oct 03, 2011 | ASUS G73JW-A1 Notebook
Hey i need to purchase a gateway nv53 power board,cable,spring & button cover. I would like where can i purchase it & where to get it fixed.
From a quick search edrence89,
http://www.skyline-eng.com/index.cfm?fuseaction=product.display&Product_ID=7564
http://cgi.ebay.com/GATEWAY-NV52-NV53-NV54-SERIES-POWER-BUTTON-BOARD-/110641410161?pt=LH_DefaultDomain_0
Pictorial disassembly of a Gateway NV53 series Notebook PC,
http://www.insidemylaptop.com/disassemble-gateway-nv-series-laptop-fix-power-jack/
[The Gateway NV5302u is part of the Gateway NV53 series, just as your NV5378u is.
The heading is for replacing the DC Power Jack, but I thought the pictorial guide may come in handy ]
Free Service Manual for the Gateway NV53 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-gateway
Drop down to the second line in the first paragraph, and click on NV53.
This is a PDF file. It may take up to 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 17, 2011 | Gateway NV5378u Notebook
My gateway nv52 does not turn on
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced
Sep 20, 2010 | Gateway Computers & Internet
Gateway nv52 won't turn on
I also had this problem. I turned it off and it would not turn on. I found the solution. First, extend the laptop screen as far back as it will go. Don't just stop the screen at a ninety degree angle. My laptop screen pulls back to about 135 degrees. Now press the power button. It should start up.
Why do I think this works? Well...I used to own an older model thinkpad that had a short "male" connector on the screen, that when the screen was folded down would enter into a "female" connector on the base of the unit and trigger sleep mode on the unit. This is how the system could automatically hibernate when the screen was closed. The little male connector broke off, and I couldn't get the system to wake up, because the connection to tell the laptop that I had the screen up or down no longer worked. I couldn't even power it up. I had to take an ink pen and push the connector through the female end to indicate to the motherboard that I'd opened the screen before it would even turn on.
It appears that the same type of mechanism is built into the long BAR under the screen of the NV52 and somehow it can't determine when the screen is open or closed. If it detects that the screen has not been opened, it won't power up. This safeguard prevents the laptop from being turned on mistakenly while closed up in your laptop bag. Extending the screen back resets the mechanism and it should turn on. Sorry for the long explanation...
Jan 15, 2010 | Gateway NV5215u Notebook
Nv52 sound card drivers for XP does not work
This problem is listed under MT3705 notebook, which doesnt use NV52 drivers but sigmatel
http://support.gateway.com/support/drivers/search.asp?st=pn&param=1014142R
If all else fails remove the drivers restart PC and get windows update to try and solve it.
Aug 02, 2009 | Gateway MT3705 Notebook
Gateway NV5215u Notebook Logo
54 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
